Question about Samsung DLP HL-P5663W 56" TV
MY Samsung DLP Shuts off after 2 minutes than if I unplug it, it will come back on for 2 more minutes and than go out again. Could it be the Bulb and Ballast failing. I just replaced the bulb a few weeks ago
    Guru:
  • 114 Answers
Try this..
On the bottom left corner there is a blue switch that detects if the lamp door is properly installed, if you try to turn your TV on without it won’t turn on.
Posted on Feb 05, 2010
Testimonial: "Thanks. Funny thing. The switch doesn't work on one side but if you apply alot of pressure on the other its fine"
I had the same problem when the unit heated up. I noticed it was the contact on the door to the lamp. The screw needed to be tight, and I haven't had a problem since. Its a documented problem.
Replaced the DLP bulb and the picture only worked for ten minutes
Hi,again,Thanks for the blessings.One quick way that works for most sets its to unplug the set wait 5 min and plug it back again.Here's instructions to replace the ballast: http://guides.fixyourdlp.com/samsung/bp47-00033a.php Found ballast here: http://www.discount-merchant.com/SAMSUNG-9137-008-08905-Lamp-Ballast-Driver-p/1139281.htm?Click=48173 Pay attention to other sounds like buzzing or whirling because it could also be the color wheel.God bless you and your house! Let me know if you need further help. r2d2repair@gmail.com
Nov 18, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung Dlp completely shuts off and then all three lights flash
Sounds more like the TV is overheating. The lamp cooling fan may be seized or not spinning fast enough. If the TV gets hot enough to trip the thermal, it could rupture the lamp.
Sep 09, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung DLP 62 inch turns off by itself after being switched on
take off the lamp access door on the back and find the safety switch that the door pushes on. unplug the connector from the switch and put staple into the connector to short out the cable. Switch is probably bad. worked for me. same problem.
Apr 07, 2009 | Samsung 61" Slim-Depth DLP HDTV
Our Samsung HL-P4663W DLP is makes noise and shuts off
It is the color wheel, inside the light engine. The bearings get dirty and makes it harder for the wheel to spin causing that whin.
Jan 06, 2009 | Samsung DLP HL-P5663W 56" TV
TV shuts off and then back on, power indicator stays on steady.
I JUST (2 minutes ago!) had the repair man leave for the EXACT same problem on the same model TV!! All he had to do was take the front panel off the TV (in the front) and clean the bulb and fan. He said that the dust gets trapped in there and makes the bulb power off! $100 service call to clean the bulb!! Now it is working GREAT and has not powered off since! Hope this helps!!
Dec 21, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung HLM5065W DLP shuts itself off for no apparent reason
I just had the same exact problem. New bulb and all. Tech. said it was the Light Engine assemble was going bad. Here is some photos of the Light Engine.
http://guides.fixyourdlp.com/samsung/bp96-01579a.php
Nov 22, 2008 | Samsung HLM5065W 50" Rear Projection...
Samsung DLP HL-P5063W
you have the same problem I have. The problem is fixed by changing the new light bulb. The problem appears again after 1500 hours of use. You can keep buying new light bulbs or avoid it by not buying another Samsung TV.
Sep 23, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP TV Powers Off by Itself
yes i have the same problem i need help
Aug 31, 2007 | Proton MM2701VT 27" TV
Samsung DLP HL-P5663W 56" TV Logo
229 people viewed this question
Jerry Greenberg
Jerry Greenberg
