Question about Jandy AQUALINK RS TELELINK KIT
Bought a house w/ a hot tub-no idea what brand. Filled it up, turned the breaker box that's outside on but can't get it to come on at all.
  • 122 Answers
There should be another breaker for it in the main panel. 10 to 1 it's double 40 GFCI. Try that.
Hope it helps!
Posted on Feb 02, 2010
Hot Tub won't Turn On.
First check the breaker box for the house and see if it has power.
Jun 26, 2015 | Home
We bought a house with an Aqua Glass jetted tub. When we tried to turn it on nothing happens. At our inspection in July it was working fine. There is no way to get in to the front of the tub and no box. ...
Get the manual and study how it works. Then with this new knowledge you will have a good idea of just what to look for.
Is power reaching the unit? ON/off switch good? Circuit breaker? Is water reaching the unit/valve shut off?
It has to be something simple.
Sep 09, 2017 | Pool & Spa
Why is my 50 amp GFIC breaker tripping out? I have just installed a new hot tube.I had one there before(smaller 40 amp) so there was already #8 wire there.The new hot tub requires a 50 amp. #6 wire. I just...
There might be a few things here:
1) Big problem >> the #8 wire is a fire hazard connected to a 50Amp breaker
#8 is a 40 amp breaker
#6 is a 55 amp breaker
We put #6 on a 60 amp breaker
Are you saying you hooked the #8 wire to the new 50 amp breaker, and the hot tub called for #6 wire?
Upsize your wire and breaker to meet code
http://waterheatertimer.org/pdf/Wire-size-amp-rating.pdf
2) After putting the correct wire and breaker, you can still have a short in the circuit somewhere
We used to set equipment out in the field in early morning >> the grass was wet >> our equipment was fine, but the tiniest short would cause the GFCI to trip
I don't know where the problem is without a thorough checkout of every possible grounded surface. You need a good multi-meter
3) You better get an electrician over there to have a look before the place burns down or somebody wakes up dead in the hot water.
If I sound a bit scary here, it's because something doesn't sound right with your installation.
Oct 19, 2010 | Inline 60 Amp Circuit Breaker
My electric went out for 24 hours. I hooked up my generator to the breaker box to power the house. The generator only powers one 110 leg so there would have been 110 going to oneside of the 220 breaker to...
You should start with checking all your breakers to be sure the breaker did not pop just half of your breaker. This is something you should do with all your breakers. When you do this you should shut down all your 220v breakers so you don't get bleed back through the system. Other than that you need to look for resets on the tub. The heater is a good place to start and don't forget the gfci's on the tub or in the bath or laundry room.
Dec 13, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
240 w/60 a outside breaker with test switch wont'
Inside the controller box is a red button to reset it but most likely the heater element is shorted out so replace the heater element first. Cost $100.00 at any pool or spa shop. Post here if you need more help.
Sep 28, 2009 | Siemens 12 Q115u 15a Circuit Breaker, Qp
How to turn on hot tub
Check at the plug in if it has a normal plug like in your home first. Should be a set of buttons there, called a GFI. One is test, and the other reset.Push reset to see if spa comes on. Most spas dont have an actual on button. Check breaker box for popped breaker also, maybe tub is having problems, and needs a service call. Also larger tubs ussually jave a gfi or fuse box outside, close to tub. Kirk
Dec 01, 2008 | Pool & Spa
Jandy AQUALINK RS TELELINK KIT  Logo
60 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Bill Jordan
Ian Kime
Ian Kime
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
