Question about Cycling
Want to take rear wheel off my hybrid bike but the brake stops the wheel from coming out. How do you release the V brake mechanism so I can take the rear wheel off?
  • 14 Answers
Want to take rear wheel off my hybrid bike but the - 0638909.jpg Grab the cable tube in one hand and the brake mechanism with the other. push the brake mechanism inward and then pull the cable tube out and away.
Once they are separated, the V brakes will have enough space between them to clear the width of the wheel. Make sure you put the brake back together after reinstalling your wheel. Your brake would not work at all if you didn't.
Posted on Jan 31, 2010
How can I release my rear left wheel
a little tap with a hammer
Feb 25, 2015 | Cars & Trucks
Rear brakes keep failing.
After reading your description, two ideas come to mind. If you have bench tested your master cylinder and it does not leak down. You have checked all fittings, lines, and master cylinder for leaks, and there are none. Then would suspect an issue with the rear brake caliper. You mentioned that you replaced the rear rotor due to it warping. I am curious to know why it warped? Raise the rear wheel off of the ground and spin the wheel. It should spin freely. Then apply and release the brake, to that wheel (a few times). After releasing the brakes, spin the wheel again. Does the wheel still spin freely? If it doesn't then I would check the brake pedal (see if it is releasing freely or binding), check the brake lines (see if there are and defects, flat spots, or kinks), and check the rear brake caliper (do all the cylinders retract with little resistance?) If the wheel does spin freely then I would check to see if you are using the correct type of brake fluid. Most bikes will require you to use DOT 4 or 5 brake fluid. If you substitute for a cheaper grade, it will affect the braking system. It may sound silly but I would double check that you are not accidentally resting you foot on the brake pedal. If that was happening, it would cause the brakes to fade. I hope that helps but If you have other details or question, let me know.
Feb 28, 2014 | 2001 Harley Davidson FLHTCUI Electra Glide...
I need a replacement rear wheel rim for my Edgewood lx hybrid
you didn't specify why you need a new wheel, is it just out of true, is it broken, is it bent?
If the wheel just needs to be trued this is an easy fix for most mechanics. You can even do it yourself using the brake pads as a guide. If a spoke is broken, this can be easily replaced and retrued. If the rim is actually bent or broken, then the rim should be replaced.
Rims can be replaced but they require a good mechanic that has the skill to relace the wheel, true it and tension it properly and at a minimum a decent mechanic with these skills will charge $25-50 for the labor. Assuming that the mechanic can get the exact same rim you are looking at about $20-50 for the rim. If that particular rim is not available then they can get something similar but it will most likely require a new set of spokes because rims are different thicknesses. Most shops charge $1-3 per spoke times 32 or 36 spokes for a typical wheel.
The easiest fix is to just buy a prebuilt wheel, these will typically run about $25-65+ for a complete wheel (not including tire, tube and rimstrip).
Your local bike shop/Diamondback Raleigh dealer will be able to help you determine what is best for your situation.
Jan 31, 2013 | Diamondback Edgewood LX 700c Men's Hybrid...
When coasting the pedals keep moving so you have to continue to pedal and when peddling backwards the bike goes backwards, how do I stop this?
I assume that this bike normally has a coaster brake. If so, your coaster brake mechanism (inside the hub of the drive wheel) is jammed or broken. You will have to disasssemble the wheel hub. This bike might have a coaster brake on both rear wheels or maybe just one side. Lift both rear wheels off the ground and turn them independently to determine which side the problem is on.
Sep 18, 2012 | Schwinn Meridian Adult 26-Inch 3-Wheel...
Changing the rear tire of a 1983 shovelhead. Hows the best way to remove it?
Depends on whether the rear wheel is driven by a belt or a chain. First raise the bike off the ground high enough to get the rear wheel out from under it. Remove the two bolts that hold the rear caliper into the caliber bracket and remove the caliper and lay it aside. Do not crimp the brake hose. This will cause the inner lining to come loose in the hose and when you apply the rear brake, it will not release. If it's a chain drive, find and remove the master link of the chain. Do not allow the chain to come off the front sprocket as it can be a real pain to get back on. If it's a belt drive, remove any belt guards over the belt. Take the axle nut off and drive the axle out of the rear wheel. Make sure you make a drawing or something so that you can remember how the spacers go back on the bike. You'd be shocked at the number of request I get wanting to know how the spacers go back under all years and model bikes. I don't know all that information. Even motorcycle mechanics make drawings or mark them. With the axle out, you can move the front wheel forward to work the belt off the rear pulley. Lower the wheel and tilt it sideways a bit to get it out from under the bike. It helps if you have something that can raise and lower the bike or the wheel as needed as the wheel itself is quite heavy and difficult to manage while trying to do other things with it.
Good Luck
Steve
Aug 05, 2011 | Harley Davidson FLHT - FLHTI Electra Glide...
No rear brakes on 1985 honda goldwing aspencade. What could be the problem ?
Check your rear brake resevoir. Fill it with Dot 4 brake fluid and proceed to bleed the brakes, If this does not resore your braking and there is no sign of a leak on the rear caliper, you will have to replace the seals in the master cylinder, or the complete cylinder.
Jan 30, 2011 | 1985 Honda GL 1200 Aspencade Gold Wing
No brakes at rear wheel of my 2005 standard goldwing. Had a new rear tire(screw/nail) put on and the service man told me.I normally slow down slow enough to use front brakes.I had installed full foot...
Try putting the bike on the center stand and get the front wheel off the ground with a floor jack. Spin the front wheel by hand and press on the rear brake pedal. The front wheel should stop. Likewise with the bike on the center stand and the rear wheel off the ground you should be able to lock the rear wheel with the foot pedal. On many Goldwings the rear pedal also operates one front disc. This is for people that refuse to use there front brakes to stop or slow there bike (80% to 90% of your stopping power is the front brake). Try bleeding the entire system front and back, you may just have air in the system. If the rear brake still does not work you may have a bad delay valve in the system. If you need to take the bike in to a shop, try to find a mechanic that is familiar with the system so they do not replace parts unnecessarily. That way you minimize your shop time and maximize your riding time.
Aug 21, 2010 | 2005 Honda GL 1800 Gold Wing
ABS light will not reset on BMW R1100 rt after replacing abs sensor
you have to check the wires going to the abs, could be a bad wire, if they are ok then either the new sensor is malfunctioning, or the abs sentral is fried
Jan 17, 2010 | 1998 BMW R 1100 RT (ABS)
2004 honda crv brake won't release
Your emergency brake is a mechanical brake system that is indipendant of the regular hydrolic system. If the red brake light on the dash is on make sure it's the emerg. brake and not a problem with the fluid level or the calapers sticking. the best way to check the emerg. brake is to rase both rear wheels off the ground and spin them. If they spin, the emerg. brake is not locked up. If they don't spin, take the rear tires off and the brake drums. (you may have rear disk brakes.) check the springs to insure they are all hooked up properly. If there is no problem there, follow the parking brake cable to check for damage. The cable is like a brake cable on a bike, If the inner cable is binding inside the cable sleeve,the brake wont release. If you have rear disc, it's probly a bad calaper.The park brake cable is attached to the calapers. Rember if it wont run it's annoying but if it won't stop, it's deadly. DON"T experiment with brakes!!! If in doubt, take it to a pro.
Apr 30, 2009 | 2004 Honda CR-V
Men?s Schwinn 700C Prelude Road Bike Assembly
Pedals can be purchased in pairs and some road bikes do not come with pedals. They have 2 different axle sizes 9/16" and 1/2". There are road pedals and road clipless pedals.The ones with clips and quick bindings require special biking shoes that the cleats clip into.Quick releases come in various lengths for front and rear wheels depending on what wheel you have. This all means a trip to your local bicycle dealer. They will match the pedals to the axel size you need and the type of riding you will be doing. For a little extra cost they will install them.They will also match you up with the proper length of quick release skewer you will need and show you how to install and tighten it properly.Remember to take your bike and the front wheel. Hope this helps. Good riding.
Mar 15, 2009 | Schwinn Midmoor Men's Hybrid Bike
Cycling Logo
73 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
