Question about Frigidaire FRS26H5AS Side by Side Refrigerator
Button on front to select cubes or crushed is not functioning properly. we only get crushed ice regardless of button selection.
  • 65 Answers
Not saying it isnt but more often the solenoid that changes from crushed to cubed in the back wall of the freezer is the problem. Pull out the ice bin and examine the bottom of the bin itself. You will see a metal bar that sits underneath the bin to one side of it. This bar is moved to pull the ice away from the crusher blades or left down to be crushed in them. Follow the bar to the back wall where it goes into a square hole in the wall. This is the solenoid that pulls the bar up for cubed and crushed ice. There is a plactic hook in that square cutout that that bar is supposed to sit in. You may have pulled out the ice bin and when pushing it back in the bar managed to get under the hook. The hook is part #45C in this diagram http://www.searspartsdirect.com/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fR0302033-00008.png If you cant even see the plastic hook, stick your finger in the square hole and feel upwards towards the ceiling. You should be able to feel the hook and pull it down back into place. If it wont budge then the solenoid itself will have to be replaced. Hope this helps.
Posted on Jan 31, 2010
GE ice maker crushed ice selector does not work. It does work for cubes and water. Pushing the door button when cubes are selected causes the assembly in the back of freezer that moves a rod to open the...
Crushed ice makers have a tendency to freeze up the mechanism. So you might want to deinstall your ice maker and let it defrost for a day or two.
That would be where I started, but if that didn't fix the problem I would move on to the electronics/
May 06, 2012 | Refrigerators
The buttons that select water, crush or cube do not function. I can get crush or cubed ice but the water button does not work. I have tried turning off at the mains and starting again but still there is a...
remove the front cover off this selector panel(if equipped) and replace the interface board in behind here as the little switches are bad and theres no fix to these boards
Jul 02, 2011 | Admiral 26 cu. ft. Side-By-Side...
Crushed ice option don't work properly . samsung RS2530B
if it new call sears for service...with crushed ice the augar moter turn the other direction... it must not be turn the other way could be a switch in the control...
let me know for it help if NOT please let me know and I will be glad to do more in depth.
Sep 26, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Dispenses crushed ice and will not dispense ice cubes
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Aug 17, 2009 | Frigidaire FRS23H7CS Side by Side...
Admiral Fridge Freezer
We had thought this was a free service...??? Yes, we fixed it ourselves, after trial and error. We pulled out the ice bin and there is an arm that is moves back and forth beside it. It had frozen up. That is the ice crusher. Thaw it out and it is fixed. By the way, the above posting was not by us--ours stated that our ice crusher did not crush ice anymore. Instead, cubes came out...
Jul 12, 2008 | Admiral 26 cu. ft. Side-By-Side...
Ice & water control buttons
sound like a bad(shorted) dispenser user interface INTERFACE DISP ASM WR55X10415
Apr 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Icemaker only dispenses crushed ice, not cubes
There is an opening next to the auger that dispenses the ice.  In there there is a lever that must move up and down. It actually seats the metal rod on the bottom of the ice maker and controls cube or crushed.  Make sure the lever is down (cube position) when you return the basket to the freezer. I had to hold it down while I slid the rod into the opening. Viola! Cubes again. http://www.applianceblog.com/mainforums/showthread.php?t=783
check it out!  Thanks to Jake!
Apr 03, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire FRS26H5AS Side by Side Refrigerator Logo
178 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
