Question about Sony KP-51WS500 51" Rear Projection Television
I have no start up just 4 blinks in protect mode sony kp51ws500
  • 29 Answers
Your convergence IC's have burnt out.
Ask yourself this:
Is the Tv worth saving? is it bright and clear? was it good (when it worked?)
if the answer to all of these is yes, then you have a few choices. If any of these are not true, then you should just get a new tv.
Your choices are:
If you are good at soldering, then you can attempt to replace the IC's yourself. (with all of the parts handy, it should take 1 hour)
If you aren't good at soldering, then you can have a friend do it for you, or you can have a mechanic fix it. (tell them that its the convergence IC's that went bad. (pay no more than $200 for the job).
here is what they look like:
http://farm4.static.flickr.com/3021/2785697590_4b74e0a58f.jpg
(the number may be different)
Here they are connected:
http://www.fixya.com/uploads/images/4790134.jpg
A word of the wise, do NOT open up your tv and attempt this if you don't know what you're doing. There is extremely high voltage inside, even when it's unplugged......so don't get shocked!!!
If you need more info on replacing the IC's, contact me.
Thanks for asking!
-Josh
Posted on Mar 01, 2010
  • 438 Answers
Do you have a manual, and are you prepared to tackle this problem ? diagnostics is in depth .
projection TV`s have many protective circuits in them, they protect your CRT`s from damage, over voltage called x-ray, and many others.
Posted on Jan 31, 2010
Sony Bravia KDL-60EX500 no longer turns on.
Refer to Sony KDL 55EX500 Troubleshooting Manual Protection Mode Symptom...
5X Blink - TCON & HFR Failure
The 5X blink protection mode indicates a communications error between the TCON/HFR board and the MT5388 microprocessor on the A-Board.
First replace the TCON/HFR Board if the 5X protection mode blink pattern occurs. If the TCON/HFR Board does not repair the problem then replace the A-Board.
see schematics in Sony KDL 55EX500 Troubleshooting Manual Page 23
Sep 15, 2016 | Sony Bravia Kdl-60ex500 60" Inch 120hz...
Powers on then right back of light flashes 8 times
Looks like a problem on the convergence board which requires repairing/replacing..
Oct 30, 2008 | Sony KP-51WS500 51" Rear Projection...
My sony bravia kdl-32s3000 keeps turning off and the standby light is flashing 5 times
Just a copy from Sony:
The 5X blink protection mode indicates a communications error between the TCON/HFR board and the MT5388 microprocessor on the A-Board. First replace the TCON/HFR Board if the 5X protection mode blink pattern occurs. If the TCON/HFR Board does not repair the problem then replace the A-Board.
Oct 24, 2012 | Sony KDL-32S3000 32 in. LCD Television
I have a 2003 sony kp51ws500 television and there's a timer on the tv and it won't turn on. A red light blinks 6 times then nothing happens. I unplugged, I hit the reset button, nothing happen
read the instruction manual and see how to operate.
if the timer is for to sleep, the problem will be the IC associates with him, you must see the block diagram and w.diagram. and tracking the signal.
go to www. retrevo.com and download the diagram. God bless you
Jul 31, 2012 | Sony Televison & Video
SONYmodel # KP51WS500 tv work for 45 minutes then blankout with a blanking red light
How many times does the light blink in between pauses? Let me know and I will assist the blinking is an error code.
Aug 09, 2011 | Sony KP-51WS500 51" Rear Projection...
MY SONY KP51WS500 HAS 6 BLINKING LIGHTS AND WILL NOT COME ON...
the set has detected and error of missing a voltage of 5 volts
Oct 15, 2010 | Sony KP-51WS500 51" Rear Projection...
Sony TV Model No. KP51WS500 flashes green & turns off
yes u will have to get a expert in but here is a guide to help your tv is going into protect mode if the screen is flashing green with white lines in it its likely that the green tube is faulty this is very expensive & u my want to purchase something else.
Apr 08, 2010 | Sony KP-51WS500 51" Rear Projection...
Have sony kp51ws500 won't turn on, it clicks then shuts down and i get 7 blinks on front--had green, blue, and red line issues before
Hi wright
To answer your question;
The 7 blinks code(sony error codes) means that the horizontal deflection has stopped.
The common cause for this are transistors Q8035,Q8038 and the horizontal output Q8024 all located on "D" board.
Hope this help and let me know if you need further assistance.
Feb 18, 2010 | Sony KP-51WS500 51" Rear Projection...
Sony home theater system started blinking protect
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Mar 23, 2009 | Sony DAV-DX250 System
Sony KP-51WS500 51" Rear Projection Television Logo
85 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
