Question about Kenmore 3.8 cu. ft. HE3t Front Load Washer
Clean water is filling in the drum when the machine is off
  • 714 Answers
Sounds like your water inlet valve is leaking
Posted on Jan 31, 2010
Water keeps filling even when not in use
hi Jeremy.
Why does my washing machine keep filling up with water when not in use? Ensure that the waste pipe of the washing machine is higher at one point than the drum of the machine, this will prevent water running back into the machine. Normally this would fill the machine with dirty water. Or it could be a faulty water inlet valve, which will fill the machine with clean water.22 Sep 2007
why is my washing machine filling up with water when off ...
forums.moneysavingexpert.com/showthread.php?t=558300 Search for: Why does my washing machine keep filling up with water when not in use?
if you want to read up more then go to this link.
Washing Machines keeps filling even when not in use Google Search
Nov 18, 2017 | Washing Machines
IT KEEPS FILLING UP WITH WATER AND OVERFLOWS
There is a tube next to the drum that senses the water level, take the screws out of the back of the machine near the top and then you can lift the top off over the drum, look for the tube and see if it is plugged with lint dirt or softener. Clean it out. If that is not the problem then check the sensor that it plugs into to be sure it is not bad
Jul 03, 2016 | Washing Machines
Water keeps filling up the drum and inlet light flashes
either the inlet water valve is bad and needs to be replaced or the controller for it is not cutting off the electricty to it, If you are going to replace something, replace the water inlet solenoid valve.
Feb 10, 2014 | Miele Washing Machines
Asko W6021 won't fill. It clicks and starts, but no water fills drum. I've cleaned drain trap but don't know how to clean inlet filter as suggested in manual.
The water inlet filters are inside where the hot and cold water supply hoses screw into the machine. Turn the water off, unscrew the hoses and they should be visible. However it might not be those causing the machine not to fill. If they needed cleaning the water would fill- but taking longer each wash.
If you confirm the filters are clear, it is more likely to be symptomatic of a malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, or the cold one if it is just cold fill!
Sorry but it needs replacing and a service call ;-0(
Good luck,
John C
Mar 20, 2011 | Asko W6021 Front Load Washer
My Indesit WE165 fills up with water
there is a little hose that runs from the back of the pump
up to a pressure switch that contols water level in drum
I had a problem similar to this and found hose had split making
the drum overfill, replaced hose cured problem
Apr 19, 2009 | Indesit W 123 Front Load Washer
Drum filling with water after cycle is done
replace bad fill valve its bleeding throw under top left rear easy
Nov 13, 2008 | Kenmore Elite 45986 Front Load Washer
Drum filling with water and now and them gives off a nasty smell
try cleaning out the filter but dont forget to turn the hot and cold water taps off at the rear!
Aug 15, 2008 | Zanussi F1245W Front Load Washer
Washing Machine Hoover H100M fills too much water in the drum.
this is 1 of 2 solutions  2 this problem the first thing to check is the vacuum system or it is a split in the pressure switch hose
Mar 05, 2008 | Hoover AAA140 Front Load Washer
An obstruction in the water-inlet valve may mean that it's no longer able to shut off You can easily open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!! Good luck !
Sep 09, 2007 | Whirlpool AWZ410 Front Load Washer/Dryer
Washing Machines Logo
109 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
