I have a Simple Comfort 2000 air and heat thermastat when i turn the heat on it comes on anthe the thermastat clicks and the fan blows and ther it clicks off and it trys to come bak on and it clicks about 3 times and it don't come back on. what could the problem be?
  • 10,319 Answers
The relay in the circuit has gone bad. It will not hold the circuit closed for continuity to flow through. The relay should be mounted on the circuit board which means the board will need a replacement
Posted on Jan 31, 2010
Fan blows air, but no heat or ac
May be your air modulator. Do you hear a clicking sound behind the dashboard?
Jan 04, 2014 | 2000 Lexus ES 300
Overheats in engine but heater blows cold air
you need antifreeze! the antifreeze is what cools your car it removes the heat and takes it to the radiator which is a simple heat exchanger the air from your fan cools the antifreeze down and circulates it through the engine to cool it! but before the antifreeze goes to the radiator it passes through your heater core under the dash which has a fan that blows through it creating the heat for your comfort! in turn no antifreeze no heat in the vents and high engine temps!
Jan 28, 2013 | Cooling System for Mercury Mountaineer
Simple comfort 2200 thermostat not working properly
We have a Simple Comfort 2200 Electronic Thermostat and last night it quit blowing cool air and the # sign beside the air temp (the set to temp) starting blinking
Aug 11, 2012 | Heating & Cooling
In Fan mode, fan works; but in AC mode, I can hear the normal AC sounds, except the fan never turns on. This is the fan in the lower half of the unit in the inside of the house, which blows the air...
on a call for air conditioning your therrmastat brings the indoor fan on and the out door unit at the same time. Since your fan comes on in "fan" mode, it sounds like you need a thermastat. For temp. cooling just turn your fan switch to "on" and turn system switch to cool and set desired temp. System will cycle off and on but fan will not shut off until fan control is set back to "auto". I suggest replaceing thermastat
Aug 16, 2011 | Heating & Cooling
I have a 98 Saturn SL1 that blows no air at all, the engines fan is blowing, and it looks like the serpentine belt on the compressor is running too, and when you put the car on max cold the rpm's...
Does your interior fan come on when you turn on the heat? If it doesn't, then look in the fuse panel for the comfort control fuse. If it is okay, then it will either be the fan motor or the comfort control switch.
Jul 10, 2011 | Saturn SL1 Cars & Trucks
2000 Jeep Grand Cherokee, heater wont blow heat!
Check the thermastat or your cooling fan to make sure all is working good. If your engine cant warm up, you will not produce any heat inside the car
Feb 04, 2010 | 2000 Jeep Grand Cherokee
Heat won't come on in auto mode; blows cool air in on mde(fan)
these units has 4-steps in heating mode... step-1 when the thermostat calls for heat, the small vent fan comes on and proves that its blowing thru the suction tube and closes a switch,,, step-2 -the next click from the gas valve, the pilot lights.......the #3 step and the next click from the gas valve the main gas comes on and heat up the box. step-#4 the box heats ups and turns on the fan switch and blows heat through out the home, now wheres the steps stops, thats where your problem is located>T Y V MUCH!
Dec 15, 2009 | Goodman CLQ36AR49 Air Conditioner
My 2000 jetta gl is overheating the thermastat is good and the fans work but when you turn on the heater only cold air blows
sounds like your cooling system isn't full.  with the heater on Hi refill the cooling system and bleed it until all the air comes out.  Sometimes you need to raise the front of the car.  And there may be a bleed screw on the thermostat housing.
Mar 27, 2009 | 2000 Volkswagen Jetta TDI
Heater won't blow hot air
you may need to change your thermastat
Dec 11, 2008 | 1998 Plymouth Breeze
Heating & Cooling Logo
47 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
