Question about Acer Aspire 3680 Laptop
Display screen my display doesnt seem to work I have tried fn + F5 with appropriate keys to get it back but it doesnt work. The laptop is not in sleep mode. I have also tried to plug it in to a seperate monitor to see if it comes up. please assist Thanks in advance
  • archana2007 Feb 18, 2008
    no it dint work
No diint
Posted on Feb 18, 2008
    Genius:
  • 3,587 Answers
So..did it work on the external monitor?
No display
The following applies to Acer Laptops...
If the power indicator is lit but nothing appears on the screen - The computer's power management system automatically blanks the screen to save power. Press any key to turn the display on.
If pressing any key does not turn the display back on, check the following....
1. The brightness level might be too low. Press Fn and the right cursor key to increase brightness level
2. Display device might be set to an external monitor. Press Fn and F5 to toggle to the internal display
3. Backlight might be turned off. Press Fn and F6 to turn on the backlight.
4. If the Sleep indicator is lit, the computer is in Sleep mode. Press & release power button to resume.
May 09, 2011 | Acer Aspire One PC Notebook
Power is on but no signal output to the screen
The following applies to Acer Laptops. You did not specify the brand of laptop you had. If your laptop is not Acer, the specific keys mentioned may be different and you should adjust accordingly.
Apr 04, 2011 | Computers & Internet
I have a advent m201 laptop . how do i turn the built in webcam on please
Try this
Function Keys Fn+F1 - Places the computer into sleep mode
Fn+F2 - Changes the (I-Powerxross) power settings
Fn+F3 - Switches display modes: LCD only, External monitor only, LCD+External Monitor
Fn+F4 - Turns Wireless LAN on/off
Fn+F5 - Switches OSD (on screen display) on/off
Fn+F6 - Turns the Touchpad on/off
Fn+F7 - Turns the Webcam on/off
Fn+F8 - Mute Sound
Fn+F9 - Reduces speaker volume
Fn+F10 - Increases speaker volume
Fn+F11 - Reduces the screen brightness
Fn+F12 - Increases the screen brightness
Fn+Esc - Toggles Bluetooth & 3G on/off (optional)
Thanks
Dec 30, 2010 | HP Pavilion dv6000z Notebook
Connectted to big screen monitor, the button Fn and F5 not work. what is the reason?
What is the screen Resolution set to on your current Display?
Try setting your current Display to 1024x768, then try the FN+F5 key
this might work. IF your current Display is set to high the other screen might not show any picture at all.
Feb 25, 2010 | Acer Computers & Internet
Screen not working but other monitor work
Your "F"keys are multi function. Look for the one with a picture of a monitor. Press the FN key adt the appropriate F key at the same time. You are probably in remote monitor mode. The F key is usually F5 or F8.
Dec 15, 2009 | Acer Aspire 9420-6426 Notebook
Screen not working
It could be the 'back light' is burned out.
Or
Press Fn and F5 simultaneously to make sure the display
priority is not set for the built-in screen.
Or
Press the 'brightness up' key a few times.
Display problems
Here are some typical display problems and their solutions:
The screen is blank.
Display Auto Off may have gone into effect. Press any key to
activate the screen.
You may have activated the instant password feature by pressing
Fn and F1 simultaneously. If you have registered a password, press
any key, type the password and press Enter. If no password is
registered, press any key. The screen reactivates and allows you to
continue working.
If you are using the built-in screen, make sure the display priority is
not set for an external monitor. To do this, press Fn and F5
simultaneously (once). If this does not correct the problem, press Fn
and F5 simultaneously again to return the display priority to its
previous setting.
HINT: Holding the Fn key and pressing the F5 key several times will
advance you through the display options.
If you are using an external monitor:
❖ Check that the monitor is turned on.
❖ Check that the monitor’s power cord/cable is firmly plugged in.
-- Try adjusting the contrast and brightness controls on the
external monitor
Aug 07, 2009 | Toshiba Satellite L305-S5907 Laptop
Cannot see the startup screen in windows vista
Press the FN and F5 keys together
or FN and F7
Jul 26, 2009 | Acer Aspire 5050-3242 Notebook
I have pressed Fn and F5 on my easynote laptop now the LCD screen has gone wierd. How do I reverse this?
fn + F5 changes output mode
its 3 way toggle switch
1. laptop screen only
2. secondary display unit only\
3. mirror on both display units
press Fn+f5 keys again to revert to normal mode
Apr 04, 2009 | Computers & Internet
How do i auto switchoff my lenovo y410 laptop
I'm not sure if your referring to sleep mode or not but I hope this helps There are several specialty key functions on the Lenovo Y410...here is a list....good Luck....please rate me ...The Fang
The following describes the features of each function key.
Fn + Esc: Turn on/off the integrated camera.
Fn + F1: Put your computer in sleep mode.
Fn + F2: Turn off the LCD screen (any subsequent operation will turn the LCD screen back on).
Fn + F3: Shift to other connected display devices.
Fn + F4: Switch between wide screen and normal mode.
Fn + F5: Enable/disable the built-in wireless networking feature.
Fn + F6: Enable/disable the bluetooth features.
Fn + F8: Enable/disable the touch pad.
Fn + F9: Enable/pause Media Player playback.
Fn + F10: Stop Media Player playback.
Fn + F11: Skip to the previous track.
Fn + F12: Skip to the next track.
Fn + Insert/NmLk: Enable/disable the Numeric keypad.
Fn + Delete/ScrLk: Enable/disable Scroll Lock.
Fn + Pause/Break: Pause to view the system information during start-up.
Fn + up/down arrow key: Increase/decrease display brightness.
Fn + right/left arrow key: Increase/decrease computer volume.
Feb 19, 2009 | Lenovo 3000 Y410 Notebook
Fn+f5 does not work. unable to switch between screens.
Thanks for your reply. I was working outside the house all day and we went out for dinner after to wind down.
I'll get back with you with a link if I can find a driver now that I know you have me and I have your model and series number.
Regards,
Worldvet
Jun 09, 2008 | Toshiba Satellite 3000-S353 3005-S303, and...
Acer Aspire 3680 Laptop Logo
130 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
