Question about Ricoh Aficio 3025 All-In-One Laser Printer
Copier/Printer Pproblem I have a ricoh aficio 3025 copier/printer that currently shows a maintenance code of SC541 - what has happened
    Sniper:
  • 58 Answers
What it means......
541 A Fusing thermistor open
The fusing temperature did not increase
12 °C at the center or ends of the hot
roller within 2 seconds after two checks
from the time the fusing lamps turned
on.
what could cause it.....
Fusing thermistor out of its position
because of incorrect installation
• Fusing thermistor disconnected or
defective
• Power supply not within rated range
(15% or more below rating
What to do if your not a technichian you should have one check it out
there are some high tempetues invoved ..the code is there to prevent fire hazzard
Posted on Feb 25, 2010
RICOH AFICIO 3025 CODIGO DE ERROR SC 302
High voltage electrical problem:
Charge corona output error - grid voltage error - charge roller current leak.
Not likely to be a diy job.
Apr 06, 2014 | Ricoh Aficio 3025P Black and White Copier
Service code "SC541" on A Ricoh Aficio 1015/18
that mean themistor is corrupted chang it first try to clean it if it does't work change it his position on fuser unit
Jan 11, 2011 | Ricoh Aficio 450 Copier
My ricoh aficio 3025 copier has the capabilities to scan, print & fax but it only copies. Can we add those modules?
you need to buy a enable sd card for print and scan... and the problem with the fax function just conect it., the line and the phone.
Jul 09, 2010 | Ricoh Aficio 3025 All-In-One Laser Printer
Hello, We have a Ricoh Aficio AP410N Laser printer. It stoped working and gives the error code SC514. Resetting it didn't help. Could you please advise? Many thanks
There is no SC514 on an AP410N. Do you mean SC541? SC541 is a fuser code that a technician has to reset. It could be something as simple as a power spike, or it could be a dirty sensor or a blown board.
Jun 01, 2010 | Ricoh Aficio AP400N Laser Printer
Gives code sc541 on Ricoh 1035
Clean the fuser thermistors.For reset enter in the service mode : press total clear (yellow)key-107-clear(red)key,touch SP mode,open the front door and turn OFF the power switch.Unplugged the machine,wait 10 sec.,plugged the cords,close the front door amd turn ON the power switch.
Nov 21, 2009 | Ricoh Aficio 1035 Copier
Erro code SC541
Fuser error.
Fix problem (Fuse, lamp, or thermistor), then reset code by entering service mode and powering off/on machine
May 11, 2009 | Ricoh Aficio 450 Copier
At start-up printer codes out a sc541 turn off then on
It's a fuser error. Fuser may need replacing, and fuser codes can only be reset by a technician, to prevent further damage
Feb 26, 2009 | Ricoh Aficio CL7100 Printer
Solve my problum
I have a richo 2018d all in one copier machine it can be a error code SC541.
what is its solution ....
Sep 16, 2008 | Ricoh Aficio 2018D All-In-One Laser...
About ricoh copier problem
sc541 is a fusing unit error code. Can you reset the code in service mode?
Apr 22, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio 3025 All-In-One Laser Printer Logo
238 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
