Question about Sony Cybershot DSC-H3 Digital Camera
Sony DSC-H3: For Use With Compatible Battery Only comes up when I put the battery back in after being charged. Then the camera shuts off. This is the same batter that came with the camera.
Arpi
  • 326 Answers
SOURCE: When i turn on my camera it flashes"for use with compatible battery only" then turns off
Hello, try to replace the battery (purchase the new NP BG1) If you need more info please advice.
Posted on Jun 08, 2007
SOURCE: Sony DSC-W80 message for use with compatible battery only
finally brought a cheap replacement battery as suggested and now i can use my camera!
Posted on Apr 05, 2008
  • 5 Answers
SOURCE: battery for Sony DSC T-300
I bought a SONY DSC-S750 3 months ago. Since last week, when i turn the camera on, appears the message "for use with compatible battery only". The battery came with the camera. The camera was bought in a big store in Philadelphia. I WILL NEVER BUY A SONY CAMERA AGAIN. I already tried to reset, tried to remove the battery and the problem persists.
Posted on Aug 27, 2008
welcomejee
  • 10594 Answers
SOURCE: My Sony Cyber-shot DSC-W70 Digital Camera now
Buy new battery, charge it fully and power up camera with that.
Posted on Jun 22, 2009
  • 89 Answers
SOURCE: SONY DSC CYBER SHOT
Try clean contacts of camera for battery and contacts of the battery also, specially the middle one - it is for communication between camera and circuit inside the battery. If the problem persists, try use another battery in your camera, or your battery in other compatible product - you determine this way if the problem is inside the battery (I hope, it is cheaper) or inside the camera.
Posted on Sep 23, 2009
I need a different way to charge my sony cybershot DSC-H3 digital camera
The DSC-H3 does not contain any charging circuitry. You could hook it up to a nuclear reactor and it won't charge the battery. You need to use a separate charger, such as this one.
Jun 28, 2012 | Sony Cybershot DSC-H3 Digital Camera
Tip
I dont know what's wrong with my camera, tried hitting it. Its DSC H3 bought...
Surprisingly enough, most freezing problems (and other problems, too) can be solved by gently hitting your camera. It works! Just remember to be gentle.
on May 06, 2008 | Konica Minolta DiMAGE G400 Digital Camera
The camera comes on when the powere button is
Usually this is a sign that the battery is weak or not charged enough.
Make sure you have either a new battery or the battery is fully charged, then test the camera again.
This camera takes a Sony NP-BK1 Li-ion rechargeable battery (or compatible).
If the battery is good and is fully charged, then there is a problem in the camera, and needs repair or sell it as parts or as is (if repair cost is too much) on a site such as Ebay.
Apr 15, 2010 | Sony Cyber-shot DSC-S750 Digital Camera
Sony Dsc h3 Camera fails to recognize lens cover removed
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your batteries need to be replaced because they're just too worn to properly power the camera. And then, of course, there's the possibility that your camera may have a problem that requires professional repair.
Oct 12, 2009 | Sony DSC-H3 Digital Camera
My sony cyber shot turns off after it says for use for compatible
Seems battery got bad and camera does not recognize it.
Take out battery, put it on charger and charge it, put back battery in camera and check.
If problem still exist, use new battery.
Thanks.
Aug 29, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
New Sony DSC T700. "For Use with copatible battery only"
I have the same problem, did you ever get it figured out ?
Jun 10, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
System error
ok try this pls take out the mem stick b4 going fwd
factory reset the camera
Home Screen>Settings>Main Settings1>Initialize press OK on Control Button and then OK select Initialize All Settings press OK
then pls turn off the camera and take out the battery then move power switch of camera to ON position for 1 minute
after 1 minute move power switch to OFF position and then put the battery back and see everrything is OK
pls let me know with the results
Rate me FIXYA if i fixed ur problem
Feb 06, 2009 | Sony Cybershot DSC-H3 Digital Camera
BATTERY
When it comes to this matter,If it isn't the snoy battery problem,then it must be the problem of sony camera charger.
For the NP-BG1 problem,you can refer to this website for help information.
Sony NP-BG1 , Sony NP-FG1 ,np-bg1 digital camera battery charger
Jan 06, 2009 | Sony Cyber-Shot DSC-W7 Digital Camera
Camera powers off
I think battery went on protection mode and if you give couple of hours rest to battery by take out from camera and place it on shelf. Hope this trick will work.
May 28, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Flash doesnot work how does one charge the flash on a Sony cybershot DSC-H3
Some of the popup flashes seem to be defective on this product. Mine is. I am returning mine under warranty.
May 03, 2008 | Sony Cybershot DSC-H3 Digital Camera
Sony Cybershot DSC-H3 Digital Camera Logo
126 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
