Question about Olevia LT37HVS 37 in. LCD HDTV
The tv is only showing the picture in a small box on the screen. The re.st of the tv is blue. How do I fix this?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 79 Answers
You will have a button on your remote control that allows you to select what picture size you would like in your case it sounds like you have it set to 4:3 and it should be set to 16:4 if this fails check your menu options as one of your factory default settings may have been changed by mistake
Posted on Jan 31, 2010
My 19 inch Emerson tv screen has went blue an no picture isn't showing
Sounds like a bad connection to whatever you have it connected to (cable box, dvd player, etc). Check the connection and then replace cables.
Feb 13, 2015 | Emerson LD195EM8 19 in. LCD TV
Screen stays blue and wont show the picture
TV may be on the wrong input and that will give you a blue screen. When you turn the TV on and the screen starts lighting up it should show on the screen what input the tv is on. If it is not on correct input change input with the TV remote or buttons on the tv. If it is on the correct input try a power cycle on the cable box, just unplug the cable box power cord for a few seconds and then plug it back in. If neither of these solve the problem describe how the cable box is connected to the tv.
Mar 16, 2014 | Mitsubishi WS-55513 55" Rear Projection...
I believe the blue lamp in my 57H81 is going bad.
You need to replace convergence out chips in your Toshiba 57H81 tv by qualified tech because 3-D look picture in rear projection tv shows some thing wrong with convergence output chips.
Your tv model number shows it is rear projection tv that use 3 tubes to make color picture on front screen where as dlp tv use one lamp as back light source to present picture at front screen that is generated in light engine.
Mar 25, 2010 | Toshiba 57H81 57" Rear Projection...
SONY BLUE RAY ONLY SHOWS IN SMALL SQUARE. THE
Have you gone through your TV's menus? You may have to change screen resolution from within the TV's settings to get a full screen presentation.
Dec 29, 2009 | Sony BDP-S350 Blu-Ray Player
Mitsubishi WS-55857 with a flickering blue edge.
The vertical IC needs to be replaced. You can get new Vertical output ICs at www.tvrepairworld.com and they will also help explain where its located.
Nov 27, 2009 | Mitsubishi WT-46805 46" Rear Projection...
BOW PICTURE AND HUE GREENS REDS AND BLUES LIKE SHADOWS
the tv had intermittant solder connections already but h\they appeared when the tv was moved to hook up the digi-box. The solution could be as simple as resoldering the power convergence amps.
Aug 06, 2009 | Televison & Video
The screen shows ''Weak Signal'' and no picture, even though audio is coming through from both the Cable DVR box and Blue-Ray player. The cable box connects to the TV with an HMI cable - all five TV inputs...
Mine did the same thing once. I think all I did was hit the setup on the remote, and let it run back through all the channels and then it worked just fine.
I hope this works for you.
Dec 29, 2008 | JVC LT42P789 42 in. LCD TV
Can't turn the volume up or down
Hello Sir,
you need to replace the tv main board part (whole mother board).
any question call 323-767-6030.
Nov 16, 2008 | Astar LTV-19BG TV
Small picture screen
on the remote there is a button called "View Mode" on the bottom right that changes the size of the screen. Try that. I don't know you would adjust it without the remote
Apr 24, 2008 | Mintek LCD TV Progressive Scan DVD Player
Olevia LT37HVS 37 in. LCD HDTV Logo
176 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
