Question about SanDisk Sansa e260 MP3 Player
I dropped sansa fuse in water and it is not working even when i plug it up will it come on later
But it in silconna feet gels in a zip lock bag and it will let out all the misture
Posted on Jan 31, 2010
How do I charge the battery on my Sansa MP3. I plug it into the computer with the cord provided it doesn't charge.
It's broken. It had to have been exposed to water, been dropped hard, or has been off for 8 months or longer. This happens alot.
Feb 28, 2010 | SanDisk Sansa Clip MP3 Player
IT WON'T TURN ON AND IT'S BRAND NEW (Sansa Fuse MP3)
Mine was the same, it solved using the methods below that written by ThaMp3Doctor:
"Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure"
Jun 17, 2009 | SanDisk Sansa Fuse MP3 Player
Works with charger but not battery
You could go online and find a new battery and see if that work it might be just the battery.
Feb 23, 2009 | SanDisk Sansa e250 MP3 Player
My sansa e250 mp3 player just fell down, after that, when i restarted it it is just showing the blue light but not showing the display on the screen. Any help would be appreciated.
Drop it again from a similar height
OK this is going to be hard to believe....the exact thing happened to mine. It dropped about half a meter onto a concrete floor and showed up with a blue screen and wouldnt shut off.
I unscrewed the back panel and unplugged the battery hoping that it would reset. After several restarts and unplugged batteries it was still unresponsive with the blue screen of death. So like any good tech i tried to reproduce the sequence causing the failure. I dropped it onto my work bench and plugged the battery back in. Worked perfectly after that and has continued to work perfectly since (nearly a year later).
I made sure i covered it with one of those cheap silicone covers after to hopefully absorb some shock after i got it working again. After a year of brutal treatment on military exercises this is the one and only problem i've ever had with my sansa.
Good Luck
Dec 30, 2008 | SanDisk Sansa e250 MP3 Player
Sansa Clip not holding charge
Locking the player will not allow the player to charge properly, no matter how long you have it plugged in.
Dec 17, 2008 | SanDisk Sansa Clip MP3 Player
I have a 4GB Sansa Clip. Was working fine until this evening. Later it kept freezing on me. Later my computer did not recognize the USB port. I called the company and they asked me to format which I...
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to the Sandisk website and click "Firmware Updater" to find out.
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Nov 30, 2008 | SanDisk Sansa Clip MP3 Player
PC not recognising hardware
Sansas only work on WinXP or later. Win 2000, ME, 98 and 95 are not supported.
Jan 03, 2008 | SanDisk Sansa m240 MP3 Player
Sansa Bad Track Fix.....
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Oct 16, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
95 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
