Question about Samsung SW62ASP Top Load Washer
Samsung SW65ASP2 top load washing machine only lets water in slowly.
  • 1,531 Answers
There may be an obstuction at the wateer inlet valve turn off your water and remove the hoses and check for anything that would be restricting the water flow if this does not work you may need to replace the inlet valves.
Posted on Jan 31, 2010
While moving my samsung top washing machine, I think my drain hose pipe has moved down the water level. Now machine is not able to retain the water while washing/soaking. I need to pull the drain hose pipe...
Although a few modern washing machines can operate with the drain pipe at any height, most machines will drain the water as soon as the drain pipe is placed below the machine water level.
The simplest solution for your problem would be to ask somebody with some handy man skills or hire a plumber to add a 2 inch PVC pipe to your drainage pipe which extends to a point behind your washing machine & then points upwards, making sure it is long enough to be at a higher point than your machines fullest water level.
This should be a relatively inexpensive alteration & will ensure that water does not drain unless the machine is on its drain cycle.
Please let me know if you need any further assistance.
Best wishes,
Graeme
Mar 10, 2011 | Samsung SW62ASP Top Load Washer
I have a Samsung Washing Machine Intellect SW65ASP2 The error code is E. Filled with water and not draining. I undid a hose at the back and removed a coin which I thought was causing the problem. Any...
you should check the impeller, the thing that looks like a fan, when the coin got in there it would have popped the impeller of the shaft, it does this to avoid burning out the motor. it just pushes on
Jan 29, 2011 | Washing Machines
I have a samsung washer sw65asp2 faulf code 1E
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Jun 05, 2010 | Samsung SW62ASP Top Load Washer
Will not wash it syphons water in the wash mode
The mixing water valve isn't shutting of letting it come in slowly. Replace valve. If not filling up may be caused , drain hos emaybe to low to ground. Should be at least two thirds up the washer.side.
Jun 02, 2009 | Fisher and Paykel GWL11 Top Load Washer
SAMSUNG waching machine doesn't want to drain and spin.
drain pump blocked. remove bottom bung filter where hose comes out. will be a hair pin, bread tag stuck in fan blades
Feb 22, 2009 | Kenmore 24032\24036 Top Load Washer
Frigidaire Top Load Washer
Hello vohra_sam
welcome
You said , Water will not drain out
Usually this is the answer
Water in washer does not
drain or drains slowly.
Because drain hose is kinked or clogged.Clean and straighten the drain hose.
let me know, Huuum
Sep 08, 2008 | Frigidaire GLWS1339CS Top Load Washer
Samsung SW65ASP2
If you are sure there is sufficient water pressure at the hose, then your inlet valve is on the blink....replace it.(the unit where your hose connects onto) Oshie
Jun 22, 2007 | Admiral AW22 Top Load Washer
Samsung SW62ASP Top Load Washer Logo
550 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
easy alberta
easy alberta
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
