What is the size of the Maytag LS7804 washer fuse?
  • 714 Answers
It is a thermal fuse can get 1 from your local appliance dealer or Repairclinic.com
Posted on Jan 31, 2010
Maytag lse7804ade
Buy the right size fuse. Too big of a fuse can cause a fire.
Aug 23, 2014 | Maytag Washing Machines
How do you select the load size on the Maytag Bravos Top load washer?
This machine is equipped with technology that allows it to sense the load size and will use the appropriate amount of water for that load. Takes the guesswork out!
Apr 21, 2010 | Maytag Bravos MTW6600T Top Load Washer
What is the cubic size of my maytag neptune MAH 1 washer
You can find the literature at this Maytag website if you have the correct model number.
Have a great day.
http://www.maytag.com/support/manuals_literature.jsp
Jul 05, 2009 | Maytag Neptune Washer
Model SE9900 Maytag Stackable Washer/Dryer - 9E Error
According to my data, a 9E error indicates door latch malfunction.
Apr 21, 2017 | Maytag Washing Machines
What is the drum capacity size on the orig maytag neptune washer?
Drum size or capacity for the Neptune Model Number MAH4000AWW is 3.4
Jan 03, 2009 | Maytag Neptune Washer
Maytag performa pav2300
Just rehook the clear tube back onto the air dome (back right side of drum), drain any water from the drum, the refill, pressure switch will reset itself. Start to fill on small load size first, then move up when washer starts to be sure it reset all the sizes.
Aug 06, 2008 | Maytag Performa PAV2200
Maytag washer
replace the micro switch and your problem is solved.Its a very small switch right next to your door switch and fuse.It has 3 wires and must be replaced to fix this problem.
May 22, 2008 | Maytag Legacy Series Top Load Washer
Maytag Atlantis Washer - MAV6200AWW will fill and spin, but wont agitate. Also lost the bolt going down into the agitator. Anyone know what size it would be?
bolt has 1/2inch head but dont know the thread size is an orderable part 3 to 5 dollors, may not agitate since agitator not on shft to turn
Apr 17, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag stacked washer/dryer Model LS7804
OK it may be one of 2 things. I would check the lid switch first. On some maytags the have a lid switch that if it is not working properly it will not let the washer fill. If it will not fill the washer will not wash because the pressure switch did not activate the timer to wash. If the switch checks good you might have a bad timer. If you open the control panel you will find a tech sheet with the wiring diagram. I would follow the fill cycle and check the components. You might also check the water valve to make sure its ok too. But its very rear that both the hot and cold would go at the same time. Good luck!
Jul 11, 2007 | Maytag LSE7806A Top Load Stacked...
Washing Machines Logo
160 people viewed this question
Top Washing Machines Experts
