Question about Car Audio & Video
Wire codes which is the power and which is ground for speaker wire in a 2002 dodge durango
  • 1 more comment
  • specialknr Feb 19, 2008
    I'm pretty sure that each of the wires had a line on them. On the front left one had a red line and the other had a black line on it. I noticed that most of the lines had had black lines, but the other lines always had a different color on them
    Thanx
    On the front left, I think the colors were green. I'm pretty sure that both wires had lines on them. One wire had a red pin stripe and the other had a black. Infact I noticed all the wires had a black pin stripe. The other wires the color varied.
    Champion:
    Scholar:
  • 216 Answers
Check by using a DVM, hope that you have one.
The DVM is a digital volt meter.
You can buy it new for under 35 dollars.
Set DVM on OHM(the horseshoe sign) around 500 or under.
Connect black lead to black socket and red lead to red socket of DVM.
Turn on DVM
Disconnect Car Battery, negative post.
Touch black lead to ground(metal of car) and the red lead to wire to locates grounding wire. When meter reads "OOO", that's ground wire.
You can use that mode for checking open circuit(broken wire) or closed circuit(shorted wire).
Hope they are helpful.
atdlee@netzero.com
Posted on Feb 19, 2008
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 199 Answers
Usually power is the wire that is solid colour. The ground or NEG- wire has a trace on it
2002 dodge Durango two ground wires on right side firewall where to install
It doesn't matter , if there are ground wires bolt them to the fire wall or to the engine , just as long as it is metal .
Jan 27, 2017 | 2002 Dodge Durango
Multiple codes on 2002 dodge durango
This many codes sounds like a wiring issue. You need to inspect all the wiring. If you have rabbits in your area, they eat wires. If not then it is likely to be a corroded or loose ground. You need to get a wiring diagram etc.
Feb 25, 2014 | 2002 Dodge Durango
I need a wiring diagram for 05 dodge durango sound and ves systems.
  • 2005 Dodge Durango Car Radio Stereo Audio Wiring Diagram
  1. Car Radio Constant 12v+ Wire: Gray/Red
  2. Car Radio Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
  3. Car Radio Ground Wire: Black
  4. Car Radio Illumination Wire: Black/Yellow
  5. Car Stereo Dimmer Wire: Orange
  6. Car Stereo Antenna Trigger: N/A
  7. Car Stereo Amp Trigger Wire: N/A
  8. Car Stereo Amplifier Location: N/A
  9. Car Audio Front Speakers Size: N/A
  10. Car Audio Front Speakers Location: N/A
  11. Left Front Speaker Positive Wire (+): Dark Green
  12. Left Front Speaker Negative Wire (-): Brown/Red
  13. Right Front Speaker Positive Wire (+): Brown/Yellow
  14. Right Front Speaker Negative Wire (-): Brown/Light Blue
  15. Car Audio Rear Speakers Size: N/A
  16. Car Audio Rear Speakers Location: N/A
  17. Left Rear Speaker Positive Wire (+): White
  18. Left Rear Speaker Negative Wire (-): Dark Blue/Red
  19. Right Rear Speaker Positive Wire (+): Brown/White
  20. Right Rear Speaker Negative Wire (-): Brown/Orange
regards, Tony
May 12, 2011 | Dodge Durango Cars & Trucks
Wiring for 1998 dodge durango car stereo
Hi there:Check this on 1998 Dodge Durango Car Audio Wiring Diagram:
Car Radio Battery Constant 12v+ Wire: Red/BlueCar Radio Accessory Switched 12v+ Wire: Red/WhiteCar Radio Ground Wire: N/ACar Radio Illumination Wire: Black/YellowCar Stereo Dimmer Wire: OrangeCar Stereo Antenna Trigger Wire: N/ACar Stereo Amp Trigger Wire: GreenCar Stereo Amplifier Location: N/ACar Audio Front Speakers Size: 6 1/2" SpeakersCar Audio Front Speakers Location: DoorsLeft Front Speaker Positive Wire (+): Dark GreenLeft Front Speaker Negative Wire (-): Brown/RedRight Front Speaker Positive Wire (+): Brown/YellowRight Front Speaker Negative Wire (-): Brown/Light BlueCar Audio Rear Speakers Size: 6 1/2" SpeakersCar Audio Rear Speakers Location: Rear DoorsLeft Rear Speaker Positive Wire (+): WhiteLeft Rear Speaker Negative Wire (-): Dark Blue/RedRight Rear Speaker Positive Wire (+): Brown/WhiteRight Rear Speaker Negative Wire (-): Brown/Orange
Hope helps.
Sep 05, 2010 | 1998 Dodge Durango
Dodge durango p0123
A P0123 code means that the computer has detected that the TPS (throttle position sensor) is reporting too high a voltage.
A code P0123 may mean that one or more of the following has happened:
  • TPS not mounted securely
  • TPS circuit short to ground or another wire
  • Faulty TPS
  • Damaged computer
If there are no symptoms, the simplest thing to do is to reset the code and see if it comes back.
Aug 23, 2010 | 2002 Dodge Durango
HOW TO INSTALL AMP INTO A FACTORY RADIO IN DODGE DURANGO 2002
You can buy adaptor plugs that allow a simple hook up at most car stereo places.  However, when you increase the power going to the speakers you also have to replace the speakers to handle the higher power or you'll toast them.
Apr 01, 2009 | 2002 Dodge Durango
2002 dodge durango fuse keeps blowing for turning signals
You have a ground problem. Somewhere on the wiring, usually where there is a bind of many cables zip tied together heat from a hot lead wire has cause it to melt another wire which is grounding itself with your other wire causing your bulb to burn or a fuse to pop. Check your wiring...this is going to be pain staking but it will solve your issue. This is the cheapest way to troubleshoot the problem. If your turn signals are parallel to each other check the other bulb, maybe that could be your culprit as well. Change both light bulbs first before you check all the wiring. Cheapest first, let me know. Gabe
Dec 11, 2008 | 2002 Dodge Durango
Car Audio & Video Logo
99 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
