My projection TV keeps turning itself off. What could be the cause for this
  • 12,061 Answers
It seems that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
Remember there are leathl Voltages inside TV's, and generally these days don't contain any "User Servicable parts" like in the "Old" days, instead Board Replacment is all that is generally done.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Posted on Jan 31, 2010
My 2004 rca hdtv keeps turning itself off when i turn it on
I do wish i had more but one thing that will cause a problem like this is spraying air freshener or spray cleaners where the spray can get inside the back of the TV. It will also cause it to pop. Hope its this easy to fix for you, good luck.
spray the cleaning rag then wipe TV clean.
Jun 25, 2014 | RCA D52W20 52" Rear Projection HDTV-Ready...
Why does my tv keep turning itself off
The tv projection lamp,might require replacing?Tv projection lamp inside this tv like 1 1/2 or 2 years already and tv daily used,like 4 or 5 hrs viewing of the tv?Yes,than projection lamp is the problems and the causes.The tv projection lamp require replacing.
Feb 25, 2011 | Panasonic PT-50LC13 50" Rear Projection...
Our Mitsubishi rear projection TV model VS-60707 keeps turning itself off. it is like it overheated cuz it comes back on after about 15 to 30 minutes being off, it comes back on by itself.
Called a repair man, he adjusted the convergence, with a remote for Mitsubishi. (I lost mine years ago). He thinks that is what was causing the TV to turn off. Time will tell if that cured it.
Dec 07, 2009 | Mitsubishi Televison & Video
My tv keeps shutting itself off automatically and the temp light keeps flashing.
this is a job for a service tech, because you are having problems with what it seems to be thermal shutdown. please refrain from turning it on you could cause further problems to set.
Nov 06, 2009 | Hitachi 42V710 42" Rear Projection HDTV
My TV shuts itself down by itself
Poer supply is the cause of the shutdown and would need to be replaced. These cost around $150 bucks just in parts the labor you would need to find someone that knows just what there doing or you could wind up into the hundreds, Thanks
May 25, 2009 | Mitsubishi VS-6055 60" Rear Projection...
Keeps turning off by itself after about 30 minutes
Is your air intake clean or clogged.. Maybe it's overheating causing it to shut off.. Had the same problem didn't replace the bulb but cleaned the intake and it works great again. Worth a try.. Intake is located on the left back pannel of the tv.. outside pannel pops off easly.
Apr 27, 2009 | Toshiba 42HM66 42" Projection HDTV
The TV turns on and off after a few seconds and repeats itself.
There could be quite a few things that would cause the set not to power up. I dont have the service manual, however you can get a copy of the service manual at the following link for your model. As thats the only proper way to be able to check for the proper voltages to determine whats wrong with the set.
Heres the link.
http://servicemanuals.vstore.ca/
Nov 26, 2008 | Samsung HCL652W 65" Rear Projection...
Sony TV keeps shutting down ever 5 mins
Could be loose connections on the board where the solder is expanding as it heats up causing a loose connection or something in the power supply or horizontal is over heating and your tv is going into shutdown protection . Good luck
Mar 03, 2008 | Televison & Video
Televison & Video Logo
358 people viewed this question
Top Televison & Video Experts
