Question about Memorex MT0500 5 in. Portable Television
What current draw is expected when using an AC adaptor please? Forde
  • Memorex Master
  • 12,061 Answers
Well for a TV such as this about an Amp or so, like 2 Amps would be too much suggesting a fault.
Posted on Jan 31, 2010
Is this product safe to use with the raspberry pi? I cannot find any answers elsewhere. More specifically the product is USB 2.0 4-Hub with Power Adaptor, NEXXTECH, MODEL NO.: N4PUDH
If you haven't found your answer yet...I would expect that this hub would be fine. In general, you are better to use a powered hub with the Pi as it takes a lot of the current draw necessary away from the Pi and powers it directly from the Hub. This is especially useful if you have any high power devices plugged into the Pi's USB ports, such as external hard drives.
Hope this helps.
- Flub
Mar 24, 2015 | Computers & Internet
Why the rpm of toyota corolla 1994 model goes down when aircon is turned on
Because aircon uses a lot of power, it causes the revs to drop and the car to use more fuel. Just a fact of life. If you don't NEED to use the aircon - don't use it. And if you do need to use it, expect expenses to rise.
Dec 07, 2013 | 1994 Toyota Corolla
I have just bought my husband a CD Walkman D-EJ011. The package says that I should buy only power adaptor AC-E45A to go with this model but I can't find anyone in UK who stocks it. He doesn't...
I just had a quick look on the internet. There are many available on Ebay. It appears that it is a Sony product. You may be able to purchase one direct from a Sony Agent or from E Bay. Type in AC-E45A and you will find them.
cheers
Dec 27, 2017 | Sony ACE45A Worldwide AC Power Adapter AC...
My church has a roof top ac unit, model # GP-1360H41BA. The ratings plate has the following ratings: RLA 26.4 AND LRA 134. What is the KW draw of this unit 1. At startup 2. After startup?
RLA ( rate load amps/current) is the rate of unit ( usually about 65% against Max. load current < FLA/FLC>)
LRA ( Locked rotor amp/current)
Seems your AC use Y or Delta starter, so at start the current draws will between : 3X ( 26.4 to (26.4(1 +35%). And After start up the current draws will drop to 26.4 to 26.4(1+ 35%) in normal operation.
Remember, that the current draws also depending to the condition of your ac.
Nov 03, 2010 | Goodman Heating & Cooling
Mine now eats batteries and needs at least 4.5 volt mains adaptor to power up. It was connected to a 9 volt adaptor at one stage.
Try this link:http://www.rolandus.com/products/productdetails.php?ProductId=818 Note the info under Power Supply,Current Draw and Expected Battery Life. Compare the specs to the results you are getting. Note that "The time may vary according to usage conditions, batteries used and type of SD memory card used." Here is a link to their support:http://www.rolandus.com/products/productdetails.php?ProductId=818&tab=downloads&skip=true If you didn't use the exact adapter recommended you may have damaged the circuitry and will have to have it serviced. It is definitely not something you can do yourself unless you have equipment to work on surface mount technology. The required adapter is listed in the info at the first link.
Mar 03, 2010 | Boss Micro BR Digital Recorder
SONY PCG-9L1M power adaptor
In general (with adaptors), go for the one with the higher amps. The amp rating is the maximum current draw that the adaptor can provide. If the current isn't required, it isn't used (think of it as a comparing a car that can do 200 to a car that can do 150 - both of them can do 100 or 150).
Oct 27, 2009 | Computers & Internet
Ac adaptor on my 32 Protron inch LCD TV no longer work
What is the current output of the adaptor? If it is AC and you use only the 12v to 3v it is ok. But if the current output of the adaptor is DC and you use both 24v to 6v and 12v to 3v there is some danger if use the new one. Remember that DC current have polarity.
Aug 29, 2009 | Protron PLTV-32 Television
I bought a targus ac adapter, it worked the first time I charged my Dell 5100 Notebook computor, now a message comes up saying it doesn't recognize the ac adaptor, how can I fix this?
AC adaptor may not be correct. Check label on AC adaptor with label on notebook for voltage (e.g. 19.5V or 20V) and current (e.g. ??A or 90W)
Voltage must be same and current must be same or higher on ac adaptor.
Aug 09, 2008 | Computers & Internet
AC adaptors replacements
You will not have any Problem What so ever.
18V is operating Voltage,
0.7A is Max of Current it (Power Adapter) is providing.
The Load (AR) is operating (Uses Current) between 0~0.7A (Even Less)
Therefore 1A Adapter is actually safer to use.
Think as, your electric company supplies 100A Service,
and you have only AC is running at 10A.
May 21, 2008 | Audio Players & Recorders
NOT TURNING ON LATOP ACER ASPIRE 1410
ya im having the same problem. please help!
Jan 20, 2008 | Acer Aspire 5100 Notebook
Memorex MT0500 5 in. Portable Television Logo
43 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
