Question about Philips LX3700D System
The LX 3750 dvd surround sound. Is the audio
The LX 3750 dvd surround sound. Is the audio optical for outgoing sound only. Why not an optical input if this is a surround sound sysytem.
    Brigadier General:
  • 8,546 Answers
It has a coaxial digital input. For whatever reason, they did not provide on optical one. This is not uncommon.
Posted on Feb 01, 2010
Unable to get TV sound and dvd sound through the surround sound speakers with samsung compatible tv and blu ray player
Hi,Even though you have not mentioned about the cabling connections you have done, for the sake of correct connection I describe all the possible cabling alternatives to you..You can select whichever you want..
TO WATCH DVD ON THE TV:
** Receiver's "AUDIO and VIDEO OUTPUT as " 2xRCA Audio+1x Video " or "Optic Cable OUTPUT or " HDMI Output " of your Home Theater Receiver (whichever you want ,based on the existing sockets and necessary cables on your hand )
** AT TV side : you need to connect "Audio+ Video input s " as can either be : 3xRCA jacks or "Optic cable input " or HDMI IN connector of your TV ,
** than just switch to DVD mode on Receiver and play DVD
You can use "HDMI" connections as well but sometimes HDMI creates problem on Audio..
TO LISTEN YOUR TV ON SURROUND SYS.
** AT TV side : you need to connect "Audio Output " as can either be : 2xRCA jacks or "Optic cable output" or HDMI connector of your TV ,
** to Receiver's "TV input "or "AUX input" or "Optic Cable input"
or HDMI of your Home Theater Receiver (whichever you want ,based on the existing sockets and necessary
** than just switch to respective SOURCE mode on
Receiver corresponding the connector you have used on the back of Receiver ..
Pls remember.."IN " goes to "OUT" or vice versa..all the times..
There you go..Both Tv and DVD sound are on the
Receiver as SURROUNDING SOUND .By this means ,whatever you watch on the TV will come thru your Receiver's SURROUNDING SOUND speakers as well .
Hope this helps!..if more help requires pls let me know.
Take care
Aug 17, 2011 | Televison & Video
How do i hook up mt audio speakers to my tv for surround sound? klh 403
If I understand correctly form your question,you can not hook them unless your TV has 5.1 surround sound amplifier built in...Does it ? I doubt so..
in order to get a surround sound from your TV you need a 5.1 /7.1 DVD/Receiver and you can connect your TV to listen it thru Receiver ..Here is how you can do it..
** connect "Audio Output " as either :"2xRCA jacks"or "Optic cable output" or "HDMI "connector " of your TV ,
** to "RCA input jacks " or "Optic Cable input"
or if you have "HDMI input" of your DVD/ Receiver
** than just switch to respective mode on
There you go..your Tv sound are on the
DVD/receiver as SURROUNDING SOUND .
will come thru your
Receiver
Take care and please
Remember to rate/vote for us to
continue f
or Helping out the Community :)
Jul 06, 2011 | Audio Players & Recorders
Samsung ps wx30 surround sound system. speakers are plugged in to dvd player. dvd player is connected to tv via hdmi cable. speakers only work when using dvd player and not tv/sky etc.. am i missing some...
Hi,here is my simple solution...
To listen your TV on your
samsung ps wx30 surround sound system ,
** you need to connect "Audio Output " RCA jacks or "Optic cable output" or "HDMI out " of your TV unit
** to "AUX input " or "TV" OR "Any input" of your
dvd player or "Optic Cable input" or "HDMI input"
dvd player corresponding your RCA or Optic connection or HDMI ..
There you go..Your TV sound is on the
dvd player By this means whatever you watch on the
TV (
tuner, satellite , Xbox , etc..) ,it's sound will come thru your
dvd player.
Hope this helps!..if more he?p requires pls let me know..
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
Jun 25, 2011 | Audio Players & Recorders
Does it support surround sound
Well not buit in, but it has a 92 KHz/16bit Audio DAC/96KHz/24bit decoder and coaxial digital audio output. So to get surround sound you need to connect the DVD player to your home theater receiver using the Digital coaxial/optical output connector (i.e. fiber Optic). Your home theater has to be equipped with the same type of input and you could enjoy your DVDs in surround sound soon.
Note: the optical inputs and outputs are generally capped when not in use and you will need to remove the the cap to be able to plugin your cable.
Good luck and please don't forget your thumbs-up to help me help you further. ty !
Apr 07, 2011 | Sony DVP-SR200P DVD Player
I want surround sound. How do I hook up my audio 5.1 RVC-884VBK, with my HDbox and LCD TV? It's too confusing. What hooks to what? Currently the HD box and blueray DVD is hooked straight to TV ...
Does you television have an "Optical Audio Output"? This would be the best and easiest way to get surround sound from your system. If your TV has an optical output the you can use an Optical Cable to connect the TV to the reciver. This way whatever you are watching from the TV will be in surround sound. The HDMI connection sends a surround sound signal from each device to the television. If you connect it to this output on the TV then make sure the optical output is turned on in you telivison's menu. If your TV does not have an Optical Audio Output then you will need to connect each optical output from the blu-ray and HDbox to your reciever. Your reciever will need to have two Input channels(one for each device). Then you can select that input to the device(blu-ray or HDbox) that you are using. The optical cable is the best way to go for surround sound because it is pure digital and produces the best sound. If the HDbox or Blu-Ray does not have an optical output then you will need the six rca jacks to get the surround sound. Let me know further info on what you have so I can assist you more.
Jun 26, 2010 | JVC RX-884V Receiver
I have no sound through my surround sound when playing ps3
The optical audio out from the TV only works for the TV's tuner, probably. Hook-up optical from Cable/SAT and from PS3 boxes to DVD/Receiver.
Apr 20, 2010 | Pioneer PDP-LX508A 50 in. Plasma TV
Hi there, is there a way to get my goodmans ghc58 surround sound system to play through my virgin + box? I cant seem to find an optical input/output from the surround sound but i do have a goodmans dvd...
There is an optical output from your Virgin + box but there is no optical input in the Goomans, there is only 5.1 input. The only way to do it is to connect the re and white phono audio output from you virgin box to the red and white tv inputs on the goodmans, this will sound good but it will not give you dolby digital sound.
Dan
Nov 28, 2009 | Audio Players & Recorders
I want to set up my surround sound i need to know what the cable looks like for digital in and video in looks like is it a fiber optic
That is called a TOSLink cable, it is indeed fiber optic. It is for digital audio only, video is carried by HDMI (which also carries digital audio), component video cables, S-video cable, coaxial cable, or RCA jacks.
For your surround sound from a DVD player, connect your digital audio from the DVD to the receiver's input, then the video out from the DVD to the receiver's input. Now the video out from the receiver goes to the TV and the surround sound should now be coming through your speakers. Post again in this thread if you need more help or explanation.
Jan 05, 2009 | Sony STR-DE475 Receiver
How do i connect my subwoofer to my sony dvd player to get the great surround sound?
there will be a subwoofer pre out( needs to be amplified) or if it don't have subwoofer pre out you will have to send the audio out to a stereo reciever that has inputs for the optical ( digital audio signal )( to a stereo or surround system that has 5.1 or higher has full surround sound ) and of course L and R audio inputs and the subwoofer pre out , then the subwoofer pre out will have to be amplified by a reciever , subwoofer amp , surround sound , ect
Oct 17, 2008 | Televison & Video
Dear wayne,
Please locate audio input socket on your TV, Then Connect audio output of DVD recorder to this input socket. The optical output of TV goes to input of amp. Since the DVD recorder is connected to the TV and TV's out put connected to the Amp. Now the sound signals from tv and as well from DVD will be 5.1 surround from the amp.
If any case this does not solve your problem, please mail me the photo of the back side of TV's connections at my mail.
rkr847@gmail.com
ramesh22
Jun 18, 2008 | Televison & Video
Philips LX3700D System Logo
208 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
