Question about GE Profile JGP636 Gas Cooktop
GE Gas cooktop Model JGP940 - the control lock button light stays on when in the unlock position. The burners will light but the cooktop 'alarm' will sound. I tried unpluging the electricity in a hope that would reset the lock - it didn't work.
SOURCE: Maytag CSE9000 Electric Cooktop
They may stay on until the burners cool off. To indicate a hot surface.
Posted on Jan 23, 2007
erpaalai
  • 999 Answers
SOURCE: I have a GE model jgp940 gas cooktop one of the
You have to determine if it is the electrode or the ignitor module and replace the component. A simple test is to swap the wires on the spark module for the non working one and see if the other electrode still works. If not the electrode is bad, if it does than the module is bad.
Eric
Posted on Dec 25, 2009
  • 21 Answers
SOURCE: No spark on our GE Profile JGP940 cooktop
Hello
Check the pilot light?
John
Posted on Jan 07, 2010
  • 221 Answers
SOURCE: Have a four burner gas GE Profile cooktop. How do
The igniter module is working fine. One of the switches (which are on each valve shaft) is stuck or shorted out. Pull a wire off each one at a time to determine which one is bad. Careful! 120 volts to each wire. Also, this can happen after you spill water into the valve area, if that sounds right, let it dry out.
Posted on Jan 30, 2010
blueextc3221
  • 15935 Answers
SOURCE: GE Profile JGP940, one igniter sparks when burners
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
Light "Burner On" stays on all the time on my electric stove GE model JBS27WH2WW
I have a GE Range Model JBS27W H2WW and the serial# XXXXX that I was cooking on and the back burner starting throwing out sparks and blew a hole in the coil and the drip pan. Now the light Burner on is staying on and I switched the 8 inch burner in the front with this 8 inch burner and still cannot get it to work.
Dec 19, 2013 | Cooktops
GE gas cooktop modelJGP970BEK2BB. The unit is in the unlocked position, burners will light, but "lock" light remains on and buzzer/alarm sounds the whole time?
The lock switch will need to be replaced. Lock switch, the switch has failed and causes the buzzer to run. Not a difficult repair but the top will need to be remover to fix this. This is not advisable to repair if your not knowledgeable with the installation part of this unit.
Good Luck
Jul 19, 2011 | GE Profile JGP636 Gas Cooktop
I have a GE model jgp940 gas cooktop one of the four burner electrodes will not spark.
Eric
Dec 24, 2009 | GE 30 in. JGP336 Gas Cooktop
Ignitors keep making ticking sound, all burners turned off, won't go in lock position, and one burner will not ignite gas despite constant ticking
Probably a spillage or boil over has clogged the burner and some of the liquid has dampened the shank switch mounted on the burner post. Get a shop vac and clean the burner. Wait a day or 2 and see if the switch stops. OR disable the ticky ticky by removing the bottom drawer and looking for the spark module. Remove one of the hot wires and tape it up. Light the burners like granny does with a match. LOL
Jul 17, 2009 | GE 30 in.Profile JGP945 Gas Cooktop
Dcs igniters
clean the knob control by using vaccium,pull the knobs then clean it.make sure how to remove the knob,same position to returrn the knob
Jun 30, 2009 | GE Profile JGP636 Gas Cooktop
GE Cooktop radiant heat element problem
Sounds like you need to replace the burner control (part # WB23K5053)
Mar 02, 2009 | GE Cooktops
Gas leak in my GE profile JGP336
Contact your local gas company and turn off the gas to the unit.
May 01, 2017 | GE 30 in.Profile JGP940 Gas Cooktop
Gas leak within cooktop
What do you mean it has a leak inside? You can remove the glass top by carefully lifting it up and out of the countertop and the removing either the phillips, 1/4" or Torx screws around the lip under the glass. Pull off the knobs and the glass will s-l-o-w-l-y come up with even steady lifting force. Where gloves in case it breaks but it shouldn't as long as you don't drop in on a corner
Dec 13, 2008 | GE 30 in.Profile JGP940 Gas Cooktop
GE Profile JGP636 Gas Cooktop Logo
206 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
