Question about Scheu Heating & Cooling
I have a 30 fas the pilot goes out nomadder how
I have a 30 fas heater and it wont lite when i relese the pilot button
  • 149 Answers
Thermocouple may be bad, are you holding for 45 seconds. is the flame touching the thermocouple if all are true thermocouple is bad.
Posted on Jan 31, 2010
It runs out of fuel
sound like pilot lite is not getting thermocouple hot.
check that pilot lite flame is extending out to and touching thermocouple. If not, clean out pilot lite orface and pilot lite gas feed pipe all the way back to the main gas valve if necessary.
If pilot lite flame is touching thermocouple, then replace thermocouple
Jan 22, 2013 | Mr. Heater Big Buddy Heater
I have a desa gas log heater when the heater lites and goes out the pilot lite goes out also
I would start with cleaning the Pilot ODS Assembly and also reseating the thermocouple.
Here is a link to cleaning instructions.
http://www.allpartsinc.com/mmAllParts/Others/Reseating%20Instructions.pdf
Oct 08, 2012 | Desa International Unvented Gas Space...
Teledyne laars xe pool and spa heater
look inside on panel directions if not turn to pilot setting hold down button light under where small silver line goes under while holding down button when lit keep holding for about a minute then turn to on should stay lit if wont stay lit need new pilot generator
Jun 09, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
When you light the pilot, then put on the burner, it will only burn for 20 - 30 seconds and the pilot light, burner and everything goes off. When you re-lite, the Pilot light will not stay on after you...
Either the thermocouple connection into the gas control valve is loose or the thermocouple needs replacing. Also check the burner and pilot assembly inside the screen area for dust, dirt and insect build up. A clogged pilot can mimic a faulty thermocouple.
Hope this helps you in troubleshooting and solving the problem.
Apr 23, 2011 | Endless Summer 153100 Open Flame Patio...
I light the piuolot button and when i let go of the pilot button the pilot goes out does not light burner wont stay lit
When you light the pilot lite you have to hold the button down until it gets the element hot enough to stay lit. If you hold down the button and lite the pilot and let it go right away it will go out. What to do is hold down the button and lite the pilot and continue to hold the buttn down for about 45 seconds to a minute then let it up very slowly and you will see if it is going to go out by the flame getting smaller as you let up on the button. If it does start to get smaller conitnue to hold it again for a few seconds and repeat the process of letting it up slowly. when the control element gets to the right temperature it will stay lit then turn your valve to "ON" and the fire will start up and continue to heat the water.
Mar 15, 2011 | RELIANCE ELECTRIC WATER HEATER
After I lite pilot and release valve, after 30 seconds, pilot goes out. Can not keep pilot lite.
Failed pilot operator or thermocouple not generating enough D.C. current 30 mega volts D.C. Replace thermocouple and see if this takes care of the problem.
Jan 30, 2011 | Dyna-Glo Heating & Cooling
I lost my manual and dont know how to light my R15 gas wall heater.
if its a stnding pilot turn the gas control nobe to pilot hold down light pilot when lite hold down for 30 saconds,then relese and it should stay lite.
Jan 20, 2011 | Heating & Cooling
Pilot light does light , but as soon as you release the gas knob it goes out
Hi there. You must continue to hold the knob in for at least 30 seconds before releasing. If the pilot still goes out, the "thermocouple" is bad. It's the little tube in the pilot flame. To replace, remove the main burner assembly/pilot. You can get a thermocouple at any hardware store. Ask questions while you are there.
Thanks
Paul
Jul 12, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
ES 160000 Endless Summer Patio heater won't stay lit
Bad thermocouple that senses the heat from the pilot light. This would be evident if you lite the pilot while holding the button down for about 30 seconds. If the pilot goes out as you release the button on the gas valve replace the thermocouple.
Oct 30, 2008 | Heating & Cooling
Heating & Cooling Logo
226 people viewed this question
Top Scheu Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Scheu Heating and Cooling Expert? Answer questions, earn points and help others
