Question about LG DU-42PX12XC 42 in. Plasma HDTV
My TV Screen just turned off, but I hear the sound, have no menu.
My TV Screen just turned off, but I hear the sound, I have no picture and I can't get the menu up.
It sounds like you may have a bad Control Board, especially if the problem is intermittent. There are dozens and dozens of posts from folks with this model LG. Usually the probles starts with red or blue verticle stripes on the screen, but in many cases the picture will go black, become pixilated, or turn various colors. Here's a link to a site that has a description, photos, and the exeriences of dozens of folks who've fixed the problem: http://greenrenovation.wordpress.com/du-42px12x-red-stripe-repair/#comment-394
Posted on Jan 31, 2010
MINE DID THE SAME THING ABOUT AN HOUR AGO. I UNPLUGGED THE SKY BOX FOR ABOUT 10 MINS PLUGGED IT IN AGAIN IT WAS FINE
5 Suggested Answers
jdbouncer
  • 72 Answers
SOURCE: Blank screen, cannot get menu to display, but sound works
Does the lcd screen have a glow to it ? Or is it really dim if u get real close to screen u can see images moving ?
it it has a glow to it you panel lighting is fine but you control board is bad. If you have a dark screen and see faint images you panel back lighting is out u can check the power with a meter at the connection to inverter board on panel.
Posted on May 06, 2008
  • 52 Answers
SOURCE: Phillips 37PF73203 37 in Television goes straigt to Menu and stays
verify in customer menu, installation, software upgrade, current software info that software is 1.5.0.0. if not upgrade by downloading from p4c.philips.com website and upgrade via usb memory stick. if upgrade is successful and menu still pops up would be a small signal board issue
Posted on Aug 18, 2008
dsacco86
  • 1077 Answers
SOURCE: westinghouse 42' tv working fine this morning, got
Try leaving the TV unpugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jul 01, 2009
SOURCE: Turn tv on. green light solid display, no picture or sound
The flashing green light is likely indicative of a self-test failure, indicating the TV has detected some sort of internal fault. With no picture or sound, one strong suspect is the power supply. Flat-panel TV's have an internal DC power supply that converts the inbound AC current, and when these fail, or are unable to supply a minimum level of power to the set, it can behave as you describe, providing only enough power for the green light to illuminate.
Posted on Jul 28, 2012
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
Toshiba 32a43 32' picture garbled mess
If you can get the tv to display the blue blackground(usually happens when there is no antenna or cable feed to tv) check to see if the whole screen is a solid blue, if it shows discolored areas around the screen then you might have to "demag" the screen. See if you can rent a demad coil from a tv shop and with tv on turn the coil in circular movements all over the front of screen till blue is solid.good luck!
Aug 03, 2009 | Toshiba 32A43 32" TV
When I turn on my TV it goes straight to the menu screen. You can still hear sound but no picture. When I try to exit you see the picture for about a second then it automatically flashes back to the menu screen. Even if I try to use the functions in the menu screen it flashes right back to the main menu screen. Very frustrated...need help!
Jul 13, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
TV has audio sound and no picture
major repair; requires 16 pin ic
Apr 19, 2008 | Televison & Video
TV has Sound but no picture
your tv set have a problem in the horizontal section of the board.have sound but no picture or no raster.contact your service tv technician to check your tv set.......anime'
Apr 05, 2008 | RCA 27R410T 27" TV
Samsung 40 no picture
If it is only 6 months old you probably still have a warranty. This is definitely a hardware issue, and unless you are comfortable taking your new TV apart, I would contact Samsung for repair.
Dec 11, 2007 | Samsung LN-S4051D 40 in. LCD Television
Your set migbe missing the high voltage that lights up the picture tube,you need to check for loose conections starting at the horizontal drive transistor and transformer ,then check the horizontal output transistor for short,it needs to be checked with a meter if the output is shorted it probably open a safey fuse or resistor to prevent more damage.If you are familiar with tv service this will give a place to star but if you are not too familiar be safe and seek the help of a servicer.Let Us know if you need more information.
Oct 14, 2006 | Sony KV-36XBR400 36" TV
LG DU-42PX12XC 42 in. Plasma HDTV Logo
628 people viewed this question
Computer Repairing
Computer Repairing
