Question about HP LaserJet 3600n Printer
HP Laser Jet 3600 it has a 51.23 error I
HP Laser Jet 3600 it has a 51.23 error I changed scanner assembly and DC controller NO change . Any have the answer??
  • Luigi Lozada
    Luigi Lozada May 11, 2010
    maybe are the purple conector?
  • 213 Answers
Try replacing interconnecting cables - flat ones
Posted on Jun 14, 2010
Testimonial: "It was the cable under the pick up assembly"
  • Dimitar Todorov Aug 06, 2010
    Which cable is that exactly? I'm facing the same problem but cannot find cables around the pickup assy exept the paper out sensor above the paper casette.
ERROR CODE 51.2M
Hi
A quick look on the internet told me that this is probably a HP ColourLaserjet series printer/copier, and have proceeded on this basis using the 5500 model. This particular code crops up on several models and the explanation is given below:
Description:- A printer error has occurred.
X Description: 1 scanner error 2 scanner startup error 3 scanner rotation error Y Description 0 no color K black C cyan M magenta Y yellow
Remedy:- 1. Press GO to continue. 2. Turn the printer off and then back on. 3. Reseat the connectors between the laser/scanner (J74 - J77) and DC controller PCB (J1106 - J1109). 4. Replace the defective laser/ scanner assembly. Calibrate the printer after replacing the laser/scanner. 5. Replace the DC controller PCB. Calibrate the printer after replacing the DC controller.
I obtained this from the link below:-
Error Codes HP Color LaserJet 3550 Code 51 XY
for the 5500, but there are drop down menus above the error details which enable you to change the model number to your specific machine and then you will get the exact requirements. I recommend you do this as although the error code description for other models is the same, the PCB numbers under the "Remedy" are different for different models. You can also download a service manual from this site using the link at the top of the page.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 27, 2014 | Office Equipment & Supplies
Erroe corde 51.10
Note: Technical skills required:
Laser scanner error:
A. Reseat the connectors between the
laser/scanner and the dc controller PCA
(J801 and J321).
B.Make sure that the laser/scanner
cartridge door interlock mechanism is correctly functioning or not
C.Replace the laser/scanner assembly.
See
D.Replace DC controller.
Laser Scanner assm:
Apr 30, 2014 | HP LaserJet M5025 MFP Printer
5120 code error
Any of these error codes (51.20 51.21 51.22 51.23) points to a failure with one of the laser scanner assemblies on the HP Color LaserJet 4610 an 4650 series. To solve these error codes, replace the corresponding laser scanner. Sometimes when the laser scanner fails you will also hear loud noises (often higher-pitched noises like screeching sounds); the noises can be another sign that the laser scanner needs replacing.
51.XY
PRINTER ERROR
For help press
alternates with
51.XY
PRINTER ERROR
X Description
1 beam detect error
2 laser error
Y Description
0 no color / black
1 Press to continue.
2 Turn the printer off and then on.
3 Reseat the connectors between the
laser/scanner and DC controller PCA
(J1009 - J1012).
4 Replace the defective laser/scanner
Mar 17, 2014 | HP LaserJet 4650n Printer
Error code 52.00
52.00 = laser/scanner error
1. Turn the device off, and then turn the device on.
2. Reseat the connectors between the laser/scanner and the dc controller PCA (J801 and J321).
3. Replace the laser/scanner assembly.
4. Replace the dc controller PCA.
Jul 12, 2011 | HP LaserJet M5035 MFP Printer
Error code 52.0
A laser/scanner error has occurred
Recommended action:
1. From the DIAGNOSTICS menu, run the
laser/scanner motor component test.
Verify that you can hear the motor
rotate.
2. If you cannot hear the motor rotate,
verify that connector J1702 and J1505
are fully seated on the DC controller
PCA (ECU).
3. Verify that the connector J12 on the
laser/scanner assembly is securely
attached.
4. If the error persists, replace the laser/
scanner assembly
Jan 18, 2011 | HP LaserJet P3005n Printer
Mi impresora marca 52.0 error
Mi impresora marca 52.0 error -  Indicates a problem with the internal Laser Scanner.
The Laser scanner provides the image onto the toner cartridge drum, if the scanner stalls or fails to turn an error is reported, in some cases the DC Controller may be at fault.
1)      Power cycle the printer.
2)      If the error persists, replace the laser scanner.
Part Number Laser/Scanner Assembly RM1-2555-000CN
Laser Printer Parts                   www.partsnow.com
Jan 15, 2011 | HP LaserJet 5000 Printer
HP Laser Jet 4 Plus error code 52 What do I do now?
A 52 error is a Scanner failure. Do you hear a "whirring" sound when you get the error?
That's the sound of the scanner motor running amuck.
You're probably going to have to replace the Laser/Scanner assembly or the DC Controller which controls the Laser/scanner motor.
Jan 18, 2010 | HP LaserJet 4 plus Printer
51.20 error message on HP laserjet 4250n printer
It is an error with the laser scanner unit
1 Press ( SELECT button) to continue.
laser/scanner and dc controller
PCA (J83 and J84).
4 Replace the laser/scanner assembly.
See Laser/scanner assembly.
5 Replace the dc controller PCA. See
Dc controller PCA.
If nothing from above works and the printer is no longer in warranty, it is possible if the printer is being used in a very dirty or dusty enviornment that the lens and optics of the laser/scanner are so full of debris that the beam detect error occurs. You can remove the top cover and the big black box in the center is the laser scanner assembly. Remove the screws securing the top cover of the laser scanner and remove and clean up all the optics to include the main mirror in the front. I usually use a damp q tip and for the mirror I slide up from toner cartrdige shutter area and observe from the top as it cleans the mirror. Removing the complete assembly on this model is not easy since there are a couple of cables going to the dc controller which are difficult to remove so removing the top of the assembly is easier.
Here is the service manual:
http://www.feedroller.com/Store/Service%20Manual/LaserJet%204250-4350%20(%204200-4300)%20sm.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 26, 2009 | HP LaserJet 4250n Printer
52.00 error
Hp says you have a bad scanner unit(laser unit) or DC controller, but first reseat all your connectors on your scanner unit(laser) and DC controller. Your scanner is located under the top cover and the DC controller is located behind the right cover. If the problem still persist replace the scanner first.
Apr 23, 2009 | HP LaserJet 4350n Printer
52 scanner error
HP LASER PRINTER ERROR CODE 52 – INCORRECT SCANNER SPEED ERROR
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS  1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
Oct 22, 2008 | HP LaserJet 2840 All-In-One Printer
HP LaserJet 3600n Printer Logo
815 people viewed this question
Seeker5211
Seeker5211
