Question about GE WBSR3140DW Top Load Washer
Washer will not fill before agitation
Cannot get washer to finish filling with water before the agitator begins.
The settings on water level may be set on very low amount. Check see your water level is set on medium or full. You may be expecting the wrong amount on the low setting.
Posted on Feb 18, 2008
Kenmore 700 series top loader washer. I put it on the normal cycle, the washer fills and agitates for a few minutes (maybe 5) then drains only to fill back up and finish the cycle. Is this normal?
no
some cycle the agitator during the fill cycle to get better distribution of the clothes as it is filling and then shut of the water and proceed to the wash cycle
have a technician check out the program board
Jun 15, 2017 | Kenmore Washing Machines
My wahser just stopped working it filled with water and then started agitating and then all the sudden stopped please help
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    Agitator starts at begining of cycle before washer is full
    Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
    Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
    After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
    Quentin
    Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
    Won't finish the final spin
    It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
    Post further comments for more information ....
    Good Luck!!
    Thanks
    Aug 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Washer functions but doesn't fill with water, with
    if it agitates without water then the fill pressure switch is stuck , this will lead the unit to beleive its full already.
    replace the water level/fill switch for the fix.
    Phil
    Jun 10, 2009 | Washing Machines
    As washer was on final spin cycle it sounded like a belt came....
    • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
    Apr 01, 2009 | Kenmore Washing Machines
    Whirlpool washer fills, begins to agitate, then drains
    Water siphoning out the drain line
    If the water is continues to fill and water is draining while it is filling or agitating, Check the height of the stand pipe. It should be about 36" above the floor. If the height is correct it may need to have an anti-siphoning valve installed into the drain line.
    moz-screenshot.jpgThe washer fills and drains at the same time only on the rinse cycle.
    Shut the machine off with timer during this period and raise the drain hose. If the water continues to drain, you will need to install an anti-siphon kit.
    Please leave a solved rating before you sign out
    Jan 31, 2009 | Whirlpool LBR4121JQ Top Load Washer
    GE WBSR3140DW Top Load Washer Logo
    150 people viewed this question
    Top GE Washing Machines Experts
    Tim Whalen
    Marvin
    Marvin
    Are you a GE Washing Machine Expert? Answer questions, earn points and help others
