Question about Maytag Neptune MDG5500AW Gas Dryer
How to open the top?
How to open the top of a Maytag Neptune dryer.
  • 1,531 Answers
There are two clips about one inch in from either side of the cabinet that need to be pushed in with a flat tip screw driver
Posted on Jan 31, 2010
Maytag Neptune Dryer, Light inside with door open, but no lights up on top and does not run, can you please help me out, or where to start?
Check the breaker or fuse box. Sounds like one leg of the 220 volts is tripped. Reset it or replace the fuse if so.
Oct 19, 2014 | Maytag Neptune MDE5500AY Electric Dryer
My Maytag Neptune dryer doesn't stop unless I open the dryer door.
You will be needing to replace the timer assembly, which is the part that has all the wires attached and is found inside the top of the machine. It is what the dial is fastened to.
Be blessed.
Jan 08, 2014 | Maytag Neptune MDG5500AW Gas Dryer
A paddle inside drum is loose, need to open top of dryer
first take the door out from the hinges then the frame around the door the you can open the top or the front of your machine...
May 01, 2010 | Maytag Neptune MDE5500AY Electric Dryer
How to remove the front panel of a maytag neptune gas dryer
Removal of the front panel requires the removal of the top cover and the console. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Remove the 2 screws attaching the top cover to the rear of the dryer then slide it rearward to clear the screw head from the top cover flange and lift the cover off the dryer cabinet.
Remove the screws securing the heater PCB board and disconnect the black and white wiring harness connectors from the board.
Remove the four screws attaching the console to the washer cabinet and rotate the console down to remove it from the dryer.
Remove the four screws attaching the top of the front panel to the cabinet and the two screws at the bottom of the door opening.
Pull the front panel forward and disconnect the interior light wiring harness then lift the front panel off the tabs across the bottom and move it away from the dryer.
Reinstall the front panel, the console, and the top cover in reverse of the removal steps.
Apr 21, 2010 | Maytag Neptune MDG5500AW Gas Dryer
I have a maytag neptune dryer. When I open the
Issue:
I have a maytag neptune dryer. When I open the door it doesn't turn on . What could be the problem?
Solution:
This is normal! The dryer has a door switch that will prevent it from operating with the door in the open position. This is a safety feature and cannot be overidden.
Aug 13, 2009 | Maytag Dryers
Can't figure out how to get the top off
http://www.pcappliancerepair.com/model-display.php This one looks like a real puzzle. Open the door and look for screws holding the front on, the top seems to lift up once something is released.
Apr 26, 2009 | Maytag Neptune MDE4000 Electric Dryer
Maytag neptune electric dryer
Warning! Disconnect power before servicing!
1.Open the door and remove the screws holding the door, then pull outward on the door to disengage the hinges.
2, Remove the screws on the opposite side of the door opening.
3. Pull outward on the lower part of the front panel to disengage from the top.
4. Remove the screw from the top left and right corner top retainer bracket.
5. Rotate the retainer brackets toward each other to disengage the top from the side panels.
6. Lift top.
May 24, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune dc
I have a Maytag Neptune drying center. The top unit is making a very loud banging noise. How can it be repaired, is this a common problem?
Apr 18, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Change rollers on a Maytag Neptune Dryer
You have to work from the front. Pull the top then the front then you will be able to see everything. Pretty self explanatory.
Dec 01, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
109 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
