Daewoo computer monitor model # F257-A not working
I have a Daewoo computer monitor model # F257-A. When I turn the computer on, nothing comes up on the screen. The green power light is blinking on monitor but no picture/graphics will display. I was able to resolve this a few times by rebooting but now that does not work. Other monitors work fine with the PC.
  • 51 Answers
SOURCE: Blinking green light with no display
Have you tried connecting this monitor to another computer?
Have you tried resetting the BIOS? That should reset any problem the video driver for the monitor maybe facing.
Posted on Oct 17, 2007
  • 165 Answers
SOURCE: When it's turned on, the light on my monitor blinks but the screen doesn't display anything. Why ....
Refresh rate may be set too high for LCD
hook up crt monitor
1. Open control panel-display
Click on settings tab and set to a lower screen res such as 800x600
Try lcd
2. Open control panel-display
click advanced button
click on monitor tab
set screen refresh rate to 60 hz
Try lcd
Posted on May 20, 2008
SOURCE: Monitor is Blank and Power Light Blinks
you try to check and replace the transistor 5707, two of them are shorted
Posted on Oct 13, 2008
sparkyuiop
  • 91 Answers
SOURCE: 1800FP Dell Monitor Light continuously blinks no picture
I have made a solution to this and it can be found on my website here:
http://www.dorchestercomputerrepairs.com/1800.html
Hope this helps.
sparkyuiop
Posted on Oct 20, 2008
frcs68
  • 1605 Answers
SOURCE: My monitor works fine for 0.5 sec every time I turn on my PC and then nothing
sound like the monitor is gone.
if it is still in Warranty, you can call Samsung.
if it is out of warranty, take it to any computer repair shop. (cost may be prohibitive.)
the last option is get a mew one.
Posted on Nov 10, 2008
My daewoo lc1700c will not turn on. No matter how many times how hard how soft how long or how short you hold the button in for nothing comes up nor does the light come on. Im not a fool. The monitor is...
Open it up and look at the capacitors. The round "tin can" looking components. If the tops appear bulged, then replacing them may help. Check out the YouTube video... and web site...
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
May 11, 2010 | Daewoo L700C 17" Flat Panel LCD Monitor
Daewoo w9zq 19"tft power light flashes but no screen :s
Open it up and check for bad caps in the power supply first, post back what you see so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 12, 2010 | Daewoo F227B Monitor
Why f257 turns on no picture light blinking?
Sounds like you have a video card issues..Also try turning off Monitor first, then shutdown PC. Then Turn monitor back on first then PC..It should sync up...
May 18, 2009 | Computers & Internet
No picture on screen but power light blinks
May be the problem with your Pc. If you can hear a beep sound when booting the Pc is Ok. Otherwise check memmory for loose connection.
May 03, 2009 | Computers & Internet
Daewoo TV Question
there should be some buttons provided on the dash board of your tv... just enter the menu using those buttons n reset it back to the original settings
Feb 20, 2008 | Daewoo 19NF 19 in.CRT Conventional Monitor
Black screen
How old is the computer? Make sure that the power light comes onto the monitor when you plug it in, should be orange and then turn green when video card syncs with it when PC is turned on. If you are getting black screen when PC is powered on:
1. Bad video card
2. Bad video cable
3. Bad monitor
1Solution: Try using a different monitor attached to this same PC and see if it works. If it does, then its the monitor, its cable, or its power supply. If it doesn't work, then its the video card or the video cable coming from monitor.
Nov 24, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
No power in my Daewoo Monitor
Hi, Youo have zeroed in on the problem area. It looks like a power supply problem. More often than not, there is a fuse inside. If you would venture to open the unit up, do a visual check on the fuse. If it is busted: 1. Clean - no burnt/scorching/black marks inside the glass tube, then you can simply replace and hopefully the unit will be operational; 2. Dark smudges - or small burnt metal pellets inside the glass tube, then it is possible that you have other defective components that caused the fuse to blow. Normal components that are known to go bad are the big capacitor and or the power transistor regulator. Most current designs uses a switch mode power supply where your mains AC voltage is converted to DC that powers a circuit that eventually produces a lower DC voltage say 12VDC for use of the monitor. Should you venture a DIY (do-it-yourself), pls remember safety precautions when working with powered electronics. Hope this be of some help/idea. Post back how things are or should you need further information. Good luck and kind regards.
Sep 25, 2007 | Daewoo F227B Monitor
Screen turns black
problem with the inverter chek it
Mar 18, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Computers & Internet Logo
229 people viewed this question
David Payne
David Payne
