Question about Sanyo DS31520 31" TV
My tv cuts off the edge of brodcast tv as though the screen were bigger. Is there any way to adjust this i feel my loss is in sharpness and color saturation but i can't adjust these things thru the menu without things getting worse.
  • Sanyo Master
  • 12,061 Answers
Can you adjust the "Aspect ratio"? I suspect that is your problem..
Posted on Jan 31, 2010
How do I adjust the vhold on the sharp 32u-s80? My screen is flipping
[PDF]32US60 Operation Manual - Sharp Electronics
files.sharpusa.com/Downloads/.../tel_man_32US60.pdf
Sharp SolarEvery SHARP Color Television set is tuned and adjusted for proper color and ... serious injury to a child or an adult, and serious damage to the equipment.
SHARP 54GS-61S OPERATION MANUAL Pdf Download.
www.manualslib.com > Brands > Sharp Manuals > CRT TV > 54GS-61S
Sharp operation manual color television 32u-s50b (48 pages) .... view the all functions implemented in your TV set demonstration and set the CHILD LOCK. 1.
SHARP 32JF-77H OPERATION MANUAL Pdf Download.
www.manualslib.com > Brands > Sharp Manuals > TV > 32JF-77H
Dec 21, 2015 | Sharp Televison & Video
Why cant i hear sound from my ps3 on my tv
Un plug the ps3 and switch of the sharp. Then after a couple of minuets have past feel free to plug the ps3 back in and switch the sharp back on
Jun 13, 2014 | Sony Playstation 3 (PS3) Console
Have sharp quos 52" screen went pink. Can still
Hi, My guess is your daughter messed it up. Go to menu and color and reset to default should fix it.
You may have to adjust color for your best viewing. Good luck.
Sep 27, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
The picture is bigger then the screen how do I adjust so that the picture is same size as TV thanks
Please confirm tv model number as question shows its Mitsubishi WS-55511 rear projection tv.
This info will help me to suggest a solution.
Do you get correct colors in picture though its over size?
Thanks.
Aug 13, 2011 | Mitsubishi WS-55511 55" Rear Projection...
I have a sony trinitron 36in tv, the screen works fine, colours are all great, no flickering or random shapes at all, its just a little blurry around edges, especially small text, its very blurry and...
it is very easy you just need a very small straight edge screwdriver
you should try to adjust sharpness setting with on screen adjustment first
if tv is too old tube might be going "soft" and sharp focus might not be able to be fully achieved anymore
good luck
Mar 13, 2011 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Composite output has ghosting around the video (sort of an auro around all images on screen, including text and video). dvd menu also has this problem, so i verified that it is the output of the recorder...
Try reducing your sharpness value on either your TV or the player if applicable. Also disable any edge enhancement or "DVE" modes on the TV if applicable.
The easiest way to adjust sharpness control by the naked eye is with a calibration disc. Alternatively however, just for sharpness if you have a screen full of text and/or lines do the following;
Reduce your color/saturation value all the way down...this will make the picture black and white.
Then reduce your sharpness control until the "ghosting" effect or any additional white lines on text edges and line edges disappear.
Then you can return your color/saturation value back to normal.
Hope this helps!
Jan 12, 2011 | Toshiba DR4 DVD Recorder
Edge of the screen is cut off when using PS3/Xbox360/Computer
Well you did not included the gaming system so its impossable to diagnose but try to go into the game system video properties and set the resolution. if its a older gaming unit like beyond old like nintendo 64 then I am stunned you may have to set you TV to streach the sceen as its not to wide screen formats. If its like a Xbox360 you can order a special cable to go HD and this will summerized this problem do not use HD mode if you not using a HD cable set it for standard resoultion on your TV..
May 14, 2009 | RCA HD52W58 52" TV
Edge Enhancement Option Disabled...
edge enhancement option i think would be enabled if you are in dynamic or movie mode. What it does is to enhance the contrast of the edges of 2 different colors.
I have the LA32S8, similar specs but only 7000:1 CONTRAST ratio. when playing dvd, i set it to movie mode. Settings vary on different tv and player. you can adjust first the backlight, then brightness then contrast, color and sharpness. the brightness you adjust by choosing the level that shows enough details on dark scenes. adjust if its too dark not to see the details of the scene. contrast, you can set by distiguishing vivid colors of the picture, dont put too much contrast as your picture would look flat. it should have a 3d look, same also with sharpness, you can experiment on the face of a person to show details on the edges.
color you set just enough to make it accurate on color reproduction.
My settings for movie are
contrast 92
brightness 49
sharpness 23
color 57
tint g48 r52
backlight 7
tone warm1
digital NR off
black adjust high
dynamic ocntrast high
gamma +2
edge enhancement on
color space auto
Oct 05, 2007 | Samsung LN-S3241D 32 in.LCD HDTV
Center screen convergence problem
The convergence adjustment on the TV set are for the center adjustments ONLY. if you cannot get them in or they are way out, then you have a convergence IC problem. Dont feel bad though as it happens to every rear projection set ever made. Good Luck
Dec 30, 2006 | Toshiba 53AX62 53 in. Rear Projection...
Sanyo DS31520 31" TV Logo
177 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
