Question about Bowflex Revolution Home Gym
Variable pulley system does not swivel easily. the pulley itself turns freely but not the swivel. should i just use some WD40?
I am having the same problem with the right pully. How did you fix yours?
Posted on Jul 05, 2012
MTD RIDING MOWER MODEL 13AH660F372
Your model is a shift on the go or varidrive. Not a transmission in the true sense . I have had to give the variable pulley a few shots of oil to get the pulley to work freely up and down.This video will help you understand the workings of your drive unit. How the MTD Varidrive system works Variable Speed Pulley Maintenance
May 30, 2016 | Mtd Garden
Swivel wheels won't stay straight and the vac just skids.
Do you find that the wheels are jammed and won't rotate, thus causing the vac to go to theleft or right or just have to be dragged along forward?Try wd40 to see if it will allow the wheels to rotate freely.
May 17, 2015 | Miele Vacuums
CHEVY C1500 SQUEALING, IDLER PULLEY?
Without hearing the noise I can't tell you for sure but take a spray can of WD40 and with the engine running spray some on the belts if noise goes way that's your problem, if not check the A/C (if you have A/C) the compressor may be binding up causing the belt to squeal due to friction from the tight compressor. To check the compressor remove the belt and turn the A/C pulley by hand (should turn freely) next turn on the key (do not start engine) turn on A/C then turn A/C pulley by hand again. It will be harder to turn but still relativity easy. If it is hard to turn it is beginning to bind.
Mar 05, 2013 | Cars & Trucks
Delta Variable speed drill press will not spin belt freely
I would go to Dewaltservicenet.com and you can download a breakdown and also user manual for this tool with information about the set up and belt assembly, the breakdown would show you how everything is supposed to go in the pulley section. L et me know if you need further help
Oct 07, 2009 | Delta Drills
Deck belt keeps tearing up then falling off
If it's an idler pulley, where the belt changes direction from the engine - yes it should turn freely. If it's a double pulley where the drive pulley from the engine connects with the deck/blade pulley, then it it's not going to turn totally free because of the blade pulleys connected to it. But in all cases, none of the pulleys should be seized. Try using WD40 or PB Blaster on the pulley bearing surface to loosen it up - or a new pulley...
Jun 29, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
MTD Lawn Tractor problem
The front belt should be a 954-0280A, rear 954-0370. When you go to higher gears, the front belt should be getting tighter as the vari-speed pulley is moving further back. Remove the shift plate, put the transmission in neutral. Start the engine, put speed selector in highest gear and slowly let out on the clutch. You should be able to see what the problem is. It will do everything the same as if were in gear, except move. Make sure you have the correct belts.
Jun 28, 2009 | Mtd LAWN MOWER PART # 753-0698 KIT-DECK...
Riding mower goes slow in forward speed
There is a variable speed pulley that is a double pulley....one belt from engine to pulley and one from pulley to transaxle....remove both belts...pushing in the clutch will help with removal....remove o ring on top of pulley and pull up......the middle piece of metal is stuck....this piece is meant to slide up and down.....put the middle piece of metal on your pulley in your vice...wd40 the hell out of the shaft on pulley .....grasp the top with one hand and the bottom with your other hand...work the stuck pulley free.....put lithium grease on shaft...reinstall....done
Mar 09, 2009 | Mtd Garden
Hauk infinity reversible pushchair, swivel wheels won't swivel
Removed the wheels and gave a little spray of WD40 lubricant, the wheels swivel perfectly now - very easy!
Aug 29, 2008 | Hauck I'coo Pico 4 Standard Stroller
Bowflex Revolution Home Gym Logo
126 people viewed this question
Top Bowflex Sport & Outdoor - Others Experts
Jerry Greenberg
Jerry Greenberg
Paul Carew
ray gallant
Are you a Bowflex Sport and Outdoor - Other Expert? Answer questions, earn points and help others
