Question about Hifonics Brutus BXi 1206D Car Audio Amplifier
Fuse keeps blowing
Why does the fuse keep blowing when i rehook the battery back up?
  • 15,935 Answers
First - disconnect ALL wires.... Power, Ground, Remote, RCA, Speakers.
Reconnect only power, and ground, and remote wire - being extra careful there are no wire strands sticking out of the terminal.
Now power on the amplifier.
If the fuse on the amplifier blows - the problem is internal and should be repaired by an electrical repair shop familiar with Car Audio Amplifiers.
Thanks!!
Posted on Jan 31, 2010
2001 Cadillac Deville hooked up jumper cables wrong to battery. Some fuses blown have changed all but one, the one says elec under the back seat will not take a fuse they just keep blowing out. Fix??
You have a short to ground ! one says elec under the back seat will not take a fuse they just keep blowing out. Fix?? Could you explain this a little better ? Videos on youtube find a short !
Apr 24, 2017 | Cadillac DeVille Cars & Trucks
Battery died and blew both fuel and ignition fuses, replaced them both and put in another battery , soon as connect battery the fuel fuse keeps blowing,, Suzuki Boulevard
Hi, Mark you have a dead short which is usually the easiest to find. Using a test light connected to the hot side of the blown fuse holder, start probing the wire leaving the fuse holder about an inch away the test light should illuminate, keep probing towards the ignition switch until the test light no longer illuminates you are now very close to the short. For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
Fuse Blowing for Instrument panel 08 FLXH Harley Davidson Forums
Keep blowing Fuse 01 CBR600F4i Honda Motorcycles FireBlades org
gauge cluster fuse keeps blowing
99500 38047 03E pdf
Mar 27, 2016 | Suzuki Motorcycles
Abs fuse keep blowing what should I look for
30A main fuse keeps blowing up on my 2001 thunderbird - Triumph ...
www.triumphrat.net > ... > Hinckley Classic Triples
Nov 13, 2014 - Posts: 33. 30A main fuse keeps blowing up on my 2001 thunderbird ...Have a close look where the loom passes the headstock & inside the headlight shell..... Battery can't reach out and fry a fuse if it isn't attached somehow. ... main fuseblowing (06 Sprint ST ABS), Lumpy, Maintenance & Workshop Talk, 7 ... Fuse 8 keeps blowing? - Wont start...
Apr 4, 2015
Blowing ignition fuse in the rain
Jul 7, 2013
Main 30A battery fuse blowing
Aug 3, 2008
Legend headlight fuse keeps blowing
Jun 10, 2007
More results from www.triumphrat.net
15a fuse keeps blowing ANY IDEA"S ???? - ApriliaForum
www.apriliaforum.com > ... > Aprilia 650cc - 50cc Motorcycles > RS250
Jun 19, 2009 - 13 posts - ‎9 authors
Ive had my bike at a workshop for the last 4weeks getting a freshn up . ... If the fuse isblowing that quick you should be able to find it quickly , probably .... eliminated the dash and reduced the amount of things you need to look at. .... SL750 / Dorsoduro 750 · 2008-2014 Mana 850 and Mana 850 GT-ABS.
Fuse Keeps Blowing - Electrical - VFR Discussion
www.vfrdiscussion.com > ... > Motorcycle Maintenance > Electrical
Dec 29, 2015 | Motorcycles
Fuse keeps blowing, tech replaced a 'faulty' battery but it continued. Tech then fixed a 'short in th wiring and still the fuse keeps blowing. Not sure if this is a glitch or an actual problem with just my...
What fuse keeps blowing (drive or hyd HEAVY FUSES or light fuses probs for invertor controller LIGHT FUSES), low batteries or running on discharged batteries for a period of time can blow the fuses. Have the motors been tested? Is the drive an AC and hyd a DC?
Sep 20, 2013 | Crown Walkie Pallet Truck Electric 6000 lb
2004 buick regal
damaged wire maybe.
Locate the horn that blows and follow the wire back until you see the damaged area.
Should only be one power wire running to the horn.
Very strange that the fuse/relay didn't stop it from happening.
let me know what you find.
Feb 02, 2013 | Cars & Trucks
Keep blowing a 350 amp fuse
check your battery cables for corrosion
Sep 03, 2012 | 2010 Renault Laguna dCi
1988 Mercedes Benz 560Sl The fuse for the A/C and heat control keep blowing I changed it and the A/C is very cold but the fuse keeps blowing when the fuse blows theirs nothing . no air blowing...
right if the fuse blows there should not be any air blowing. Anyway this sounds like your have a bad ground in the circut this is running on. Simply get a meter and check the circut from the battery all the way around ac circut and back to the battery. you will find it as auto electronics are very simple once you put aside your fear of it and realize that it current starts at the battery and ends there. Follow the ac's circut and the problem will be found. good luck
Apr 17, 2011 | Mercedes-Benz 560-Series Cars & Trucks
Keep blowing battery fuse on my 04 fxsts
Your Dynamo is giving more current than its supposed to resulting in blowing up the fuses when the bike is speeding. Either change or repair the armature..............................sodeep
Jun 28, 2009 | 2004 Harley Davidson FXST - FXSTI Softail...
Starter fuse keeps blowing
Sounds like a short in the system. you will need to inspect the wiring and posably, bench test the starter. Check the cables to the battery. Make sure the wires and the battery are in good shape.
May 13, 2009 | 1997 Dodge Neon
Hifonics Brutus BXi 1206D Car Audio Amplifier Logo
51 people viewed this question
Top Hifonics Car Audio & Video Experts
Professor_V
Professor_V
Matthew Spark
Matthew Spark
Radames Pagan
Radames Pagan
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
