Question about Shimano Deore Xt Thumb Shifters 7 Spd.mountain Bike
Moves to a smaller rear cog by it self
Under load the rear derailer will shift to a smaller cog. are the thumbshifters worn?
    Brigadier General:
  • 8,546 Answers
Possibly the right one, but I doubt it.
Load-induced upshifting is usually due to the indexing adjustment being off due to normal expected cable stretch over time.
You might need to adjust the tension of the rear derailleur cable. Get a bead on how the gear selected and the two derailleur pulleys line up as viewed from directly behind. They should all be in the same vertical plane. If the pulleys are slightly outboard of the selected gear you can expect random upshifting to the next highre gear (smaller cog).
Turn the barrel adjuster at the derailleur about 1/4 turn CCW as viewed from behind the bike. This will make the cable a small bit tighter and you should see the pulleys move inboard to be better aligned with the selected cog. Try riding it and see if it gets a little better, then try another 1/4 turn. Don't go overboard with it though.
Posted on Feb 01, 2010
Shimano Derailer 200GS needs adjusting How do I do that?
There is a barrel adjuster on the derailer, right where the cable comes in.
If you are having trouble getting to the easier gears then you need to tighten (usual problem -cable stretches). Pull out the barrel adjuster and unscrew it (turn CCW). Do this gradually until you get the shifting you want.
There are also two little adjusting screws on the face of the derailer that limit the travel of the derailer(keep it from jumping off the cogs, into the spokes or outside it). It is good to check these while you are working on it. The upper one is usually for the easiest gears, screw it in until you can no longer shift to the easiest, then unscrew it just a bit so that you can get in gear, but so the erailer can never go too far). If nothing happened, it is the other screw, so tighten that one.
Now do the other screw, tighten it until you can no longer shift to the smallest cog , then unscrew a bit, making sure you can shift to the smallest cog.
Hope that helps
Jul 16, 2011 | Cycling
Cannot get rear derailer to work properly 24 inch girls evolution
Don't start messing with the derailleur yet! Make sure your shifting trouble isn't due to something else, such as a warped, dirty, or stretched chain, gummed-up pulleys, crud in the cable housing, trapped cable, or a bent derailleur hanger
Clean the chain and the rear derailleur pulleys. Pull the chain away from each pulley, and turn the pulley to make sure it can move freely. A pulley that offers resistance to turning must be replaced.
Now check the cable to be sure it slides freely. Mud and grit within the cable housing, or on a cable-guide, can keep the derailleur from moving a "full gear" during downshifts. If the cable doesn't slide freely in the housing, you may be able to clean or lube it to restore smooth shifting.
Let the high-gear limit screw. In your highest gear on the shifter, and with the chain on the smallest cog, position the derailleur so the upper pulley exactly matches the teeth of the small cog. Run the chain a bit with the front derailleur in the large ring, adjusting the limit screw until the pulley and the cog seem to match perfectly.
Setting the high-gear (small cog) limiting screw.
Once you're sure the derailleur matches the cog, move it just a whisker (1/8 to 1/4 turn) towards the other cogs. (You may need to readjust a bit if you get chain-skip.)
Closeup of setting the limiting screw.
Now adjust the low-gear limit screw. Shift into the lowest gear (largest cog). If it won't go, loosen the limit screw. With the chain on the largest cog (and the front derailleur in the small chainring), adjust the derailleur so the upper pulley exactly matches the teeth of the large cog.Once it's perfect, turn the limit screw so it moves the derailleur a tiny amount towards the other cogs (1/8 to 1/4 turn usually works).
Setting the low-gear (largest cog) limiting screw.
Now shift to the highest gear (smallest cog). Push the shift lever to downshift one gear (go from the smallest cog to the next-smallest). If it doesn't shift, tighten the cable with the barrel adjuster, 1/2 turn counter-clockwise. Backshift and try again. Continue tightening until it shifts. If it overshifts, going from the smallest cog to the third-smallest, loosen the cable by turning 1/2 turn clockwise. Backshift and repeat until it shifts exactly from the small to the next-smallest cog.
Fine adjustment of tension in the derailleur cable.
Now go to the second-smallest ring. Tighten or loosen the cable slightly, until the outer side plates of the chain are just clearing the third-smallest cog. Shift up and down, fine-tuning until you're satisfied.
Checking the position of the chain on the cogs.
Mar 04, 2011 | Pacific International Pacific Evolution 24...
Hi, I have recently installed a new X9 derailleur in accordance with the manufactures' instructions. I have also relpaced the rear hanger. The gears shift ok, however, when in gear, especially the...
Did you also replace the chain or any of the cogs? Skipping is a common condition when you replace one and not the other. Or if the cogs and chain are well worn, it may simply be time to replace them. You can usually do fine without replacing the gear-rings (that is, the cogs by the pedals)
Nov 10, 2010 | Sram X9 Mountain Bike Rear Derailleur
I need to change my back gear cable
Shift your rear derail down to the smallest cog on the cassette. Loosen the nut that holds the cable onto the derail. If you are reusing the outer cables back the inner cable out to the shifter. If your replacing the outers also, note where they are installed. There should be an allen screw on the bottom of the shifter that will free up the shifter and expose the knob on the end of the cable. Pull out the old cable and install new in reverse. Insert the cable into the clamp on the derail. Pull the cable taught with pliers while tightening nut on clamp. Run through the gears while on middle ring on front. Turn barrel adjuster on derail in and out to dial in shifting. That should do it. Good luck and let me know if you have any problems.
Oct 04, 2010 | Mongoose Exile 26 Men's Full-Suspension...
Good evening - I have Shimano Alivio Gears on my Cannondale F6 MTB and the gears are trying to change down a gear on the rear cogs (go to the larger cog) and need adjusting - which screw is the one to...
Neither screw is for mis-shifts. Those are limit screws for the largest and smallest cogs. Tweaking the cable tension will usually bring in the indexing...
http://www.parktool.com/blog/repair-help/rear-derailler-adjustments-derailleur
It sounds like your cable is/was a smidge too tight.
Aug 14, 2010 | Mountain Shimano Alivio Front Bike...
My shimno sora front derailler shifts perfectly to the small and large chain set cogs, but on the middle, the chain rubs along the cage.
Set the rear derailleur to the lowest gear (big cog) and the front to the lowest gear (small chain ring). Disconnect the derailleur cable. Screw in the adjuster for the cable tension all the way (this adjuster is on the shifter of a mountain bike or the down tube of a road bike). Pedal to make sure the chain is not rubbing on the derailleur cage. If it is, adjust the "L" setting on the derailleur until the chain moves by without touching the cage. Now pull taut and reattch the cable and shift the front to the big ring while pedaling. If it does not shift up well or completely, hold the shifter past its normal shift and adjust the "H" screw so that the derailleur allows the shift. Shift into the highest cassette gear and keep pedaling. The chain should not be touching the front derailleur's cage when you pedal. Adjust with the barrel adjuster until the chain moves freely without touching the derailleur cage.
i hope this helps
-matthew
Oct 30, 2009 | Cycling
Wont change gears 12or3
There should be one or two limiting screws for the front derailleur that you can use to adjust how far out/in the derailleur moves to shift the chain over. You can ask a friend to lift the back end of the bike off the ground while you do the adjusting of these screws and then try shifting the gear while moving the peddles with your other hand.
Aug 21, 2009 | Huffy Womens Mountain Bike - Passion...
Shimano Deore Xt Thumb Shifters 7 Spd.mountain Bike Logo
159 people viewed this question
Top Shimano Cycling Experts
John Egan
John Egan
Eric Hidle
Level 1 Expert
Mike
Are you a Shimano Cycling Expert? Answer questions, earn points and help others
