Question about Canon PIXMA iP1500 InkJet Photo Printer
Print cartridge stuck
The print cartridge on the printer is stuck in the right hand corner of the printer.
Normally when you open the front the cartridge will move out to the middle, but this is not happening. You can see it trying to but it just won't.
Please help
  • 1 more comment
  • trinle Dec 07, 2008
    The cartridge carrier is stuck in the far right side. How can I get it to the center so I can change the ink cartridge?
  • Anonymous Dec 29, 2008
    I have the same problem but don't know how to get the object out and I have just replace a new ink catridge. The ink cartridge is stuck and I can't get it out.
  • Anonymous Apr 12, 2009
    same thing here, it seems that the cartridge is tilting forward and get stuck and when i push it back so that it can move out of the right side, it then grinds every single bump thru-out the cartridge path. Is something broken?
    Sniper:
  • 60 Answers
You should try to reach at the right end by dismounting the front elements of the printer, it seams something slipped in, could be a coin or an earring or whatever, the foreign object must be removed. But youneed some tehnical skills...
Posted on Feb 19, 2008
Printer displays 10.002 error
10.000x Supply error E-label cannot be read or print cartridge is
not properly installed.
10.0000 = Black print cartridge
10.0001 = Cyan print cartridge
10.0002 = Magenta print cartridge
10.0003 = Yellow print cartridge
1 Reinstall print cartridge.
2 Turn on the printer.
3 If the problem is not solved, replace the
cartridge.
Dec 24, 2010 | HP Color LaserJet 2600n Printer
Que voy a fotocopiar algun trabajo documento. etc. y en la pantalla de la multifuncional dell a940 me aparece hardware error 0502 y tampoco puedo imprimir trabajos del computador
Hello
1. Ink cartridges lids are open which is not allowing cartridges to move freely. 2. Ink cartridges carriage will not move from its original position(left) when front cover is opened 3. Encoder strip is Dirty. 4. Encoder strip is Out of position.
Solution: 1. Open the front cover and check if ink cartridges lids are properly snapped in.
2. Turn the printer off and pull out the power cable from power socket, open the front cover and manually center the ink cartridges carriage. Clean the metallic rod inside the printer using WD40 or Kleenex from Left corner to right corner properly.
3. Cleaning the encoder strip: a. printer should be off and disconnected from power. b. open the front cover. c. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer and you can move the cartridges carriage to clean the strip completely. d. Note: The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting running parallel to metallic rod. e. Close the printer and try again to print.
4. Repositioning the Encoder strip. a. Remove the power cord from the printer. b. Open the front cover. c. Gently slide the ink cartridge carrier to the middle of the printer. d. Gently move the top part of the printer belt to the right. e. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier. f. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly. g. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip. h. Once the encoder strip has been re-seated, close the scanner lid. i. Re-connect the power cord to the printer and try again to print.
Hope it will helps if so do rate the solution
Dec 20, 2010 | Dell A940 All-In-One InkJet Printer
Dell 924 printer
There could be 4 possibilities.
Solution:
Incorrect position of encoder strip
Correct position of Encoder strip
Hope it should fix the issue.
Nov 05, 2008 | Dell 924 All-in-One InkJet Printer
Carrier stall.
Solution:
Nov 04, 2008 | Dell 962 Photo All-In-One InkJet Printer
Clear carrier jamed
Solution:
Oct 20, 2008 | Dell 924 All-in-One InkJet Printer
Hardware Error 0502
Solution:
Sep 20, 2008 | Dell A940 All-In-One InkJet Printer
Clear the carrier jam
Solution:
Sep 01, 2008 | Dell 942 All-In-One InkJet Printer
Dell Printer carrierjam
Solution:
Aug 31, 2008 | Dell 942 All-In-One InkJet Printer
CLEAR THE CARRIER
Solution:
Aug 19, 2008 | Dell 924 All-in-One InkJet Printer
Cartridge stall
Solution:
Sep 04, 2007 | Dell 924 All-in-One InkJet Printer
Canon PIXMA iP1500 InkJet Photo Printer Logo
169 people viewed this question
old marine
old marine
