Question about Soltek SL-86SPE2 Motherboard
SL-86SPE-L Motherboard manual and / or bios jumper settings required.
Require a manual for bios and jumper settings for a CPU upgrade to a 3.0 gig prescott..
Bios is currently version 1.5, (ver 1.4 and above supposedly supports prescott CPU's up to 3.0 gig according to there bios blurb)
Just need to know what settings are required to get the CPU to boot.
Thanks
  • Anonymous Mar 21, 2014
    Jumper settings for phoenix bios d686
  • 56 Answers
Load fail safe defaults from CMOS/ deseabled the CMOS.
OR press F5 when booting & continue.
Posted on Feb 18, 2008
Asus f3j bios mod for upgraded ram
Not sure what you are asking about. Asus site says the motherboard will take DDR2 533/667MHz SDRAM, 2x SO-DIMM socket expandable to 2GB
Which means DDR2 533mhz 1 gig per slot total 2gig
or DDR2 667mhz 1 gig per slot total 2 gig
To enter BIOs press F2 at boot up, but no setting should need to be changed.
They do not have a BIOs update for increasing the memory limits.
BIOs upgrades from first to current are.
BIOS 304
Update new CPU Microcode
System plays wave file and causes garbage sound.
BIOS 305
To fix system cannot do battery pre-charge process when an unknown/failure battery insert.
Support Intel Extend ID CPU:Merom Celeron 530 CPU.
BIOS 306
BIOS 307
Fix System hang at ASUS LOGO on SATA HDD with factory recovery image
Last upgrade date is 2008 7 14
Mar 14, 2014 | ASUS F3Jc Notebook
Don't reset password BIOS HP DC7100
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard.
Open the CPU casing locate the CMOS battery in motherboard and remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
On some motherboards, the battery is soldered to the motherboard, making it difficult to remove. If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password. If you have the motherboard documentation, you will know where that jumper is. If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper.
This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
If all else fails, you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard.
Many RTC's require an external battery. If your RTC is one of this type, you can clear the BIOS password just by unsocketing the RTC and reseating it. Good luck!
Oct 04, 2009 | Computers & Internet
ECS P4IBMS Motherboard CPU Voltage Jumper Settings
I don't believe that there is a P4 motherboard that needs jumper setting to specify the CPU voltage. This used to be common for Pentium & Pentium II motherboards, & some Pentium III motherboards. But I have never seen a Pentium 4 motherboard that require this kind of setting.
Besides, I checked the motherboard's manual & I saw that there is a sub-menu in BIOS labelled "Frequency/Voltage Control". This should be the place where the CPU voltage should be set, & on most motherboards, CPU voltage & frequency are automatically detected.
Jun 20, 2009 | EliteGroup ECS P4IBMS Socket 478pins...
Got a soltek sl-k8av2 rl upgrading RAM
The motherboard takes DDR 400 ram so make sure you dont put anything higher than this in.
At present i am using 2 x 512MB DIMM's, but am unsure if it will take 2 x 1024MB DIMM's. If it does, it may require a BIOS update (1.6 is the latest but 1.5 is readily available through a google search).
When you get the beep, are you still able to get into the BIOS? It might be worth checking what speed the RAM is set to. It should default to AUTO. If you need to clear your BIOS then look closely at the motherboard for JMPR1/JMP1/CLRCMOS in small white writing on the PCB.
Good luck :]
Jan 14, 2009 | Soltek SL-K8AV2-RL Motherboard
CMOS checksum bad 0085
the problem might lie in the fact that the mother board and cpu cannot be handled at the speed
or it requires the jumpers to be set by so that the cpu can be clocked properly if you got a mother board spec guide follow the guide for *********** board to set up 3.2
you might also have to set the bios to the cpu speed cause if mother board doesnt do jumpers no more the setting would be in bios
hit the delete key direct are power up this will take you to bios
its not the battery
Jun 05, 2008 | Intel Motherboard
Soltek SL-86SPE-L CPU upgrade issues
Maximum you may go upto 2.4 GHZ. [p4]. Not dula core etc.
Best Regards
Rafique
Feb 17, 2008 | Soltek SL-86SPE2 Motherboard
This took ages to find... and EVEN LONGER to download, it felt like I was on pre-pre-pre-pre-56kbps era.
Anyway, without further ado:
Soltek SL-86SPE/SL-86SPE-L BIOS AM1.5L. Included:
  • Flashing App
  • How to
  • ROM file
86SPE-L15.zip
Hope it helps. Rate me. Thanks.
.:: Cyberneticus ::.
Soltek SL-86SPE-L and 512MB 400MHz memory cards
If I could find your manual, I would bet that your memory should be CL2 or a max of CL2.5 which is the core voltage of the memory.
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=80098-21
A lot of places do not show the CAS or CL voltage, rather they make you look for it. Thats just wrong.
Jan 16, 2008 | Soltek SL-86SPE2 Motherboard
CPU Upgrade
Athlon XP 3000+ is 400mhz FSB according to the link(http://www.amd.com/us-en/Processors/ProductInformation/0,,30_118_1274_3734^11672,00.html), means that in order to display the actual speed of your Athlon XP 3000+ you have to set your board 166mhz to 200mhz jumper setting or in CMOS utility overclocking option. and also just to inform you that your motherboard is in Overclocked condition when set, because it only supports processors up to 333mhz FSB (http://www.digital-daily.com/motherboard/soltek-sl75frv/)
Sep 11, 2007 | Soltek SL-75FRV Motherboard
Soltek SL-86SPE2 Motherboard Logo
888 people viewed this question
Top Soltek Computers & Internet Experts
John Anderson
John Anderson
Steven Wander
Steven Wander
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Soltek Computer and Internet Expert? Answer questions, earn points and help others
