Question about D-Link DI 514 Wireless Router (DI-514)
Can connect to DLINK adsl2 router via wirless but
Can connect to DLINK adsl2 router via wirless but not via lan cable why?
    Scholar:
  • 94 Answers
Make sure your LAN connection is not disabled,
make sure that you are getting a valid IP address form the router
If you need commands for this let me know, also which OS are you using
Posted on Jan 31, 2010
Not able to open settings page (DLINK (WBR-1310)
If the default password on the D-Link has been changed then-
To reset the D-Link back to the default settings -
Press and hold the RESET button at the back of the router with the power ONuntil the LEDs flash at the time the release the RESET button. (firmware version was 3.00, and upgraded to3.05)Connect a LAN cable from the D-Link to your laptop/computer'sLAN port, open the browser on your laptop/computer and enter the D-Link's configurationURL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter)You can now change the default admin password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jul 01, 2012 | D-Link ADSL2/2+ Modem/Wireless Router...
How do I connect a Dlink wireless router to a Netgear WiFi Internet adaptor?
Hi there is two way to connect best is to connect via cable ,DIR 615 login to router setting by typing 192.168.0.1 enter user name and password uaser name will be admin and password could be admin or blank or you need to enter text " read the manual to access the router via internet explorer" make sure WAN connection is DHCP connect LAN cable from your main router to the WAN port of your Dlink it should be ready in 1 miutes also if it support WDS you do not cable it can find the main router signal and connect to it and boost it , should you need any help please post me your question to http://computernetworksupportindubai.com/
Jul 22, 2011 | D-Link DIR-615 Wireless Router
I have ADSL 2+ router D-Link GLB-802C but unable to install it what should i do.. pl.. Bhushan 9968301345
For router u did not need to install any drivers. connect the router to your PC via lan cable and check the connectivity by,
start---> run ----> cmd ----> ping 192.168.1.1
Mar 02, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
I have a d link d1 514 router. I'm unable to open 192.168.0.1. if i put the internet connection wire in LAN then I'm able to get internet access using cable but if i put the wire in wan, I'm not getting...
carry out the resetting of the dlink router
then use lan cable to gain access to dlink router,
set up the internet conenction (i.e. your internet provider modem plugged into the dlink router also)
if it has a built in wizard then just follow the on screen instructions
you will need to define SSID (wireless network name) and passkey (password for the wireless connection)
and the your done. disconnect the laptop from wired connection and connect via wireless
Oct 16, 2010 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Driver
not sure why you will need USB drivers for your adsl2+ modem/ wireless router and 4 port LAN switch. It would help you had provided the model number.
The device uses a LAN ethernet port to connect to the computer. You will need atleast one computer to be on the LAN port for setting it up. Once setup is complete you can use wireless connection for every computer.
The user manual & drivers or the DSL-2740B which appears similar to your product description
http://www.dlink.com.au/tech/Download/download.aspx?product=DSL-2740B
Not sure if you need these. Your computers will need LAN or wireless drivers to connect to this DLINK modem/ router.
Good luck
Dec 25, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
D-link dsl - 2640u ' the lan is up but wireless no...
i have a dlink dsl2640u when i go in 192.168.1.1 and try to turn on the wireless and save it reboots 3 to 4 times then it stays on but the wireless is off any help
Oct 06, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Can't get my wireless router to work
FIRST OF ALL YOU CAN ATTACH ROUTER TO ANY PC WITH LAN CABLE
AND CHECK IT IS WORKING OR NOT
IF IT IS WORKING THEN
REMOVE THE LAN CABLE
IF YOUR WINDOW IS XP THEN GO TO START SETTING CONTROL PANEL AND NETWORK CONNECTINON AND CHECK THE WIRLESS CONNECTION AND FOUND THE WIRLESS NETWORK
THEN WIRLESS NETWORK FOUND
AND CLICK THE CONNECT
IT IS WORKING
Aug 26, 2009 | Toshiba Computers & Internet
Wifi problem of DIR-300 dlink
just open the dlink ip homepage and configure the wireless settings
sagar
Jan 27, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Dlink Router not assigning IP to NAS
DI-624 (Update to FW 2.70+)
See: http://www.infrant.com/wiki/index.php/Hardware_Compatibility_List_-_Network_Switches/Routers#D-Link
Dec 28, 2007 | D-Link DI-624 Air Plus XtremeG Wireless...
I can not get my dlink wbr-2310 router to connect
Try to setup a wirless network thru xp sp2 in the control panel.
Make sure you use the mac id from your router as the password.
Only enable one.
Dec 11, 2007 | WatchGuard Technologies Gateway AntiVirus...
D-Link DI 514 Wireless Router (DI-514) Logo
106 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
