Question about BenQ Computers & Internet
Benq FP91G 19'' fades out
I have a Benq FP91G 19'' LCD
When i turn it on, it comes on very light, then fades out very quickly.
If someone can tell me what is wrong then i know if its worth getting it fixed
or maybe get a part to fix it.
Thanks
Peter
  • 2 more comments
  • lockie2 Jan 31, 2010
    Thanks for the reply
    I have pulled the monitor apart, found the board.
    There is a few capacitors on the board
    Can you tell me which capicitor i need changing please
    http://i49.tinypic.com/rmqlw6.jpg
  • lockie2 Feb 02, 2010
    As you can see from the image on my last reply the capacitors look fine
    no bulging, none of the tops look like anything is wrong.
    Will replacing all of them definitely fix the problem do you think?
  • 558 Answers
Capacitor problem on the power board internal solder fix is possible.
Posted on Jan 31, 2010
Testimonial: "Quick reply's, great help ....Thanks"
  • Scott Hill
    Scott Hill Feb 01, 2010
    the capacitors that are domed or have colored leakage will need to be replaced.
    please look here for images of damaged caps
    http://en.wikipedia.org/wiki/Capacitor_p...
  • Scott Hill
    Scott Hill Feb 02, 2010
    OK if there are no puffy caps then the problem is related to the transistors called MosFets. this is something that a service center will need to do the easiest thing at this point is to replace the power pack. I am sorry if this is not the answer you wanted to hear , however I am not going to lie to you .
    the MosFets supply power to the lamps, what is happening is that the MosFets are undervolting or Overvolting and the monitor is saving itself from a Fire situation. It is a soldering situation and it can be complicated so I have to advise to take in for service center or buy a power pack for it (e bay is cheap) or get a new monitor.
Need new adaptor for benQ FP951......because the old one broken....thx
A quick search on Google for "fp851 adapter" turned up several sources. Here's one listing from eBay, which is always a good place to check. If you're not in the US, you can check eBay listings in your area or find an online source that will ship to you. You shouldn't have much trouble locating a replacement.
Jun 02, 2011 | BenQ LCD Power Adapter for FP951 Monitor
My Benq FP93GX 19" LCD Monitor does not turn on,
It does the same attaching to another PC?
Otherwise it is more likely to have bad caps, that will be the first thing to check.
Basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 12, 2011 | BenQ FP93GX 19" LCD Monitor
Hi My Benq FP91G flickers with the auto syncing message around once every 60s. sometimes the power button does not work, i have to keep pressing it before it will eventually switch on. Is this worth...
Its worth fixing...
Its just an issue with the board.
If it happens to be the LCD panel, rather not fix it since its gonna cost u a fortune.
Oct 11, 2010 | BenQ FP91G+ Monitor
Can't get monitor to turn on
Dell has the same problem as BenQ since BenQ makes the monitor for Dell and HP. Please look through the Dell albums so you will know what to look for inside, bad transistors, caps, solder joints.
http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Apr 25, 2010 | BenQ FP91G+ 19" LCD Monitor
BenQ FP91G+ Problem
Hi...there,
Dies on 1 seconds usually caused by busted backlight inverter or AC Adapter if you got one on your monitor.
Nov 21, 2008 | BenQ FP91G+ 19" LCD Monitor
Blank LCD screen
The description "comes on very faint" is indicative that the backlight is not turning on. The backlight as the name implies provide the illumination of the rear panel of the LCD display. It is made on 1 or more CCF Lamps (cold cathode florescent lamps) and are powered by an inverter that provides the high frequency high voltage needed for the CCF lamps to work. Since the entire screen is dark and it is highly unlikely that both or all the lamps would go out at the same time, it would highly be likely that the inverter is the culprit being the common denominator to all the lamps.
Should you venture to perform a DIY (do-it-yourself) (with the necessary precautions and safety in mind), look for a board that would have small transformers and have connectors that leads to the CCFLs. They often go bad because of dried up/blistered capacitors, cold solder or a general failure in the electronics.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 02, 2008 | BenQ FP91G (Black, Silver) 19 inch LCD...
Small text and Icons
sir
sheza
i think you r installed any lan card ar etc. when you had taken com thing from the shop he will geve garenti for minimum one weak. for each component they geve a instaltion cd please instal. and see the system requiredments and proseed to ti ok
Mar 25, 2008 | BenQ FP91G+ 19" LCD Monitor
Fp91e
Problem with Inverter circuit.
Check with BenQ They offer a 3 year warranty.
Samir
Jan 19, 2008 | BenQ FP91ESIL (Black) (Silver, Black) 19"...
Benq LCD monitor
I had same problem. No Power at the monitor. what can I do?
Jan 03, 2008 | BenQ T705 17" LCD Monitor
Computers & Internet Logo
1,072 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
