Question about SmartParts (1DPFSP01) Digital Picture Frame
Up loaded pictures the pictures displayed for fifteen min. then smoked and shut down
  • 12,061 Answers
I would think the Power Supply inside has burnt out.
Posted on Jan 31, 2010
Affinity washer door lock shuts off. I put a new door lock in and after 20 min it does it again.
Wait until the washer gets done, and then try unplugging the washer for fifteen minutes.
May 06, 2011 | Frigidaire Affinity ATF7000E Front Load...
My treadmill quits after about 5 min. The
Have you lubricated the the running deck? The lack of lubrication can increase friction thus causing the current over load circuit to activate thus shutting down the unit to prevent further damage, Go to your local hard ware store and purchase silicone spray. Apply Lubricant by lift one side of the running belt spray contents length wise starting at motor shroud to the back end repeat this process on the other side. If this unit shut down again then you will have replace the running belt and possibly the deck.
May 27, 2010 | Proform Exercise & Fitness
I have a gmc 3500 deisel,it starts and run great but out of no were it just shuts off.at stop ligyt or highway,doesn't matter.wait ten min. and it will start again,run for fifteen min. and die again.i...
check the camshaft and crankshaft sensors. If they get faulty (typical in GM cars) the PCM would shut down the engine. Happened the same problem to me and solved it by changing the crankshaft sensor.
Jan 24, 2010 | 1998 GMC Sierra
Reddy heater 55 runs about 5 mins the a puff of
This a classic occurance due to low fuel in the tank.
Jan 21, 2010 | Reddy Heater-30-55,000 BTU Variable
F-21 error means What?
F-21=LONG DRAIN If the drain time exceeds 8 minutes the water valves shut down. After 4 mins the Sd(slow drain) error will be displayed, 4 mins later the F/21 error code will be displayed.
Press PAUSE/CANCEL 2 times to clear display
Probable cause/Proceedure
Drain hose plugged/kinked
unplug washer/disconnect power
check electrical connections to pump
and make sure pump runs
check drain pump filter for strings,sand etc
plug in washer If this dont work
replace pump.
Dec 31, 2009 | Kenmore HE2 Plus Front Load Washer
Dell wont display welcome screen after boot for 15 min.
You must have turned off the Welcome screen. go into Dell help and search for Welcome and have it "Default".
Aug 24, 2009 | Computers & Internet
HL-S5687 DLp tv
your keeping a part that is warming up and shuts down your shutdown that protects the tv from burning up... cooler... to find this you might need a hair dryer or a can of freeze mist.
I believe the left side is your high-voltage section.
you can also let it warm-up without the fan .. let it shut down and feel parts with set unplugged to see what is running hot.
Oct 22, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
360 starts up for about fifteen seconds, then shuts down
If 3 red lights flash, you may have a problem. if not, then your xbox may just be overheated.
Sep 14, 2008 | Microsoft Xbox 360 Console
Duramax black smoke under meduim load and over heats
my twins 98 ford taurus has a problem. it started with the motor fan not shutting down it was shut off, then i shut down finally. they were driving to work this morning, when they got therethe car started smoking black smoke and throw all the water out. can this be a fuel pump
Jul 23, 2008 | Chevrolet 2500 Cars & Trucks
Green screen&no picture only sound
check the crt socket could be a bad solder
Oct 22, 2006 | Philips PR0935B Television
SmartParts (1DPFSP01) Digital Picture Frame Logo
250 people viewed this question
Top SmartParts Photography Experts
Joseph Hoffmann
Tony
Are you a SmartParts Photography Expert? Answer questions, earn points and help others
