Question about Microsoft Windows Server Standard 2003 for PC
IIS in winxp
I can't run IIS without Permission administrator
Are you registered in Administrative groups as an administrator for the PC? If not, you can go to Administrator Tools in Control Pannel and change in include youruser name in the Computer Administrator group, that wayit will allow you to installand change confugurations.
Posted on Feb 18, 2008
How to set up a FTP server in Windows 7
You can use MS products (FTP Service and IIS Management Console) or a third party software (FileZilla.)
To use MS, you have to enable FTP under "Add Features" in Programs and IIS service.
Then you have to configure IIS:
  1. Run Administrative Tools -> Internet Information Services (IIS) Manager
  2. Expand the local machine
  3. Right-click "Sites" and add "FTP Site"
  4. Call it "Default FTP Site" and create the path like "C:\inetpub\ftproot"
  5. click "Next"
  6. Enable Start FTP site automatically, select Allow SSL
  7. click "Next"
  8. Enable Anonymous Authentication
  9. click "Finish"
Oct 15, 2015 | Computers & Internet
Tip
How to back up IIS 6
<p>Internet Information Services IIS 6, a web server application that allows you as administrator, the settings for the Exchange server organization. Part because of its importance, it is imperative that you back up the metabase of IIS 6. IIS 6 Backup helps you to recover lost data on a server crash. You must have administrative rights and permissions for this task. <br /> <p><br /> <p>1. Click the Start menu, select Administrative Tools and click Internet Information Services (IIS) Manager. <br /> <p><br /> <p>2. Right-click the name of the server or computer. <br /> <p><br /> <p>3. Move the mouse to "All Tasks". Select "Backup / Restore Configuration." <br /> <p><br /> <p>4. Click "Create Backup". <br /> <p><br /> <p>5. Enter a name for the backup to the backup configuration name. "Check the Encrypt backup using password" if you want to password protect the backup and then type the password for the backup to confirm. <br /> <p><br /> <p>6. Click "OK" to back up the IIS 6 <br />
on Jun 22, 2011 | Computers & Internet
Administrator login
Have you tried logging in at localpc\Administrator with blank password?
Dec 26, 2013 | HP Computers & Internet
I tried to change permissions on my hard drive and now I am unable to have access to anything other than just opening programs and folders.
Enable the administrator account, login as administrator and select your regular users folder and assign your regular user as owner.
Enable admin Open a cmd prompt, run as adminif in win vista/7 type without quotes "net use administrator /active:yes" Log out of current user and login as administrator
Now you should have permission to set permissions to your other users folder. Set ownership to originsl user.
Comment if you get stuck or need more help
Aug 05, 2011 | Acer Aspire 5050-3242 Notebook
How to Install IE8 in WinXp Without Administrator Access
If someone has turned off software installation permission using an admin password there is no simple way to defeat that permission. Depending on how the permission was set, either from a server that you log into, or on the local machine itself, you might be able to take the hard drive out of that PC and then install it onto a computer that is not limited by that permission. You would then install your IE8, and then re-install the hard drive back into your PC. The only catch might be that your system may also be limited against running IE8 as well.
The other trick that might work is getting a disk version of the Linux Knoppix program. You would have to boot your PC to the Knoppix install, and then use it to break the Admin Access permission. There are several issues with this hack. Your PC would need to have permission to boot from a floppy or a CD/DVD drive, and chances are that permission has been turned off as well. Any admin who has at least a couple of years experience knows about the Knoppix hack, and will have taken steps to ensure no one would be able to use it. You might unfortunately be stuck with whatever browser you are currently using.
Thank you for the opportunity to assist you in resolving your issue. Should you need further information or assistance please do not hesitate to let us know.
Feb 17, 2011 | Computers & Internet
SixEngine.exe and TurboVHelp.exe are blinking under win7 user in the bottom task bar. No problem under administrator. I can get rid of the blinking by clicking on the twobuttons and adding the admin...
SixEngine needed permission too though not TurboV. So, though I found out how to run it as admin, it's useless so I just uninstalled it.
1) http://www.sevenforums.com/tutorials/11949-elevated-program-shortcut-without-uac-prompt-create.html
2) http://www.sevenforums.com/tutorials/11841-run-administrator.html
I wouldn't want turboV to run without prompt: so anyone could adjust system voltages. If this is what turboV does, no way, and mine sadly doesn't need permission to run. Fortunately, I am the only user.
Nov 07, 2010 | ASUS P7P55DE Pro Motherboard
Conflicting User profiles when using Internet Explorer in WinXP
This is because the other user must have been the administrator. Administrative user can control the settings of other user. He must give permission to the other user which is given by default. But if its not, then options will be very limited to the other user. Access to surf the net and other access options can be given through the administrator.
~regards,
Jegan
Jun 03, 2009 | Microsoft Internet Explorer 6
I can't open the Lumix Simple Viewer program.
You are probably running Windows Vista, you will need to log in as the administrator on your machine. If you google "How do I become the administrator on my vista system" you will find several solutions to this problem. :)
Nov 26, 2008 | Panasonic Lumix DMC-FZ18K Digital Camera
Message Sending from windows 2003 server
GO TO YOUR EXPRESS AND REPLY ALL. MAILS TO EVERYONE IN YOUR BOOK.
Jan 21, 2008 | Microsoft Windows Server Standard 2003 for...
Microsoft Windows Server Standard 2003 for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
