Question about Highpoint Technologies 1 Bay e.SATA Upgrade Kit w/ Rocketmate 1000 Hard Disk Enclosure and Rocket 1511 Adaptor - Serial ATA Drive Case
Difference between ata and sata hard disks
Pls, tell the difference between ata and sata hard disks and also features of sata and ata hard disks
    Scholar:
  • 93 Answers
ATA, or (PATA) hard drives use the older "seatbelt" 40 or 80 pin ribbon interface cable, whereas SATA is fairly new using the small, thin interface cable found in most computers manafactured in the last 12-18 months, hope it helps
Posted on Feb 19, 2008
How to change sata to ata in bios
If you want to install Windows XP or configure a RAID array, you may need to change the SATA type in BIOS. here I will introduce some method of SATA settings in BIOS. SATA HDD(hard disk) has been more porpular because of the hight transferring speed and simple installation. If you want to Install a Windows XP in SATA hard disk. we offen need a floppy disk to save the additional driver of SATA/RAID. but the floppy isn't too easy to find. So we can do another method, modify the SATA type to compatible IDE or ATA mode, etc.
Notes: If your computer has installed some operating systems. Changing SATA types may corrupt your systems or need to be repaired again. But when can I change the SATA type?
1. You are prepairing install a new operating systems, for commonly Windows XP. If Windows 7/Vista will be installed. you need nothing changed in BIOS unless the setting has been modified.
2. Or you want to install a RAID.
I will introduce how to install Windows XP at SATA HDD(hard disk) in the coming chapters, here we need to know how to change the SATA type in BIOS. At first we need to access BIOS, Here is my desktop BIOS, we can find the BIOS is from AWARD software.
201003290718324672.jpgIn my BIOS, the harddisk settings are in the line of integrated peripherals, different BIOS or different OEM menufactures may have different promise. you can try the Advanced BIOS features setting or Integrated peripherals, or system configuration, etc.
Locale to Integrated Peripherals and press enter, you may find the SATA configuration.
201004010308121905.jpgthe above screenshot is the SATA configuration position. There are two items about SATA controller, Onchip SATA controller and Onchip SATA Type, Notes: There may be one or more configurations about SATA, we only need to change the SATA Type. you should not close the SATA controller if you don't know what's will be happened.
Navagete to the Onchip SATA Type and press ENTER, we can find these selections: Native IDE, AHCI, RAID. If you want to install Windows XP, you may need to change to Native IDE(some called ATA) mode, when you finished installation, you can refresh your SATA drivers in Windows XP and change the SATA type to AHCI mode in BIOS again.
If you want to configure a raid array. set to RAID similarity. When finished settings, you should press enter to accept it, and save to CMOS before restart your computer. In my BIOS, I need to exit to the BIOS main menu at first and save it.
when the new status has been saved, you can press CTRL+ALT+DEL to restart your computer, some OEM PCs may need to click the EXIT or Save to CMOS and Exit, the computer will be restart automatically.
Another example screenshot is my DELL notebook BIOS. DELL BIOS is not the same as the desktop BIOS, we can find the SATA operation behind the System Configuration. there are only three selections (Disabled, ATA, AHCI). If you want to install Windows XP, here need to be changed as ATA mode.
201004010308185104.jpg Notes: If you want to install operating systems, you may need to change the boot orderto boot from your CD/DVD drive.
Oct 10, 2013 | Compaq Presario Notebook
HDD Upgrade
That model has standard IDE interface for hard drive. Don't think 500 GB or higher comes with that interface. The standard now is SATA interface for hard drives. Here is a lnk to the owner's manual for you model:
ftp://ftp.dell.com/Manuals/all-products/esuprt_desktop/esuprt_optiplex_desktop/optiplex-gx60_user%27s%20guide_en-us.pdf
You tell the difference between standard IDE and SATA in that the standard IDE interface uses a wide flat ribbon cable to connect to the drive. SATA uses a small thin cable as shon in the following link:
http://www.google.com/imgres?imgurl=http://www.cooldrives.com/lib/cooldrives/ultraflex-sata-cable-2.jpg&imgrefurl=http://www.cooldrives.com/24seatsaiiul.html&h=514&w=600&sz=35&tbnid=wGLj8F1otpnJYM:&tbnh=97&tbnw=113&prev=/search%3Fq%3Dwhat%2Bdoes%2Ba%2Bsata%2Bcable%2Blook%2Blike%26tbm%3Disch%26tbo%3Du&zoom=1&q=what+does+a+sata+cable+look+like&usg=__57zU4K_H2rpvq5AyZ41v_Ag4RTk=&docid=m3f9D21nEcMb3M&hl=en&sa=X&ei=NZQVUbrfDJD49gSd44CAAg&sqi=2&ved=0CFkQ9QEwBA&dur=81
Feb 07, 2013 | Dell Optiplex GX60 PC Desktop
Need new hdd for my presario 700 but don`t know if it`s ata, sata,pata.What is the difference.
ATA =aDVANCED tECHNOLOGY aTTACHMENT
PATA= Parallel ATA
SATA=Serial ATA
SATA is more avenced in speed than others.
Mar 31, 2011 | Compaq Presario 700 470024-192 Notebook
I asked this a few days ago; , I have a Samsung SpinPoint P80 SP1604N 160 GB Hard Drive in a HP compaq presario SR 1617CL I want to replace it with a larger HD, 500GB or 1TB. Can I replace it with a...
Yes, either of these drives will work. The cache is not all that important it is just where data is stored temporarily in case you have to access it again soon after a file is written to the hard drive. The best thing you could do in this case is see if your motherboard has a sata connection which I would assume it does and buy a sata hard drive. It will be much faster than either of those drives, just make sure you also get a sata power adapter if your power supply doesn't already have one and a sata cable.
Mar 11, 2011 | HP Compaq Presario SR1620NX...
SATA Hard Drive Type The Dell Optiplex GX280 Takes?
It makes no difference providing the computer motherboards support SATA interface.
SATA 1 and 2 drivers are in the BIOS. If all the computers have SATA 1 you can upgrade the BIOS to latest version via Dell's support website.
Regards.
Jul 08, 2010 | Dell OptiPlex GX280 PC Desktop
Hard Disk Problem
it seems as serious disk drive error to try fixing any errors that may be present on drive please run from command prompt [as admin] cd /D <faulty drive letter> then chkdsk /r if asks to unmount <or scan after reboot if it is sys disk> say Yes <lonely Y also does the job> this should fix the trouble, if not please send message
Oct 09, 2009 | Computers & Internet
Motherboard : ASUS P5GV-TMX Which hard disks does this motherboard support? It came with sata-I hard disk. Recently i bought a sata-II hard disk bt it is giving some problems..to be specific on windows it...
Yes, it can be causing a problem. You have 2 hard drives that are working at 2 very different speeds. The computer is having to do a translation and adjust rates of transfer between them on top of having to do the read and writes between them. Will SATA II will be backwards compatible to SATA I it won't work the other way. If you have to keep these drives, I would make the SATA II Drive the primary and SATA I drive the secondary on a different channel if possible. The SATA II drive is teh faster drive and should be your main.
Oct 09, 2009 | ASUS P5GV-MX Motherboard
Xp installation in cq40 301
check the kind of Hard disk if SATA ,,change sata mode to ATA or disable sata mode on bios
May 05, 2009 | HP Compaq Presario CQ50-110US Laptop
Planning to buy a hard disk
look on the board... if it has sata connectors .... use them as they seem to have a better data rate. i'm uncertain if you can still buy new 80 gb drives now... but your sources might be different then mine.
Mar 21, 2009 | ASUS P4S533-MX MB, DDR+SDR/ VGA/ Audio/...
Difference between HDD and SATA
Buying a new SATA hard drive is confusing if you don't understand the differences between the various drive types. Which hard drive should you buy?
SATA Hard Drives (Serial ATA) are the most popular drives being sold today. Alongside them in the store however you will also find boxes labeled Parallel ATA or SCSI. So what are the differences between these hard drives and which one should you purchase? Your decision is dictated by what your computer can accept. Check with your computer's manufacturer to see which drive style you can use. Most newer computers purchased within the last two years accept SATA connections. If your computer cannot accept one of the newer SATA hard drives you can purchase SATA adaptor cards that plug into an empty expansion slot on your computer's motherboard. You can purchase SCSI adaptors as well, so follow these tips to guide your decision.
SATA vs PATA: Serial ATA vs. Parallel ATA Drives SATA hard drives have many benefits over their older cousin, the Parallel ATA drive. Chief among these differences are:
  • SATA hard drives are faster and perform much better than traditional ATA drives and are better for high bandwidth applications such as video editing and multiplayer gaming.
  • SATA drives use a smaller, cheaper cable to connect to the computer's motherboard. These cables can also be up to three feet in length compared to eighteen inches with Parallel ATA cables.
  • SATA hard drives can be hot swappable, meaning that they can be disconnected and reconnected without powering down the computer. There are limits to this of course. You should never disconnect your boot drive while the computer is operating.
  • SATA cables are easier to plug in without damaging the delicate connecting pins on the drive.
  • SATA hard drives are significantly faster than external USB hard drives.
SCSI Hard Drives SCSI hard drives are the elders of the storage world. SCSI is one of the oldest specifications but it is also the fastest and thus has been widely used in network servers and other high speed, high bandwidth applications. Unfortunately this high speed storage has also meant much higher costs. SCSI drives were once standard in all Macintosh computers but have since been replaced by the cheaper SATA based hard drives.
  • SCSI drives are also hot swappable, similar to the SATA drives.
  • Some varieties of SCSI can be used with SATA
  • SCSI drives are often set up in a mirroring arrangment to allow for instant, continuous backups of the hard drives.
  • SCSI drives are still the most expensive drives on the consumer market.
Your basic rule of thumb should be to purchase a drive that is designed to work with your computer's motherboard. Try to avoid using SCSI adaptors or SATA adaptors unless absolutely necessary as the whole point of using a specific kind of hard drive is to get the most speed and storage for the money.
Thanks alot,
Sanjeev Kumar
Jan 22, 2009 | Tablets & eReaders
Highpoint Technologies 1 Bay e.SATA Upgrade Kit w/ Rocketmate 1000 Hard Disk Enclosure and Rocket 1511 Adaptor - Serial ATA Drive Case Logo
193 people viewed this question
Top Highpoint Technologies Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Highpoint Technologies Computer and Internet Expert? Answer questions, earn points and help others
