Question about Siemens SpeedStream 4200 (13A4200001) Bridge
Connecting 4200 simens modem to D-Link Router
Hi, my 4200 simens modem has just one port I need mor ports for my other computers, can I use my D-Link 504 router with 4 ports to slove this problem? can you help me about the connection of them?
Thanks
    Problem Solver:
  • 18 Answers
Yes u can!!
however ur going to need a cable called a CROSSOVER cable to connect the modem to the router. you can find this at any computer part supplier near u.
however u MUST connect the computers to the router with normal Straight through cables. plug in n enjoy!
Posted on Feb 21, 2008
How to install d link 802.11G wireless access
Connect modem lan cable to Router Wan / Internet port. From Router Lan port you can either connect your system or switch . wireless : Scan for wireless network from your wireless system. If it shows, connect to your wifi network
Thanks
Mar 25, 2011 | D-Link 802.11g Wireless Router WBR-1310...
Problem setting up home network with d-link des-1105. Windows Vista on main PC & Windows XP on laptop. Presently, I have ethernet cable connected on main PC to d-link and usb cable connected to laptop & to...
A router is basically a mini-computer that splits up one internet connections to 4 (or whatever # of ports you have).
Basic Connections to a router:
A Router requires a internet connections, so your broadband modem must connect to the WAN port (theres only one) of the router DIRECTLY. Then Ethernet cables go from the router to the computers on the LAN ports. Don't do something weird like connecting your internet to your computer then your computer to the routers WAN port, it'll most likely mess up.
Once you have connected your router like this, it should work.
If your modem only has a usb port, I have no idea how to make that work out. Sorry. Try getting a new modem from your ISP, or check if your modem does have a ethernet port, if it does just connnect that to the routers wan port.
Also computers should not interconnect with each other with use of a router. Thats what the router is for. Everything gets connected and split up at the router, nothing connects to anything else but the router, basically.
Feb 26, 2009 | D-Link DIR-625 (790069292637) Wireless...
Initial connecting of router to modem
hi..
look at the back of the router you will see 5 ports..one of them is seperated and 4 of them is together,what you need to do is to connect the cable comming from the modem into the port that is seperated and the 4 ports thats there together you can connect the computers,on the modem there will be a port that is labelled as ethernet the cables going to the router should come from this port...
hope this helps you..
vedhick
Feb 25, 2009 | D-Link DI 514 Wireless Router (DI-514)
Hi I need help with my modem settings. It is siemens speedstream 4200. I am told in forums I need to open ports to solve my problems.. but cannot successfully do it. PS3 will only give a NAT3 connection...
Do you have the device hooke up directly to the speadstream 4200? As the Speedstream 4200 is a modem most companies already have this device in bridged mode because it is largely understood that if this device enters a home it will be shared. That being said do you have a router? if so your task will be that much more easier if you are going to purchase a router please ensure that you buy a good one as gaming can be quite intensive and some routers do not do so well when it comes to this..
Depending on your ISP if you place the PS3 in DMZ you may have to registar the mac address with them before they allow it on the network. As of now they probably have the Speedstream modem registered and this is why you do not have access to online gaming in DMZ.
Jan 15, 2009 | Computers & Internet
Can't get a wireless router to work with a speedstream 4200
This may actually be an issue with your ISP. There is a good possiblity that your ISP has bound your connection to the MAC address of the network card on your computer. This is a common occurance which is why router manufacturers give you the option of having your router clone your computer's MAC address. Go into your router's management an perform the clone, sorry I cannot give you more details but I don't know the specific model of your Belkin router.
Jan 05, 2009 | Siemens SpeedStream 4200 (13A4200001)...
Siemens 4200 2 computers
Yes and No! The 4200 gives you the option to connect via USB or Ethernet. You can only use one or the other to connect. You have two options. The first DOES involve another "gadget". The second does not!
Solution #1
I realize you're not looking to use additional equipment, but a network hub, switch or router will give you what you need. You can pick up a very inexpensive router for under $50 or even better a wireless router for a few bucks more.
I recommend a Linksys Wireless Router (Model - WRT54G) as it is very user friendly and comes ready to use. Just connect the port labeled "Ethernet" to the "WAN" port of the Linksys Wireless Router. Then connect both of your computers to any of the four "LAN" ports.
Solution #2
You can connect the first computer directly to the 4200 via USB and connect the second computer directly to the first computers ethernet port using a Network Crossover cable. Without a router of hub between the two computers, a crossover cable is required to allow them to talk to each other.
Once you have them connected to each other, on the first computer open the network connection properties for your internet connection (will be the one setup during the install of the USB modem) and click "Share This Computers Internet Connection".
Now the first option is surely the most reliable and keeps the traffic separate.
Hope this help!
Jul 20, 2008 | Siemens SpeedStream 4200 (13A4200001)...
Hooking ethernet to broadband router and cable modem
Hi Sherry - The etherport port on your modem should be connected to the WAN port on your router. You then connect your pc to one of the 4 ethernet ports on the router. If this answers your question PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks.
Jeff
Jul 10, 2008 | SMC Universal Wireless Broadband Router...
Router
i asssume that you have connected the ethernet port of the modem to the wan port of the router. if that would be the case, yes you need to connect the computer to the lan port of the router to get internet access. that it if you want your computer to be directly connected to the router. but if you're planning to connect wirelessly, you just need to make sure that your router and computer have a wireless capability and your computer.
Jul 04, 2008 | Blitzz Technology BWA711 (B3WL000900)...
Siemens SpeedStream 4200 (13A4200001) Bridge Logo
328 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
