Question about Elite Saniflo SaniCompact- SaniCompact One Piece Macerator Toilet
What size toilet seat fits a sanicompact elite?
  • 37 Answers
An after market seat will not correctly fit the compact, need to contact saniflo directly for a replacement which will be either white plastic or wood effect.
Posted on Feb 27, 2010
    Sniper:
  • 82 Answers
The manual http://www.saniflo.co.uk/pdf/install/Sanicompact.pdf shows that the lid and seat is of an elongated design and I think that you would need to get a direct replacement instead of trying to fit a standard seat/lid combo as a replacement. A normal seat/lid may line up with the fixing holes, but would probably not be the same elongated design.
You should be able to get a direct replacement from your plumbers merchant (may need to order), or from Saniflo directly http://www.saniflo.co.uk/
If this helps please leave feedback, if not let me know and I'll try and help some more!
Posted on Jan 31, 2010
I have a sanicompact 43, if the water pressure is low will this b the reason for flushing problems , please ?
Its a Cisternless ceramic toilet with built-in Macerator Pump.So the water pressure should not make much of a difference as most of the job is done by the pump
Regards.
plz. Don't forget to rate my suggestion.
Jul 13, 2011 | Elite Saniflo SaniCompact- SaniCompact One...
Sanicompact motor operates continuously but bowl doesn't clear. Have emptied bowl manually and poured Saniflo cleaner in.
This problem occurs when the flush button is damp after cleaning the whole toilet with a shower. Solution: Wait till it dries up 2) if you have installed a main switch put it on and at the same time press the flush button.
Dec 26, 2010 | Elite Saniflo SaniCompact- SaniCompact One...
We bought a Saniflo in Dec. 2009 and had it installed by a reputable plumber at a cost of about $750.00. It is seldom used but now we have had to disconnect the power because it flushes constantly. Could...
the backflow preventor sounds bad if you have plumbing skills you should be fine just take out and clean mite be dirty they usually last few years under heavy use
Oct 28, 2010 | Elite Saniflo SaniCompact- SaniCompact One...
Involuntary flushing operation occurs every 10 minutes
hi,
i was having same problem with my sanicompact48,it was flushing continuously after few minutes.i opened and cleaned every thing still it was the same thing.and i noticed irreguliar flushing due to SOLONOID VALVE.just replaced and works fine.yo can order by phone # 1 800 571 8191 to "saniflow".tale them your problem and your toilet model.
good luck
garry
Sep 06, 2010 | Elite Saniflo SaniCompact- SaniCompact One...
At the moment we have a saniflo plus but the whole system has blocked but the pipes are clear what should we do next
If the toilet doesn't flush but the rest of the plumbing works fine you may need to buy a closet auger to clear the toilet stoppage, they cost around $20 and do wonders much better then plungers
Jun 25, 2010 | Elite Saniflo SaniCompact- SaniCompact One...
My Saniflo sanicompact does not flush away, when i press the flush botton it does not work, the toilet buzzes all the time. when the water gets to a level it use to pump away but has stoped doing this.
saniflo buzzing all the time means that the motor is trying to run but cannot. indicates that something is blocking the pump impeller from rotating. unit needs to be removed, cleared and tested. if fault contiues you may blow the fuse (if you are lucky) otherwise the motor will eventually burn out. get this checked soon.
Apr 12, 2010 | Saniflo Sanicompact Elite - One Piece...
Fills but wont flush
take off the lid on the tank. there should be a chain from the handle to a rubber flapper at the bottom of the tank. sometimes they fall off
Jul 25, 2009 | Elite Saniflo SaniCompact- SaniCompact One...
Check the electric power to the unit first as the compact is all controlled via a printed circuit board
Replacing Sanicompact toilet seat
I have asked around they take a normal seat on most us models
Feb 03, 2009 | Saniflo 005 Toilet Tank White
Elite Saniflo SaniCompact- SaniCompact One Piece Macerator Toilet Logo
989 people viewed this question
Top Elite Home Experts
Donni Steen
Tom Chichester
Are you an Elite Home Expert? Answer questions, earn points and help others
