Question about LG DLE3733 Electric Dryer
My LG dryer has stopped heating. Still runs, no
My LG dryer has stopped heating. Still runs, no heat. This happened once before while under warranty, the technician told my husband it was a fuse of some type. An overload fuse. Where would this be?
bestdarngood
  • 3037 Answers
SOURCE: LG DLE7177 - Doesn't heat
If you scroll over the top right picture on the following link you can find the thermal switch that you speak of. Please let me know if you have any further questions, thanks
http://www.repairclinic.com/0100_15.asp
Posted on May 02, 2008
Illeagle
  • 525 Answers
SOURCE: LG Front loader Electric Dryer want heat but will run and spin
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
This link will show teardown illustrations: Parts and more help available on other pages of the website.
http://www.repairclinic.com/0100_16.asp
Hope this helps.
Illeagle
Posted on Aug 27, 2008
MNTECH
  • 1543 Answers
SOURCE: front load gas dryer lg model dlg 5988w does not heat
This can obviously be several things, but I would first check the small safety thermostat. On the gas models, there is a small pin sticking out of it which can be pushed back in to reset it. It is located on the heater housing and is only about the size of a dime, with two wires on it. This will trip out easily if your vent was not clean, or is long or restricted in some ways (like using flex ducting)
If you need more help getting to it, let me know and I'll give you more instructions.
Posted on Dec 22, 2008
SOURCE: Runs but no heat
I WOULD LIKE TO KNOW WHERE THE RESET BOTTOM ON A (LG-GAS 7.0 DRYER)
Posted on Mar 06, 2009
SOURCE: LG DLE5932W electric dryer has no heat but is running.
Heating element is bad
Posted on May 04, 2009
May 02, 2008 | LG DLE7177 Dryer
Maytag gas dryer flame comes on but will not stay on
Your ignition unit may be worn out and will need to be replaced. Generally, a heating element comes on and once it reaches a certain temperature, it ignites the gas pilot. Then the heating element cools off because the gas is now burning and producing heat. When this heating element stops working correctly, it will not reach the right temperature to ignite the gas. You'll need to have a professional perform the repair. If the dryer is still under warranty, this might be covered.
We had ours replaced several years ago by a reasonably priced repairman. It bought us another 8 hears on our dryer!
Jul 27, 2011 | Dryers
I have an LG front load dryer and it has stopped heating. Do you have any suggestions?
Because you have a gas dryer, your problem is probably caused by the ingition panel.Generally, with a gas dryer, there is an ignition device that heats to a specific temperature and this causes the gas to ignite. When this electric ignition fails to work, the gas will not ignite and there will be no heat. I had this happen and had to call a professional. It was a simple matter of installing a new ignition device and it worked perfectly for years. I hope this helps! If it is a new dryer, check to see if this part might be covered under warranty.If this helps solve your problem, please come back to Fixya and rate my advice.
Jul 26, 2011 | LG DLG5988 Gas Dryer
Gas dryer kenmore elite runs but won't heat
Check your owner's manual.
I really hope this solves your problem. If it does, please come back to Fixya and rate my advice!
Jul 16, 2011 | Dryers
Dryer is running but doesnt seem to be heating it takes a long time to dry and the clothes are not warm when pulled out
Jul 16, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Gas dryer won't heat
Check your owner's manual!
Nov 11, 2010 | LG DLG7188 Gas Dryer
Dryer does not heat up/ dry clothes
sound like heater or stat call them out.
Sep 28, 2009 | LG DLE7177 Dryer
LG Gas dryer will not keep heating
sounds like the heat sensor on side of heater pan is bad and needs to be replaced ,,, its mounted on side of pan the flame blows into and has 2 wires plugged onto it / larry
Dec 12, 2008 | LG DLG5932W Gas Dryer
Runs but no heat
Jul 30, 2008 | LG DLG5932W Gas Dryer
LG DLE3733 Electric Dryer Logo
126 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
