Question about Dell Inspiron 1720 Notebook
My cursor jumps around as I type. I would like to adjust the sensitivity to see if that helps bet cant figure out how. Can you help?
  • 3,940 Answers
Control panel, mouse, touchpad tab, you can adjust sensitivity there.
The is also an option to disable the touchpad while you type. It may be called ENABLE PALMCHECK or it may say Disable when typing
Posted on Jan 31, 2010
How do i fix keystrokes that jump backward as I type?
Some Lenovo touchpads are over sensitive and they cause the cusor to slip or jump around. In Control Panel select Mouse or Touchpad. A box will open and you can locate touchpad Properties and adjust the sensitivity. Lenovo also has updated touchpad software/drivers for one or two of the most troublesome models. i was able to reduce the cursor jumping around quite a bit by adjusting the sensitivity, but i still don't think it's a good design.
Aug 12, 2014 | Lenovo Computers & Internet
Cursor jumping
I have had this same issue. I realized one day that the palm of my hand was touching the track pad intermittently. Some of the HP laptops have super sensitive track pads. Mine actually has a button that disables it for typing. let me know, if this helps.
Feb 26, 2013 | HP Computers & Internet
Samsung labtop cursor jumps around when typing causing all kinds of problems including highlighting and erasing entire lines or sentences!
Press Fn & F10. This disables the touchpad. You will have to use arrows or a mouse to move the cursor. This helps when you are doing a lot of typing. Press the same keys to enable the touchpad when you are finished typing.
Jan 21, 2012 | Samsung N150 (36725723009) Netbook
I am having a problem when I type and the cursor moving
This happens when your hands get to close to the palmrest and your wrists are actually causing the cursor to jump to another spot. Go to the control panel > mouse> settings > highlight the touchpad listed and select the settings button. Look through the entries and there is a setting for palmrest sensitivity. Turn down the sensitivity so your hands and wrists don't trigger a cursor movement. The hardware and drivers are fine, this is a setting adjustment.
Oct 10, 2009 | HP Pavilion DV6700T Notebook PC
When I am typing he cursor jumps around
It is a fault with Lenovo laptops. My cursor jumps all the time, no matter what software I am using. It is NOT the 'sensitivity' of the touchpad, for my cursor jumps even when I am not typing, even if I don't touch the laptop! I can set the cursor to a certain point on a document and then, after about 30 seconds, it will just jump to another point, even if I am in another room.
Sep 24, 2009 | Lenovo 3000 Y410 Laptop
Toshiba keyboard problem with window vista enterprise
I have seen this before.
Either you are touching the touchpad with your palms as you type, or the touchpad is set to be very sensitive. Either way, you should reduce the sensitivity of the touchpad. Go into the control panel, and go into the mouse properties. On the hardware tab, you should be able to find advanced properties and the sensitivity adjustment. Move the slider to the left to reduce sensitivity. If you stroke the pad very very gently with your finger, the cursor should not move at all. adjust sensitivity until this happens.
Reduce the sensitivity until the cursor stops jumping. This will fix it. :)
Aug 21, 2009 | Computers & Internet
Over sensitive touch pad, causes cursor to jump all over the LCD
Try control panel and double click the mouse icon then settings you can adjust sensitivity there
Dec 28, 2008 | Sony VAIO FRV25 Notebook
Skipping cursor problems
i was trying to assit my lacousin with her laptop "issues" and could not figure out how to stop the cursor from skipping around. when you start typing on her laptop the cursor has been known to:
move randomly while you're typing
highlights text and deletes it
jump all over the page
After doing many google searches, I was unsuccessful in finding a solution so I thought I'd post here. I have tried to make her touch pad less sensitive but nothing seems to work.
Thanks for touching basis with me for clarification...hopes this helps!
Oct 15, 2008 | Acer Aspire 5500 5570-2609 Laptop
Cursor jumps around
If your cursor moves erratically on the screen (for example, if it jumps around the screen, moves at varying speeds, or selects items on its own), perform the following steps:
  1. Clean the surface of the touchpad with a dry, soft cloth to remove grease, sweat, moisture, or other liquids.
  2. Adjust the sensitivity of the touch pad:.
    1. Click the Start button and click Control Panel.
    2. Click Printers and Other Hardware.
    3. Click Mouse.
    4. When the Mouse Properties window appears, click the Pointer Options tab. (Figure 1)
      Figure 1: Pointer Speed
    5. Under Select a pointer speed:, click to move the slider bar closer to Slow.
    6. Click OK.
    7. Check to see if the touch pad still behaves erratically.
  3. If the touchpad still caused the cursor to behave erratically, attach an external mouse to your computer and restart your computer. Use the external mouse to see if your cursor still moves erratically.
Aug 14, 2008 | Computers & Internet
Cursor with independent mind
I've seen it happen with cordless mice. If it's cordless then try changing your batteries.
Nov 16, 2007 | Toshiba Satellite M55-S325 Notebook
Dell Inspiron 1720 Notebook Logo
860 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
