Question about Canon ImageRUNNER 1670F Copier
I need an manual for a 1670f it will not take paper in auto feeder
  • Canon Master
  • 12,061 Answers
Posted on Jan 31, 2010
Testimonial: "Thank you for getting back to me so quickly, although there is no information available on line. "
Copying 8.5x8.5 original thru document feeder and it doesnt aal print
Most copier has an APS (Auto Paper Selection) as default, 8.5 x8.5 is a square original, I would suggest you manually select the paper tray (e.g. Letter) first (this will temporary disable the APS for this session), then lay it down on the original glass, or ADF (Auto Document Feeder).
If you do not disable APS, you will have paper jamming problem, you do not have 8.5 x8.5 is th paper tray, of course, you may try it feed from the by-pass tray, set the the paper size to 8.5 x8.5 or special size ....... Each manufacturer has a different name for the same function (terminology).
Nov 12, 2013 | Canon for IMAGERUNNER C2020 C2050 C2058...
Paper transport works not properly, 3 flashes orange LED
First make sure the printers well connected and the power supply properly plugged.
  • Remove any previously loaded paper.
  • Check out the printers Auto sheet feeder/front feeder for any paper jams and remove manually any visible stuck papers.
  • Turn the printer off and on.This also helps in automatically removing any stuck papers that may not be manually removed.
  • Make sure there is no foreign objects in the Auto sheet feeder.
  • Make sure you load a fair amount of plain papers in the feeder,that is,reduce by half the amount you feed into the feeder.
  • In case the printers rear cover had been removed,fit it properly by pressing it firmly until it fully fits into the rear of the printer.
Hope this helps.Thanks!
Please rate this answer.
Oct 26, 2011 | Canon PIXMA iP3300 InkJet Photo Printer
The printer keeps telling me it's out of paper, which it isn't
1> Open the sheet feeder cover and pull out the paper support.
Set paper, aligning the right edge of the paper to the cover guide with the paper's print side facing up.
Pinch and slide the paper guide to the paper's left side.
Note: Make sure to set paper lengthwise. Setting Credit Card sized paper long-side down by mistake may cause a paper jam.
Pull down the paper output tray supporting with both hands.
Pull out the extension completely.
Ensure that the Power lamp and the Auto Sheet Feeder lamp light.
Note: If the Cassette lamp lights, press the Paper Feed switch to light the Auto Sheet Feeder lamp.
If the Auto Sheet Feeder lamp does not light even after pressing the Paper Feed switch, Paper Source in the printer driver may be set to the setting other than Paper Feed Switch.
Nov 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Load mp feeder with a4
find the switch and turn it to auto paper in the printer settings, mp is for manual paper feed ap is probally for auto paper feed, its a guess . hope it helps
Dec 01, 2009 | Lexmark Office Equipment & Supplies
Copy paper feeder alignment
You need to call a Service Technician, You need to do a Registration adjustment and A Service Tech who is Brother authorized will know how to do it ?
Your registration is off.
Mar 04, 2009 | Brother MFC 7420 All-In-One Laser Printer
Canon D860 - I get a solid black line when I use paper feeder.
I'm pretty sure you might have solved this problem already, but this might help others.
Make sure that the platen glass is clean near the right side of the machine, where the document is scanned when going through the document scanner. Remember, when placing a document on the glass to copy it that way, you would place it on the glass on the left side of the machine. When scanning through the ADF, the scanning unit itself moves to the right side of glass and scans the document as it moves through.
We had the same issue and found out that there was a little spec of dirt on the glass. After cleaning it, the problem was solved.
Feb 03, 2009 | Canon ImageRUNNER 1670F Copier
Not feeding
Have you still getting the problem, have you done cleaning of Cartridge, its nozzle and Contact strip.. then cleaning of Printer roller or carriage rack.. Do a Service of it or get it done by Technician.
Also check the feeder tray.. to grab paper one by one by printer.. Manually
Take all updates for printer and OS.
Oct 31, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
XE90FX Auto Feeder not detecting paper?
If you go to this site, you will need to download MULTIPART zip/rar files.  The ones that you are looking for are XE_Cover and XE_Chapter1.  When you click on XE_Chapter1, pay attention to the Multipart section.  There are at LEAST 13 files that you will have to download to get the whole manual.
http://www.eserviceinfo.com/equipment_mfg/Xerox_22.html
Oct 28, 2007 | Xerox WorkCentre XE90FX Laser Printer
Auto feeder misalignment
Are you sure you don't have a static problem locking the paper to the glass.
Mar 29, 2007 | Sharp AL 1631 Copier
Canon ImageRUNNER 1670F Copier Logo
192 people viewed this question
old marine
old marine
