Question about Panasonic Microwave Ovens
I'm trying to remove but unable to determine how
Unable to remove over range Panasonic microwave model # NE-8860
  • 254 Answers
Most over the range micos are secured by either 2 or 4 screws from above usually inside a cabinet or storage above remove those disconnect or pull away venting if vents above,, u willl need two people sometimes to help hold micro..... i would have to see the unit some might also have trim pieces if its more of a built in situation hope this helps
Posted on Jan 31, 2010
  • harveydog Apr 05, 2011
    Look at the left and right sided plastic pillars that join up with the two heat grilles at the top and bottom of the fixing kit and you will see an indentation on either side that will take a flat head screwdriver.
    Insert the screwdriver and prise the side pillar off - it will come - it just snaps into place.
    Once they are off you will see the four screws that hold the rest of the fitting in place.
    Hope this helped.
Replace fuse panasonic ne-8860 microwave
The outer cabinet has to be removed to gain access. Be aware that you will be exposed to potentially lethal voltages, even with power disconnected.
Feb 12, 2017 | Panasonic Microwave Ovens
Over the range microwave oven
The problem is the release spring is broken or the button is sticking, pick up a small can of electronic cleaner attach straw and spray into the button crevis to break down the crud, grime, and dirt this should help release the mechanism.
Apr 23, 2012 | Panasonic NNH965BF Microwave Oven
How do i remove the control panel
Hi Colin, On our microwave , unplug first, husband just removed thewhole outer casing of microwave and pushed the button through the back, he did not touch the control panel. Hope this helpskind regardsChristine
Nov 20, 2011 | Panasonic NN-H275 Microwave Oven
Model of 1989 GE Spacemaker
The model number should be on a tag as shown in the drawing below.
Feb 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Replacement part for microwave
That would have been # ANE06012L0APbut it is listed as no longer available from normal distributors.
It looks like you can still order it here.
Dec 04, 2008 | Microwave Ovens
Looking for parts for my Panasonic Microwave Model No 9970C9870C
The proper model number format would be NE-9970C or NE-9870C.
You can order Panasonic parts from Tritronics, but if you don't find what you're looking for there, try here.
I would suggest searching by just the root model number without the C suffix.
If you're still having trouble, please replay back with your specific model (from the tag on the unit) and let us know which parts you need.
Oct 13, 2008 | Panasonic Microwave Ovens
Microwave runs for a few seconds then F 12 displays on screen and it stops
The following is a solution for the Panasonic brand microwave. I do not know your brand so this is the best I can do.
PANASONIC
Model: NE-1057, NE-1057C, NE-1257, NE-1077, NE-1277, NE-1457, NE-1457C, NE-1757, NE-1477, NE-1777 Symptom: Code "F11" or "F12" appears on the display intermittently Problem: Moisture is accumulating on control panel from steam rising out of the door. Solution: Install foam sealer (cushion rubber) along lower edge of control panel escutcheon. Part # A8251-3180
Apr 03, 2008 | Microwave Ovens
Microwave Ovens Logo
219 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
