Question about Vizio P50HDTV10A 50 in. Plasma HDTV
I just got a 50 vizio and was told to run the image cleaner on it and I was wondering how long its supose to take before its done
Just purchased a 1994 Firebird, took it in for a smog test, and it failed at 15MPH, measuring 522 while the max allowed is 483. Car had been in storage for two years with the battery disconnected. Also low...
522 what? Get it registered. Yes it needs to be driven, Yes do an oil change. Add some injector cleaner, I recommend Chevron TECHRON fuel system cleaner. The shop that is checking it most likely knows what it needs to be repaired. If you dont trust them to properly repair it, find a different shop.
Aug 03, 2011 | Pontiac Firebird Cars & Trucks
How do i clean my vizio tv without damaging it?
There is a screen cleaner you can buy at any store like the source, future shop , best buy that sells it, it is called monster screen cleaner it is a bit expensive but will not damage your tv screen
Apr 08, 2010 | Vizio L32 32 in. LCD HDTV
My vizio 50 inch plasma tv will not turn on. what
Tries unplug,replug about an hour,see if it reset itself.Not than must replaced the signal tuner board.Plasma have this problems alot.
Jan 08, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
Black box in center of TV
Sounds like close caption is on. Go into menu and turn it off.
Jan 04, 2010 | Vizio Televison & Video
I have a Vizio 50-inch Plasma TV (out of warranty) from Costco and recently when I put the TV on pause while watching a show from my DirecTV DVR List, a white line (2-inches) vertically appeared on the TV...
it could be an image burn that was caused over time because you pause the screen to much or from a game or pc use.
You can try to clean it by going to the tv mode and go menu and go to set up and go doen to image cleaner.
Try that maybe it will take care of it.
Aug 10, 2009 | Televison & Video
Vizio lcd tv turned off and wont turn back on.
I just spoke to Vizio, I have the same problem on my P50HDTV10A and they do not cover the model with the lifetime warranty is not the P50HDTV, i was told to try a hard reset and if that does not work i was S.O.L
Comments: Jun 05, 2009 - It worked, i turned the tv off, unplugged it and held the power button on the side of the tv down for 1 minute, once i plugged it back in and turned it on everything was back up and running
May 30, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Ghost Images - Pastel colored images
There are 3-4 issues in here,one of them might be a bad convertion part in there. It is not worth your time and money to guess the issue,if it is under warranty,you should take it back.If not,repair tech. would be the way to go!
solutiondoct
Nov 07, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio 50
tv needs z sustain board to be replaced try www.vizioce.com or www.ebay.com the part # is on the board.
remove the back cover and is the board on your right side
your rating to my answer is highly appreciate
thanks
Jun 29, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
No screen display - VIzio 50" Flat screen TV
If you purchased the TV 6 months ago, still under manufacturers warranty. They normally give customers 1 year warranty coverage.
It looks like the main board will have to be replace on this TV or fix to the component level.
Mar 21, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio P50HDTV10A 50 in. Plasma HDTV Logo
120 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
