Question about Whirlpool Calypso GVW9959K Top Load Washer
Timer setting How do I set a newly installed timer to a top load washing machine to its complete washing cycle?
    President:
  • 1,314 Answers
Choose the load size on the timer for what your putting in large small medium etc match the water fill large small med etc select wash rinse temp to you pref add soap bleach fabric softner pull out the knob make sure the lid is closed
Posted on Feb 18, 2008
Just got washing machine...its used. However it stops mid cycle and is full of water. I have to stop it and turn the knob to a different setting (like from normal to permpress) and sometimes it will...
If it just stops in one of the cycles such as regular, it points to the timer being defective. Have you tried to complete a cycle in say, perma press pr delicate? If it works ok in the different cycles except one, it's most likely the timer.
Jun 21, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Timer setting
this model doesn't have a timer. it is computer controlled.
Feb 18, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
WHDSR209DWW on/off button will not engage to spin the cycle selector dial
The cycle selector is not engaged onto the timer shaft. Need to remove the on/off knob by removing the plastic "U" clip. Remove the cycle selctor knob and check that the steel spring clip on the selector is fully seated. Re-install the cycle selector onto the timer shaft aligning the selector key with the with tthe notch on the timer shaft. Re-install the on/off knob.
The cycle selector and on/off combination is a poor design. Users press the on/off knob in and turn clockwise to set the wash cycle. If you're not gentle this action wears the teeth on the timer shaft and the user has to press harder and harder to set the wash cycle. This pressing causes the cycle selector to be pushed off the timer shaft and you can no longer operate the machine.
VERY IMPORTANT:
Stop using the on/off knob to set the wash cycle. Press on the cycle selector to set the wash cycle. Use the on/off knob only for starting or stopping the machine. Don't press or pull too hard on the on/off knob or you will wind up pushing the cycle selector off the timer shaft.
Jan 12, 2010 | General Electric WHDSR209DWW Top Load...
Fabric softener cup on Maytag Neptune washer is full of fabric softener after the cycle. Checked valves in output mode. Both the main and the bleach valve turn on and dispense water, but no water dispenses...
Hi. your problem is actually a rather complicated one.
Timer and selector switches The timer switch is usually the largest dial on the main control panel. It can be either a mechanical device much like a simple clock, or completely electronic with just a digital readout.
The timer runs the washing machine in a pre-determined pattern. It provides the electricity to all of the washing machine components at the correct time and for the correct length of time.
The Start switch is usually part of the timer knob. When you set the timer to the proper cycle, you either pull or push the timer knob to start the cycle.
The selector switches or knobs vary from machine to machine. Most washing machines have one or several switches or knobs on the control panel besides the Timer/Start switch. These let you adjust certain settings; for example, the water temperature, spin speed, timer cycle, and so on. Normally, the washing machine completes the cycle selected on the timer, regardless of how you set these switches and knobs.
Jul 14, 2009 | Maytag MAH2400A Front Load Washer
Whirlpool Top Load Washer cycle problem
check the lid switch by putting a screwdriver into the lid switch hole; look at your timer duration diagram it's in the control panel a small sheet of paper taped inside Does you machine not advance mark the timer knob and, see how far the knob advances next set the timer for the agitate position and check the timer for continuity on those pins noted on the sheet
May 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine starts by itself
going through to the next wash not na normal function, perhaps the machine is advancing to an extra rinse cycle?? this EXTRA RINSE will start after the normal wash is complete, i would check your dial settings perhaps some one has mistaknely switched extra rinse "ON". if htis os not tyhe case the n i would jave to blame a faulty timer mechanism and you would need to replace the timer
Feb 15, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
MACHINE NOT COMPLETING WASH CYCLE
your problem can be one of a number of things. First, if its stopping in the wash cycle itself i would look at the timer, if it stops when its suppose to spin, i would look at the lid swtch.If its not agitating at all, then replace the coupler.
Dec 31, 2008 | Whirlpool LSR5132PQ Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
133 people viewed this question
Dan Webster
Dan Webster
Sal De
