Question about Farmall IH Tractor 460, 560, 660, 2606 ITIH25
I would like to know how to check the hydraulic fluid level on an International harvester 560 where is the plug and what type of fluid do I use?
  • 18 Answers
SOURCE: is hydraulic fluid really used for both the
caseih hytran fluid is used for hydraulics and transmission fill through plate on top of deck next to shifter check plug is located on left side of transmission housing next to clutch linkage rod probably square headed pipe plug
Posted on Jan 23, 2011
  • 10865 Answers
SOURCE: Hydraulic Fluid Level (Checking and Filling)
hello darrell. yes you just unscrew the plug and fill it full.
Posted on Apr 15, 2009
  • 14 Answers
SOURCE: what battery does the international farmall
call NAPA they will tell you
Posted on Aug 17, 2010
  • 18 Answers
SOURCE: where are hydraulic fluid drain
1 plug under pto 1smaller plug under tractor on front of transmission 1plugunder clutch housing total of3
Posted on Mar 20, 2011
SOURCE: where do you check hydraulic fluids on a 460 international tractor
I own one. Most have a plug in the top of the trans/hydro case to the left and rear of the gear shift leaver. It takes a 3/4" drive to open it. I use an extention and brake bar or ratchet. The fluid should just all most reach the opening. the books state it should hold 8 to 10 gal. I have found my 460 Utility holds almost 20 gals.
Posted on Jan 07, 2012
Have a b414 international that as you use the tractor the 3 pt gets weaker as it warms up.
Check your fluid level and type. Also make sure your hydraulic cooler core is clean near your radiator.
Jan 10, 2015 | Cars & Trucks
Where do you check hydraulic fluids on a 460 international tractor
Jan 04, 2012 | Farmall IH Tractor 460, 560, 660, 2606...
Where are hydraulic fluid drain plugs located on farmall 560
Jan 25, 2011 | Farmall IH Tractor 460, 560, 660, 2606...
Is hydraulic fluid really used for both the transmission and hydraulics in the international 460 also where do you fill it?
Jan 15, 2011 | Farmall IH Tractor 460, 560, 660, 2606...
Farmall 560 hydrolics wont work on the bucket
i am not sure but check the levers and the inside of the lever control movements.
Apr 28, 2010 | Farmall IH Tractor 460, 560, 660, 2606...
What kind of hydraulic fluid can i use in my farmall 460 that is affordable
universal hydraulic fluid is all we use it is used for the transmission and the hydraulics, about 25 bucks for 2.5 gallons, put in at the gear shift until it comes out plug below cluch pedal. Check any cenex gas station .
Oct 09, 2009 | Farmall IH Tractor 460, 560, 660, 2606...
I have a case 4210 farm tractor and need to know what the best type of hydraulic fluid to use would be ??????
Older case machines used a fluid identified as TCH (Torque Converter Hydraulic) for both the transmission and the hydraulic system. It's not readily available so has been replaced by default by separate products. Hydraulic fluid for the cylinder system, and transmission fluid for the torque converter. I'm currently using NAPA TDH with no problems.
Sep 07, 2009 | The Times Case Corporation Tractors...
Apr 15, 2009 | Toys
Checking fluids
look for a tank reservoir with a dipstick. Locate the pump or cylinder and follow the line back to the tank.
Dec 22, 2008 | Ertl International Harvester Farmall Super...
Farmall IH  Tractor 460, 560, 660, 2606 ITIH25 Logo
295 people viewed this question
Top Farmall Toys Experts
Phil Walker
Phil Walker
Bud H
Adam Plug
Adam Plug
Are you a Farmall Toy Expert? Answer questions, earn points and help others
