I have a Tru tech 338 inch tv monitor, the problem is it does not have a cable input connected to it. how do i get cable connected to it or do i have to buy a piece for this problem?
  • 438 Answers
You will half to use a VCR or equivalent to tune TV channels if you have satellite receiver or any device that has video out your good to go
Posted on Jan 31, 2010
Can i connect a blue ray dyd player to a tru tech tv
If your TV has an audio/vidoe input, you can. If has HDMI, better
Jul 11, 2015 | Televison & Video
Just purchased Asus VE248H monitor. Used a 10 pin connector and was happy, but wanted more. Hooked monitor to pc with an HDMI cable, got HDMI - NO SIGNAL. Screen went dark. Disconnected HDMI, reconnected...
Hi , just access the monitor on-screen display (OSD) menu and ensure Monitor input mode is configured for HDMI ( Asus speak the " desired input source" ) - Input select is accessed under tv with arrow icon : change from vga to hdmi
Mar 03, 2015 | ASUS Ve248h 24-inch Led Monitor
I can't get audio to work on my Samsung UN40HU6950F UHD TV HDMI 1 input using the Time Warner Cable Cisco 4742HDC cable box.
if all 4 inputs work with another input source(i.e. your Motorola box) it indicates the issue is with the TWC input source. Also check your HDMI cable to be sure it is in good condition & properly plugged in on both ends.
Jan 12, 2015 | Samsung UN40HU6950 40 Inch Ultra Smart
Hello so on my monitor i have two vga in slots and one of them works and the other keeps saying cable not connected and it stays a black screen so everytime i want to play on my xbox i have to unplug and...
Usually when a PC monitor like this one has multiple inputs, there is an input change button (much like the one on a TV). It might be hidden in a menu. Make sure that when you have both devices connected and turned on that you're switching to the correct input in order to view the other device. It's very unlikely that it will switch automatically.
If you're viewing the correct input and you're still not getting a signal from your Xbox, it could be a defective monitor connection. Try switching the cable first: use the cable that you know works and connect it to the second input to make sure that it's not a cable problem.
If the cable is fine but the second input still isn't working, the monitor input connector is probably malfunctioning. Depending on how long you've had it and if it's still under any kind of warranty, you may want to contact Acer for further support and see if they can either fix it or replace it for you.
Hope this is helpful!
May 08, 2011 | Acer P224W 22 inch LCD Monitor
How to use rca entertainment series 32 inch as pc monitor
Assuming that your RCA 32 inch tv has an HDMI or VGA input, all you need is the proper cable to connect the two units. If your computer has a VGA out (blue female connector) and so does your TV, you would need a male to male VGA cable. If your computer has a DVI out (white connector), you would need to purchase a DVI to HDMI cable. The combinations can me played around with depending on what connectors are on the back of the TV and what you have as an output for your PC.
Feb 28, 2011 | Compaq Computers & Internet
Emerson 42 inch television flat screen HDTV: i connected a DVI to HDMI cable to dell computer screen to television in order to display computer screen to it but the signal isn't working, how do i...
Your Dell Monitor does not have a video output. The DVI/HDMI cable needs to run from the DVI-Out of you computer tower directly to the TVs HDMI input, ideally one with a red/white analog audio input next to it, because that cable only provides a video signal. If you don't have a DVI out on your computer, perhaps your TV has a VGA input. If your computer/video card only has one monitor connector, then you can only connect the Monitor OR the TV.
Dec 27, 2010 | Emerson Televison & Video
We have a panasonic 32"inch lcd tv.we want to
hdmi Ports Qty 3 port(s) PC Interface VGA (HD-15) HDCP Compatible Yes
I read your tv has 3 hdmi ports and a PC input.
if your pc has hdmi out - the you use a hdmi cable from the pc to the tv on one of the hdmi inputs.
if your pc has a 15pin vga cable you can unplug from your PC monitor (or go buy a VGA cable if you want to keep one on the tv and one on your pc monitor - or if you are using a laptop).
when you unplug the computer from the monitor .. check the pins - should look to be about 15 pins in the connector. it that will plug into the tv- then you are using a vga cable. if it will not plug into the tv pc input .. don't force it. It could be a dvi connector . .take the cable off the PC and to radio shack and they can fix you up (you need a dvi to vga cable - not likely, but possible)
I always turn off a pc before disconnecting monitors - and plug into the other display before turning the pc back on.
Good luck.
Bill.
Nov 29, 2010 | Panasonic TCL32U22 32 in. TV
I can't see the words clear when I go on facebook the words are blurryI I asked A tech about it and he said I f I have another monitor to switch over.I have a 26 inch flat screen tv can I use that as a...
It depends if it has a VGA input then you can use it as a monitor. All you have to do is connect a VGA cord from your pc going to your flat screen tv.
Nov 19, 2010 | Samsung 226BW Monitor
Laptop connection
Buy a HDMI cable.Hook up one side of the HDMI cable to ur tv HDMI Hub.The other side of the HDMI cable to ur laptop USB Hub.That it u got a connnection,now go in ur tv input pick which HDMI inputs,u put it in,example 1 to 4 HDMI Hubs.Pick the one HDMI Hub that ur laptop it hook up in.That it now u got ur LCD tv used as a monitor.
Apr 27, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
Need code to program direct tv for truetech tv
here is a list of all of the direct tv codes. I do not see your TV on the list, which is sometimes the case. Maybe you will find it there. Hope so.
http://2getdtv.com/directv/tv_codes.html
May 01, 2009 | TruTech PLV16320 Television
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
