DC-D37U UNIT IS COMPLETELY NO POWER...
    Problem Solver:
  • 9 Answers
Pls Check d cable if there is any broken wires or check the fuse on your audio shelf system
Posted on Feb 19, 2008
  • 56 Answers
Check the fuse but your main transformator primary side is worn out
The lens aperture does not open/close completely? What can I do?
open the cam take out the lens, open it carefully takeout the aperture unit remove the cables solder, check the aperture control with a 2 volt DC power, if it is struck manually open an shut, if not working with DC power it means faulty, change the lens unit.
Sep 18, 2015 | FUJIFILM FinePix F500EXR Digital Camera
LG SPLIT SYSTEM AIR CONDITIONER INDOOR UNIT WILL NOT POWER UP
as described the voltage you are seeing is fake. if there is no led lighting in the indoor unit check the small transformer in the indoor unit you should get 12V DC or 24V DC out from it
Feb 10, 2014 | LG Heating & Cooling
Can my daozd1mb6go motherboard work with out the capacitor pc 90?
No! you will cause more damage in the long run even if you successfully restart it, replace the part before you attempt it.
May 06, 2012 | Acer Aspire 5920-6423 Notebook
Power coverter to scanner failure.which unit should i buy? present one 240v 50/60hz.0.4A. output 12v.dc.i.25A
I just found my Canon 5000F scanner to have a power supply outputting 3V DC instead of 12V DC. I replaced it with a 12V DC Power Supply from Tandy rated at 1.5 amps. I had the scans getting darker by the day and sometimes completely black. Now I have great scans again. Just test the voltage at the plug that supplies the scanner for a healthy 12V DC with a multimeter.
Jan 20, 2010 | Canon CanoScan 5000F Flatbed Scanner
E-000003-0000
During printing, the main thermistor detects less than 120°C/248°F for 1
sec or more continuously.
Main cause:
The fixing film unit is faulty (main thermistor fault, thermal fuse blow, fix-
ing heater fault).
Or the power supply PCB is faulty.
Or the DC controller PCB is faulty.
Action1.
Malfunction
Turn off the power; wait for 10 min, and turn on the power. Is the problem
corrected?
YES:End.
2.Wiring
Is the wiring from the DC controller PCB to the fixing film unit normal?
NO:Correct the wiring.
3.Fixing film unit
Try replacing the fixing film unit.
Is the problem corrected?
YES:End.
4.Power supply PCB, DC controller PCB
Try replacing the power supply PCB. Is the problem corrected?
YES:End.
NO:Replace the DC controller PCB
Nov 07, 2009 | Canon imageCLASS D320 Digital Copier
No power
check first the charger, if its working check the dc jact connector need to open you unit.. then check if the battery is not working when you remove it should be work even withtout the battery..
Sep 11, 2009 | Acer Aspire 5500 5570-4421 Laptop
Gateway M Series M7301 M6885 Laptop DC Jack Adapter is Broken
The correct model number would help in order to solve the issue. Please see if you can locate the correct model number in order to help you.
Thank You,
Jun 11, 2009 | Gateway M-6885u PC Notebook
Gps dosen't hold a charge. ac power charge, or mobil charge
Ahh, the notorious battery problem. I had (2) units that would not charge or turn on (red light just kept flashing). I opened the unit and disconnected the battery on (1) and completely removed the leaking battery on the other since I could not find replacements batteries. The units work fine now when plugged in (AC or DC adapter of course !). Still looking for a replacement battery...
Jun 06, 2009 | Nextar Q3 GPS Receiver
Lenovo z51t, no indication of life when power up
Try this. Turn off unit. Unplug charger. Take out battery. Replug charger - not battery. Turn on computer. If it comes on the battery has a glitch and should recover after an hour or so. If it doesn't come on, the unit needs to see a reputable computer repairperson.
Good Luck
Mar 21, 2009 | Computers & Internet
Replace dc power jack
Hi, by dc power jack, if you mean the one at the back of your toshiba laptop, to replace, you may have to completely disassemble the unit and expose the back of the printed circuit board. This would involve removal of several small screws, panels, brackets, devices (hd. kb, cd, etc), connectors, cables. The screws would normally be small philips + but others might require a torx driver. Once the back of the main pcb is exposed, you can proceed to desolder the jack. normally there are 2 or 3 solder points. Simply insert the new jack and solder in place, reassemble and that should do the trick. However, if you are not comfortable with disaasmebly and soldering, it might be to your advantage to let somebody technically trained to perform the replacement for you. Hope this helps. Please let me know how it turns up. Regards.
Apr 11, 2007 | Toshiba Satellite P25-S507 Notebook
65 people viewed this question
 Grubhead
Grubhead
