Question about Yamaha RX-V870 Receiver
Front panel light on Yahama RX-870 AV Receiver is out; Radio Shack can't help me unless I know the voltage of the light
SOURCE: i just purchased a yahama rx- v850 av reciever
if you dont mind a lettle customization, just go to radioshack and set your favorite color l.e.d. and wire it in, if you can find a specs diagram for your reciever, you might look up voltage and wattage of the bulb so you can get appropriate resistors for the led, and install that. itll last forever, cost virtually nothing, and its easy to do.
Posted on Jan 24, 2009
petraman7
  • 1175 Answers
SOURCE: i need a display bulb for a yahama rx- v850 av reciever
The display bulb is a 14 volt bead style lamp about 0.150 inches wide with wire leads. You'll need to cut the old bulb off the two -pin cable assby and wire the new lamp into the existing wires.
partsexpress.com
mcmelectronics.com
or
studiossoundelectronics.com should have lamps for that
Posted on Feb 04, 2009
SOURCE: yamaha av receiver rx-359
go to best buy and buy a new recever
Posted on Apr 10, 2009
SOURCE: no picture from wii
The RX-V800 switches the various video signal types separately.
Since you are feeding S-Video to the TV the composite (yellow) input from your Wii is not going anywhere.
If you cant get S-Video output from the Wii then I'd suggest a simple Composite to S-video adaptor plug ($5 say). It worked for me with a Game Cube.
Cheers
BJ
Posted on Apr 27, 2009
SOURCE: We have a Yamaha rx-v365 AV receiver. In basic
i have the same problem. any answers? navychief872000@yahoo.com
Posted on Nov 24, 2009
RX-V461 Yahama Receiver is hooked up to TV with optical THX cable but can't get sound. Tuner on receiver plays and all speakers work perfectly for radio listening.
double check input used on amp and make sure u use the auto format decoder fuction on your amp ok if it has none than turn it on optical digital ok that should work for you :)
Feb 10, 2011 | Yamaha RX-V461 AV Receiver
I would like to know how to connect my Bose 901 to my Yamaha RX-V765 AV Receiver.
Ahhh, the good ole Bose 901. (I like those)... And you want to connect them to the Yamaha RX-V765 AV receiver. That should be a piece of cake. I assume you only have two Bose 901 cabinets. If so, you simply need to connect one end of your speaker wires to the terminals found on the 901 cabinets, and the other end of the speaker wires need to go to the Front Left and Front Right speaker outputs of the RX-V765. The RX-V765 is a 7 channel surround receiver. Weather you run it as a 7 channel theatre or as a more classic 2 speaker configuration, you will want to run the 901 cabs from the Front L and Front R speaker outputs, unless for some reason you want to specifically use them for any of the surround channels in which case it will not harm anything if you use them for surrounds - it's just that if you're simply wanting to use them as your principal speakers, you want Front L and Front R.
So connect them as I explained, power the receiver up, put on your favorite CD and enjoy!
Oct 24, 2009 | Audio Players & Recorders
I need a display bulb for a yahama rx- v850 av reciever
partsexpress.com
mcmelectronics.com
or
Jan 11, 2009 | Yamaha RX-V461 AV Receiver
I just purchased a yahama rx- v850 av reciever
Yamaha RX V-663 video output into old Coaxial TV
You need a coax to RCA converter. Do a google search, Belkin makes one, Radio Shack probably has one too.
Yamaha Rx-V870
I replaced it with a 6V lamp. Radio Shack part# 272-1140. It cost $1.49.
Aug 31, 2008 | Yamaha RX-V870 Receiver
Front display panel
Check for bad connections on the display pins themselves. Specifically, the ones on the ends are the power/ground pins.
Let us know if that resolves the problem. If not, we'll look further into the circuitry.
Dan
Apr 14, 2008 | Yamaha RX-V657 Receiver
Yamaha rx 530 receiver
I have the same exact problem, though I do have the original bulb. I THINK the part number is: VE628900. I need someone to replace it for me though! Not too sure, but I think you can get a similiar one (not in brightness, but in dimentions and voltage) at Radio Shack. I think it is 6 volt, but have NO clue if it is AC or DC.
Mar 05, 2008 | Audio Players & Recorders
RX-V1500- front panel lights not working
The display on an amp has two components.
A small Lamp (light bulb)
A LCD display with a color filter.
Normally when the display goes out the problem is with the lamp
The lamp on my RXV 870 died after about 9 years of use.
I called Yamaha and was able to by a replacement.
The lamp is an odd voltage 14.5 if I recall.
Looking at the receipt i should have bought 3 for the cost of shipping. It cost about 10.00 cnd,
Apr 02, 2007 | Yamaha RX-V1500 Receiver
571 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
