If you replaced an ink cartridge while Near Empty was displayed on the LCD, the LCD may ask you to verify that it was a brand new one. Example: Did You Change Blck? 1.Yes 2.No. For each new cartridge you installed, press 1 on the dial pad to automatically reset the ink dot counter for that color. If the ink cartridge you installed is not a brand new one, please be sure to select 2. WARNING If ink gets in your eyes, irrigate them with water immediately and call a doctor if you are concerned. If you wait until Ink Empty message is displayed on the LCD, the machine will automatically reset the ink dot counter. If the Install message is on the display after you have installed ink cartridges, check that the ink cartridges are installed properly.
Lift the scanner cover from the right-hand side of the MFC until it locks securely into the open position.
If one or more ink cartridges are empty, for example Black, the LCD shows Ink Empty Black and Cover is Open.
Pull the ink cartridge hook toward you and remove the ink cartridge for the color shown on the LCD.
Open the new ink cartridge bag for the color shown on the LCD, and then take out the ink cartridge.
Remove the cartridge covers.
Each color has its own correct position. Keep the ink cartridge in an upright position when you insert it into slot. Press down on the ink cartridge until the hook snaps over it.
Lift the scanner cover to release the lock. Gently push the scanner cover support down and close the scanner cover.
If you wait until Ink Empty message is displayed on the LCD, the MFC will automatically reset the ink dot counter.
yes you need to install all cartridge before printing any page ...I have also this model...but u need to install all 4 cartdge. before printing any page wheather color or blacknwhite..
you need to follow the whole procedure on your to ensure proper installation as soon as you install the new one, follow the instruction on the screen to calibrate your new ink
Even with out the Black cartridge installed the X1240 should use the color cart to make a "composite" black. I would suggest calling Technical support to troubleshoot that issue ad get you to test the cart itself
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
