Question about Refrigerators
Where are the leveling wheels located on model #FRS26H5ASB4, side by side refrigerator/freezer. Manufactured by Frigidaire.
  • 65 Answers
The wheels located in the back of the unit cannot be adjusted and the front ones can be accessed under the doors by pulling off the grill assembly. Use the screw going thru the cabinet on each side to adjust the front two wheels. Hope this helps.
Posted on Jan 31, 2010
Side by side Frigidaire. Reifrigerator working properly freezer not working
Side-by-side refrigerators typically have a defrost system that automatically defrosts the freezer periodically. The freezer stops cooling to turn on the defrost heater, but should resume cooling after about an hour. If the timer fails, the freezer will never defrost and ice will continue to build up on the coils, stopping all air glow over the coils. This will prevent the freezer from cooling properly and it will give the impresdion that it's failing. Only the freezer cools, the air is circulated into the refrigerator and cools it (only less so) which gives thd appearance that it's working properly (except it's probably not cooling to the proper temperature of ~40° F.).
The fix is to replace the defrost timer. If you can locate its location on your unit, it usually involves unscrewing and unplugging the old unit and installing the new one. You will need you brand and model number when you get a new one.
Nov 02, 2018 | Frigidaire Refrigerators
FRIGIDAIRE REFRIGERATOR MADEL FR121NLH TROUBLE SHOOTING
ifit is a single compressor model, then the door between the freezer and the fridge side may be stuck shut,, usually located in upper left hand corner of fridge
Dec 21, 2014 | Frigidaire Refrigerators
How do i raise/lower frigidaire refrigerator/freezer doors
Hello friend, thank you for your post!
In order to provide you with accurate information could I please get your model and serial number? Each refrigerator has different sets of instructions for leveling doors. Typically you can locate your serial tag (which lists your model number) on the inside wall of the fresh food side of your refrigerator. I have included a link to search for any available manuals. I hope this is helpful. -Matt
Frigidaire Product Manuals
Oct 11, 2014 | Frigidaire Refrigerators
I have Frigidaire model# FRS26H5ASB4 and had a recent bad outlet surge of power. Now all light are on in the frig but the Compressor and Ice Maker are not working. How can I find out the what the prob
Ice maker won't work if compressor will not run, of course. I would suspect the main circuit board if there was a bad surge of electricity, or the problem could be at the compressor, i.e., a bad relay, overload, or start capacitor.
Oct 02, 2014 | Frigidaire FRS26H5AS Side by Side...
How do I repair/replace the ice dispensing paddle? Mine broke in half! I have a Frigidaire FRS26H5ASB4
The panel comes off some snap off others have a couple screws hidden under the drip tray. After removing the outer panel, you will see some screws holding the paddle in place.
Sep 24, 2014 | Frigidaire FRS26H5AS Side by Side...
Need a manual for FRS26H5ASB4
here is the link to the manual copy and paste it if necessary...http://manuals.frigidaire.com/prodinfo_pdf/Anderson/240389306en.pdf
Jul 20, 2011 | Frigidaire FRS26H5AS Side by Side...
Frigidaire Refrigerator FRS26H5ASB5 side-by-side
Hi, yes, your thermostat could be faulty, yes there should vent( damper), check controls on freezer side, controls amount of cold air going to ref. side, yes could be stuck by ice, yes both adjustment are necessary, check manual, some thermostat are very sensitive, you should adjust gradually, wait for about 40 minutes, before adjusting again. yes there's vent flap (damper) yes that could be your problem, normally they get stuck with ice, remove covers to locate it., you 're smart, you will see, damper, good luck.
Aug 12, 2009 | Frigidaire FRS3R5EMB Side by Side...
How old is my refrigerator?
Here is a --->link<--- to download the manual for your unit.
this --->link<--- will allow you the ask Frigidaire what year the unit was manufactured.
hope this helps
clarkco
Feb 17, 2009 | Refrigerators
Frigidaire side-by-side model # FRS26H5ASB4 making humming or buzzing noise
I had the same problem. I found the buzzing noise was caused by ice build up around the fan motor inside the freezer. I believe water must have leaked down around the fan during a defrost cycle. I removed the ice maker, the ice cube bin and ice dispenser auger motor. It sounds complicated, but it isn't too bad. The ice maker and auger are connected with quick connect plugs. So just unplug, remove the screws and remove them from the freezer. You will need to remove several other screws as well, I believe 11 in total as well as the top freezer rack. This will give you access to the white aluminum panel that runs from the top of the freezer to about halfway down the back of the freezer. After you remove the aluminum panel you will see the fan about half way down the freezer. I found a lot of ice around my fan. The fan blades were hitting the ice causing the buzz. Remove the ice and the buzzing is gone. It took me an hour to complete this repair. I hope this helps.
Nov 08, 2008 | Frigidaire FRS26H5AS Side by Side...
Refrigerators Logo
617 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
Gil Shultz
